September 15, 200917 yr comment_276415 Having problems with the search function so apologies if this has already been dealt with. I'm quite enarmored with PC as source due to its convenience but wondering about possible ways to get data from a PC to a DAC. For instance I have a Havana DAC that I've compared using direct USB input vs RCA from an EMU1212m soundcard and preferred the USB by quite a bit even though it's regarded as a lesser method. It just didn't sound as detailed or tonally correct via the RCA socket. So, for an older style DAC with BNC input (like an Assemblage 2.0 for instance) I was wondering whether anyone has any thoughts beyond just connecting up the EMU1212m via a BNC cable and RCA converter? Bel Canto do a USB to BNC converter for $495, which, at the cost of the DAC, I find to be a little excessive, though I'm sure it does a good enough job. However, wouldn't using a Twisted Pear USB receiver be both more cost effective and do pretty much the same thing? Granted there's a little extra hassle sourcing and adapting the enclosure and soldering in the bnc socket, but fairly minor considering the cost difference. As an aside, when I was seriously considering buying a Sonic Frontier 3, I heard that some bright spark had managed to adapt a floppy drive cable and connect it directly from the EMU1212m child-card socket (the sound card has an analogue out child card) to the DAC via the proprietary 13-pin or whatever connector. Nice idea if you can get it to work I suppose. Cheers ) Report
September 15, 200917 yr comment_276420 However, wouldn't using a Twisted Pear USB receiver be both more cost effective and do pretty much the same thing? Granted there's a little extra hassle sourcing and adapting the enclosure and soldering in the bnc socket, but fairly minor considering the cost difference. Along DIY lines, I would probably recommend a Gamma1 USB to SPDIF converter, then use an RCA to BNC coax cable (BJC can do these cables really cheaply). Should come out much cheaper than the TPA offering and fits nicely inside a bog-standard Hammond case. I'm planning a similar thing for my upcoming Buffalo re-build; the Gamma1 will be housed inside the case, and wired directly into a TPA SPDIF MUX. As for more expensive options like the Bel Canto...... well, I just am not nearly enough of a believer in audibility of jitter to pay anywhere near that much money for just a digital interface. Report
September 15, 200917 yr comment_276421 Don't know if this helps any: http://www.head-case.org/forums/off-topic/1488-post-last-thing-you-bought-617.html#post276490 http://www.head-case.org/forums/off-topic/1488-post-last-thing-you-bought-617.html#post276499 I placed the order this weekend, so I expect to receive it by this weekend. Approx.~ $70-$80 on ebay for the Musiland Monitor USD. Report
September 15, 200917 yr comment_276423 Yeah, they look like handy little devices. I investigated those for the Buffalo, but there just wasn't enough info about them for me to make them a permanent fitting inside my DAC. Report
September 15, 200917 yr Author comment_276431 Thanks Beefy and Alex. I like the tests AMB performed on their USB to S/PDIF converter and it seems like quite a bit more work than just buying the TPA one. Are they clearly superior? General rule of thumb - the less soldering I have to do the better. I know I asked a similar question before about USB direct to a Buffalo DAC. Also, I can't see any reason why a S/PDIF COAX RCA socket can't just be wired to a BNC socket instead? Aren't they (electrically) the same thing? From what I gather, the main advantage of BNC is that it's 'true' 75 ohm vs RCA which somehow isn't due to socket design? Is this as a result of a mechanically designed feature - ie the BNC socket is more securely attached, than RCA which just 'slips on'? Or that the 'resistance' of BNC sockets are 75ohm and RCA sockets aren't or have more variation? Alex - please tell me what you think of the Trends and Musiland USB converters ) Cheers! Report
September 15, 200917 yr comment_276437 General rule of thumb - the less soldering I have to do the better. Then just ask MisterX what it would cost for him to build you one Also, I can't see any reason why a S/PDIF COAX RCA socket can't just be wired to a BNC socket instead? Aren't they (electrically) the same thing? Yep, same thing electrically, no reason you couldn't use a BNC other than physical size of the connector. From what I gather, the main advantage of BNC is that it's 'true' 75 ohm vs RCA which somehow isn't due to socket design? Is this as a result of a mechanically designed feature - ie the BNC socket is more securely attached, than RCA which just 'slips on'? Or that the 'resistance' of BNC sockets are 75ohm and RCA sockets aren't or have more variation? Pretty much all that...... but it isn't resistance that is different, but rather characteristic impedance - it all makes my brain hurt, so I will let someone smarter explain it. But if you have good gear and short cables runs I see no tangible advantage in specifically using BNC over RCA connectors, except where you have to with your existing gear. Report
September 15, 200917 yr comment_276451 The Musiland USB converters (particularly the ones that don't draw their 5V off USB) should be fairly decent as far as USB goes, since they're asynchronous. Have you considered upgrading the EMU1212m instead of going with USB? Report
September 15, 200917 yr Author comment_276455 Hmmmm - interesting. I didn't know they were async... The Musiland 01 looks good value (only $74). What soundcard would you suggest as a transport? Report
