I see that Panavises are highly recommended by a number of you. What base/head combination would you suggest as an initial purchase? The circuit board holder looks great, but there doesn't seem to be much expandability. I was thinking the model 350 (tray base, wide jaws) might be a better option because it can take a wire holder. Do the wide jaws work well for PCBs? Is the soldering station useful?
Thanks for suggestions!
what are you planning to use it for first ?
and how do you want it to stay in place
The 380 base with 376 head has been very helpful (unmoving, firm and easy to adjust) for soldering of xlr connectors and modding of my K340 headphones
Mostly using it for soldering PCBs (usually small to medium size). However, I'm also looking at non-PCB heads for a secondary use to hold plastic case parts while I Dremel them.
I'm hoping that the base will stay put without bolting it to the table (not an option).
  • 4 months later...
I have the 324 work center, minus the solder iron holder, which I bought off of ebay. I never have bought any other heads for it; still use a helping hands for cable shit (or my bench vise). I dislike the helping hands more everytime I use them :palm: The Panavise Jr. looks nice, if you can live with its limitations.
Chris, do you think the 324 would work for cables?
Not really, no. I have one has well and its functionality is pretty much limited to PCBs with those big jaws although as Chris said you can buy other heads for it.
