Best Place to Purchase Tube Sockets in the US
jp11801
I need to pick up three sets of tube sockets for my Dared 845 amp and I assume I need 2 pcb mount 12ax7, 2 6sn7 pcb mount (do they make a 7n7 pcb mount?) and a pair of 845 bayonet type sockets. I really prefer high quality over saving a few bucks. Any ideas on where to buy also ceramic and teflon is one better than the other? The reason I ask is I found a local tech here in the East Bay (SF area) that will do the work if I source the sockets. Great older guy who grew up in the radio and recording industry.
Thanks in advance for any help that you can provide.
Parts Connexion. Check out the Teflon Composite for the 12ax7 and 6SN7 (no loktal PCB mount I know of)... PcX is cheaper than the 'bay on these last I checked. For 845, not too many options to choose from. Slightly cheaper than the tefcom sockets are Azuma sockets, also available at PcX. If you want to spend some money, there is always Yamamoto:
Edited by luvdunhill
Nixie Clock? With downward facing tubes for the dots in the colons? (I.E. pointing straight at you.)
Serious answer to the side question -- I saw KG criticizing Mikhail's choice of tube sockets and recommend replacing them with ceramics enough times that I googled researched the topic a little bit and found this site. The thing that I found most eyebrow-raising was the water-absorption of ceramic, wouldn't mind knowing if that's malarkey or not (they are, after all, trying to sell their own choice of materials). I have to admit to noticing my ceramic sockets getting soggy over the course of decades. Oh, wait a minute, no, that never happened.
another link
google for yourself
The problem with mikhail's tube sockets is that the plating on the metal pins comes
off real easy, then all you are left with is regular steel which gets rust on it and
the contact quality degrades very fast. There are plenty of other sockets just
like that that are made better.
Everything said about teflon is true, but if you use the solder mount sockets and
have everything perfectly aligned, nothing ever moves. In fact if i could get
the tulip pins by themselves i would not even need the rest of the socket.
Except then you have to pay real attention to the way the octal tube gets inserted.