September 15, 200917 yr comment_276460 Hmmmm - interesting. I didn't know they were async... The Musiland 01 looks good value (only $74). What soundcard would you suggest as a transport? Yes, they are asynch, which is what prompted me to buy one. There are three models: USD01 is USB to spdif and toslink converver. US01 adds a DAC and headphone amp to USD01 US02 adds a built in power supply to US01 and an extra headphone amp I chose the 1st because I dont need the options of the other three (plus it looks like the BNC connection is not available in the other two, im not sure). The Trends Audio does well, but if the USD01 does up to 192kHz (whereas the Trends tops at 48kHZ) and does it well for almost half as much, it's a no brainer for me. But we'll see what happens when the unit arrives. Report
September 15, 200917 yr comment_276462 Hmmmm - interesting. I didn't know they were async... The Musiland 01 looks good value (only $74). Neither did I. Good value indeed! Report
September 15, 200917 yr comment_276525 <snip> Pretty much all that...... but it isn't resistance that is different, but rather characteristic impedance - it all makes my brain hurt, so I will let someone smarter explain it. But if you have good gear and short cables runs I see no tangible advantage in specifically using BNC over RCA connectors, except where you have to with your existing gear. Its a physics thing regarding the BNC can do 75 ohms; RCAs can't. Has to do with the spacing of the center pin versus the shield I believe. Much gear isn't terminated correctly (if at all) anyhow, so just changing the connector will likely not have much effect. I've replaced the clock on a CDP and it made a big difference (not as big as the discrete output stage, but still big), so I do think that minimizing jitter is beneficial; I know alot of people consider it near snake-oil so will let it go at that. Report
September 15, 200917 yr comment_276529 Its a physics thing regarding the BNC can do 75 ohms; RCAs can't.I did not know that. So most all coaxial cable connections everywhere are wrong? Report
September 15, 200917 yr comment_276530 I did not know that. So most all coaxial cable connections everywhere are wrong? yes indeed (the one exception might be the proper use of line transformers) Report
September 15, 200917 yr comment_276534 Don't know if this helps any: http://www.head-case.org/forums/off-topic/1488-post-last-thing-you-bought-617.html#post276490 http://www.head-case.org/forums/off-topic/1488-post-last-thing-you-bought-617.html#post276499 I placed the order this weekend, so I expect to receive it by this weekend. Approx.~ $70-$80 on ebay for the Musiland Monitor USD. How are they implementing ASYNC? As far as I knew Gordon Rankin (and those he licensed it to) are the only ones using it. Also in an Ebay auction FAQ: Q: DOES THIS ITEM WORK WITH A INTEL MAC MINI? A: No, it doesn't work with MacOS. Makes me suspicious as ASYNC devices are compatible with OS X. Report
September 15, 200917 yr comment_276536 How are they implementing ASYNC? As far as I knew Gordon Rankin (and those he licensed it to) are the only ones using it. ...... Makes me suspicious as ASYNC devices are compatible with OS X. The USB receiver seems to be a programmable chip (FPGA) that they implement with custom drivers. So it is the simple case that they have written Windows drivers, but not Mac drivers. Report
September 15, 200917 yr comment_276539 No idea how, but it is probably a custom solution. No idea if it is actually async, but the fact that it doesnt work with Macs doesnt really mean anything. I would expect a custom solution to require the installation of it's own drivers, either through a separate software install or uploaded from the device. They probably just didnt bother doing Mac drivers. Bah, beaten by Beefy! Report
September 15, 200917 yr comment_276577 Offramp3 also starts at $700, which is a rather steep premium for code that others will write before too long. Report
September 15, 200917 yr comment_276579 Offramp3 is async and works with macs. Search empirical audio here, its been mentioned before. There is a large price difference. Report
September 15, 200917 yr comment_276583 Certainly possibly they could have coded their own solution via an fpga.. that's similar to what j4cbo is doing. If they are then that's like all sorts of victory. Report
September 15, 200917 yr comment_276591 Offramp3 is async and works with macs. Actually, it isn't (I don't see any mention of it on his website). The only async solution empirical audio offers involves a modded Tascam US-144 + their clocking device. How are they implementing ASYNC? As far as I knew Gordon Rankin (and those he licensed it to) are the only ones using it. There are quite a number of async USB devices out there actually... the Tascam US-144, and even the EMU 0404 USB are meant to be async, and they all use custom solutions. Report
September 16, 200917 yr comment_276759 I've never heard the 0404 myself, but I know it has other features I won't use, features that add to the price, making it unnecessarily more expensive for my needs. Report
September 17, 200917 yr comment_277370 Musiland Monitor USD 01 has arrived! Now I know what I'll be doing this weekend. Report
September 18, 200917 yr comment_277397 Musiland Monitor USD 01 has arrived! Now I know what I'll be doing this weekend. Writing impressions? Report
September 18, 200917 yr comment_277401 Musiland Monitor USD 01 has arrived! Now I know what I'll be doing this weekend. wondering if you should upgrade to the 0404? Report
