I had the fuse in my Klipsch iFi subwoofer blow. It's a 2A 125V slow blow fuse. Went to a couple Radioshacks and they only carry a 2A 250V fuse. Is it okay use that as a replacement? At the first the lady said, "Probably, but I wouldn't bet my life on it." Second store guy said "You only have to worry about over-wattage." :confused:
My concern is that if something hits say... 200V and the fuse doesn't blow, will I end up damaging other components downstream?
Yes, it is fine. It is the current rating that you need to pay attention to; that and whether it is fast blow or slow-blow. Most fuses seem to be 250V anyhow...
Dont do that, measure DC voltage. Likely to blow your sub if you try and measure current by replacing the fuse with the dmm, since there is definitely something going on.
