I'm trying to get my squeezebox (v1) to play my personal Last.FM radio and it seems that the only way to do that is to get the stream url somehow. I've tried most methods that I've seen on the interwebz (squeezebox forums included) with no luck. If anyone sees a solution, I would love to know.
EDIT: I know this can be done somehow since a foobar plug-in does it very well.2009-09-03_1453.png
The official last.fm scrobbler can act as a radio relay. Just go to Tools > Options > Radio and specify a port. Then point your squeezebox at http://pc-ip:port.
I don't think there's a way to get a direct connection, last time I checked last.fm used a proprietary streaming protocol to deter ripping.
Hmm, I'm probably an idiot but I can't get the lastfm radio streaming from the scrobbler to work. When I try to open the url in squeezecenter or even foobar or vlc, it doesnt recognize the address and it does nothing. :(
Yeah, sorry, I know I checked out the code, but it's on neither my home machine nor on my work machine, so I have to either check it out again or download it.* So let me know if you get it, and I won't get around to it right away.
* I do that a lot -- bite off more than I can chew, then put it on the backburner. :palm:
