Should I Get an HD600?
40 minutes ago, Dusty Chalk said:
No, I remember even before , the HD600 was considered veiled unless you amped it properly . I don't consider one more veiled than the other .
I always thought that "veiled unless amped properly" just meant "like most headphones, they sound best when properly amplified."
  • Replies 259
  • Views 68.5k
Yeah, but this was in the early days, when most people were not amplifying properly.  And yes, you're right, most headphones "scale" -- they respond well to increasingly better amplification.  I think the HD600 are worse than most (in the same way I think the VTGs and the Sony MDR-7506/-V6 are better than most, in that they scale very little).
1 hour ago, dsavitsk said:
QED
Meh. It was one of those things. I generally don't follow for sale forums that closely and i do like Sennheisers.
44 minutes ago, grawk said:
The reason I like VTGs and JH13s is they sound basically as good straight from my iphone as from most amps.
Yeah, that's what I was trying to say about the VTGs.  I probably should not have said, "...in the same way..." when I really meant "...the same, only different..."
High impedance, relatively low sensitivity.
1 minute ago, Dusty Chalk said:
If my responses don't make sense, it's because I'm more inebriated than usual.
I'm less than normal.
