Just been looking over the ES1 and was wondering if there's any reason the four triodes couldn't be replaced with two twin triodes and replace R5-R8 with a pair of 2k resistors across the tabs?
Bear in mind I know shit about this, so humor me :)
The 4 input tubes are actually 2 x 6sn7's and are twin triodes.
However the original circuit was 2 x 12ax7's which have more gain.
Fact is that as shown the amp just barely has enough gain to
work. In fact its a good idea to change out the 1500 ohm resistor to 1k ohm
to bump up the gain a bit.
If you do replace the front end with 12ax7's then you need to lower the B+
to that section because 400 or 450 is too much. There is another power
supply in the T2 that would be great for 300 volts...
Edited by kevin gilmore
cool, I wasn't sure I was reading it right. Looks like it could be made very small as well, aside fom the psu/transfos.
I might have a go at this when I'm a little more practced
let me be slightly more specific.
something like the old vampire right angle single rca jacks, circuit board mount.
justin's are not right angle..
The connex one is the only one currently available, and it is way to long, i.e.
i have to mount it 1 inch back from the circuit board edge to get it to fit the
backpanel.
The cardas is even longer as a dual.
Is this what you are looking for?
Rapid Electronics - Cables & Connectors
Sorry, only UK... And they seem quite expensive...
I've spent the last few hours searching for PCB rca connectors and coming up empty. The single Cardas GRFA might fit but I can't find any other nice ones which aren't branded Vampire. Perhaps we should just have the RCA's on short lead wires?
The stock T2 supply is not RCRC. In fact its just diode bridge into
capacitors...(balancing resistors and discharge resistors don't count)
My bad... it's not like the schematic wasn't within reach... :palm:
If you ever want to tackle this Gary just drop me a line. The ES-1 rebuild has been on hold for a while now but I'm about to get cracking again and solve those damn gain issues (one channel is lower then the other in SE mode) and add the second 5k pot for the front end.
You can also build a smaller version (ECC83, ECC99 and 6S4A's)... :)
Those appear to be Vampire Wire units
Pabbi linked a picture of one at some point and I think he's the only one that's built one? Talking with luvdunhill who I believe designed it? He says that its actually more like the woo amp WES or was it the GES? I forget which one its like... but yeah it's a whole other direction.
If you consider the BH to be one tangent and the Vulcan to be one tangent I think the T2 is somewhere in between sharing like 50-75 percent overlap with the BH... but with more tubes to roll and other differences.
Anyway I'm not technical so correct me if I'm wrong?
Well, Marc is the designer, where the design goals were BHish, but with 6s4a tubes. Marc SHOULD have his built... mine looks like:
Now, what Peter was referring to is the Poor Mans stat amp (~$300), which looks like, but not quite there, though in final proto, with one up and running, one damn close, another by the weekend, well, then mine, which is always the problem child. -=I=- am DIY's lowesr common denominator - sorry Smeggy.
God damn, by spirits are flagging, and I still have to fix one channel on my BH - worse that Mikhail, except I'm just fucking myself over.
what to do?
http://gilmore.chem.northwestern.edu/sockets.jpg
If i make the octal sockets flush with the top of the amplifier
then the 9 pin sockets are .23 inches below the top of the amplifier?
If i make the 9 pin sockets flush with the top of the amp, then i have
to make the holes for the octals bigger and they stick up .23 inches?
Or push them both thru the top and make different sized tube rings?
any suggestions...
would rather not machine up some tube rings..
what to do?
any suggestions...
use ceramic standoffs to add some height to the noval sockets?
If i make the holes real big for the octals i can push them thru to the threads and gain another .12 inch.
yes, that's what I meant. I have a whole sack of mil-spec ceramic standoffs around here somewhere... They cost a fortune to buy these days through Mouser, etc.
So the size of the RK50 dictates positioning too.
Its actually perfect flush mount for the noval's, and the
octal will be .230 high, and i'll make .250 rings.
Or maybe plates, ray style :D
luvdunhill, what is the thickness of the ceramics you have (need to be .09 id) and .25 long.
and do you have 600 of them that you want to sell?
I totally missed that!
It looks complete class compared to the WPI job.
Much more secure mount to boot.
I was being a clown, by patting myself on the back. I built that jack with help from a really cool jig Marc designed. It is a fantastic jack though, and it really has a quality feel when inserting the Stax plug. If you knew Marc (luvdunhill) like many of us do, you'd expect nothing less.
I hope it's safe to out your plug Marc, considering I already did so quite a while back. :P
