lusting after knobs is perfectly fine around here... NTTIAWWT...
I almost got a woody when I saw Kevin's telfon knob but thought it better to keep that to myself. However I see I'm in good company.. :D
Beautifully neat looking work Craig, re-spect. How long did it take you?
Thanks struts and voltron.
I didn't keep a tally, but I guess it must have been ten hours for both boards, or maybe a little more, spread over three days. I don't have a flip over frame to help soldering, so I stuck a piece of carpet onto piece of plywood just larger than the big board with carpet spray glue. Used a lead bender to assist component preparation while the boards were propped on two transformers - then put the carpet gizmo on top and flipped it. Worked a treat.
Ok guys - what is the secret? I've just experimentally tried out a 2SJ109 and I failed fairly miserably to get it in the holes.
**** ENTER YOUR CHOICE OF DR. WOOD JOKE HERE ****
You don
The delrin extension is what i had in stock. Aluminum works fine.
The knob gets as hot as the rest of it. Its unlikely that people are going to listen to this
thing 12 hours a day, and the anodizing is going to definitely get rid of the heat.
On the original, the knob got very hot too.
The 2sc3381's i have measure a diameter of .020
and i reamed the holes out to .0205
will go find some 2sj109's to measure.
Edited by kevin gilmore
I'm assuming that's the "major diameter"? I thought they had square pins...
The pins are square. I got .020 on the flats and between .0235 and .0240 from corner to corner. Regardless, they still fit(on my board anyway), all be it very very snug.
I don't see any problem reaming the holes out, if needed, as long as one makes sure to properly solder both sides of each lead(both sides of the board.)
Edited by digger945
Wow that came out great. Justin quality great. And slightly cheaper.
Hey birgir, get your ass to the customs agent and pick up your package please.
Then post some more pictures.
Custom piece for Inu will be finished by next week.
So will Birgirs one and only custom knob. :D
