kevin gilmore Posted March 24, 2010 Report Posted March 24, 2010 I have real sources and you know it. Easier to move the amplifier downstairs than to move the source upstairs. Besides which the rest of the stuff is already in the media room.
morphsci Posted March 24, 2010 Report Posted March 24, 2010 .... It is going to be a tight squeeze in my corvette for CJ010 T2 amplifier and power supply sony sacd player cables and power strip stack of music Camera with 2 lenses, tripod, regular and tripple ring flash 35+ bottles of booze clothes for 3 days If i have to, i'll give up the extra clothes .... No need. The liquid refreshments will fit nicely in the pick-up. Then you can even bring extra clothes ... or .... more whisk(e)y.
jgazal Posted March 24, 2010 Report Posted March 24, 2010 I'm going to do serious listening over the weekend after cleaning up some of the mess. I have (...). (...) omega's, omega2's,sr-003, sr-404 headphones and the koss esp950. I know that you were going to comment that anyway, but it would be nice to have your opinion about differences between SR404 and both Omega's when they are being driven by T2.
kevin gilmore Posted March 24, 2010 Report Posted March 24, 2010 Speaking of milling around http://gilmore.chem.northwestern.edu/t2parts1.jpg http://gilmore.chem.northwestern.edu/t2parts2.jpg
n_maher Posted March 24, 2010 Report Posted March 24, 2010 Sweet! Is it so wrong I'm more curious about what you're doing with the 8020 profiles?
kevin gilmore Posted March 24, 2010 Report Posted March 24, 2010 I love 8020. Erector sets for BIG kids. All of my Salamander cabinets use 8020 as the vertical members, i'm making internal supports for my soon to be showing up 82 inch lcd panel. Which is suprisingly heavy.
kevin gilmore Posted March 25, 2010 Report Posted March 25, 2010 So seeing this reminds me how much i want a single piece machined T2 chassis. http://gilmore.chem.northwestern.edu/singlepiece.jpg I'm scheduling it for early next year. The 18 inch x 18 inch x 3.5 inch blocks are about $900 in material each. Vertical heatsink fins will be directly machined out of the block, as will the insides. Sort of like the CTC blowtorch, but about 3 times bigger.
n_maher Posted March 25, 2010 Report Posted March 25, 2010 I'd hate to have to clean up the mess from milling that.
kevin gilmore Posted March 25, 2010 Report Posted March 25, 2010 I'd hate to have to clean up the mess from milling that. yep, lot of mess from that one. Luckily its now all automatic... air hose blasts the pieces away while machining, box is completely closed and monster industrial vacuum stuck into a 55 gallon drum sucks away the mess. Then the scrap gets recycled.
n_maher Posted March 25, 2010 Report Posted March 25, 2010 Any concern about reaching that deep into something with an endmill and getting chatter?
kevin gilmore Posted March 25, 2010 Report Posted March 25, 2010 Special head with a 1 inch carbide mill bit. Can do 4 inches max. That is why the corners are that round. I only need 2.95 less the .25 for the bottom. Should not be a problem. Estimate of 20 hours of machine time including the heatsinks.
Kerry Posted March 25, 2010 Report Posted March 25, 2010 Special head with a 1 inch carbide mill bit. Can do 4 inches max. That is why the corners are that round. I only need 2.95 less the .25 for the bottom. Should not be a problem. Estimate of 20 hours of machine time including the heatsinks. I have to say that you have the coolest toys
voodoochile Posted March 25, 2010 Report Posted March 25, 2010 Holy crap, Kevin! That's a huge chunk. You could make high-end wetbar sinks on the sideline.
Guest sawyers Posted March 25, 2010 Report Posted March 25, 2010 So seeing this reminds me how much i want a single piece machined T2 chassis. http://gilmore.chem.northwestern.edu/singlepiece.jpg I'm scheduling it for early next year. The 18 inch x 18 inch x 3.5 inch blocks are about $900 in material each. Vertical heatsink fins will be directly machined out of the block, as will the insides. Sort of like the CTC blowtorch, but about 3 times bigger. You thought about making it vacuum sealed and filling with high thermal conductivity gas? I believe power generation companies used forced hydrogen cooling for their generator sets
deepak Posted March 25, 2010 Report Posted March 25, 2010 So seeing this reminds me how much i want a single piece machined T2 chassis. http://gilmore.chem.northwestern.edu/singlepiece.jpg I'm scheduling it for early next year. The 18 inch x 18 inch x 3.5 inch blocks are about $900 in material each. Vertical heatsink fins will be directly machined out of the block, as will the insides. Sort of like the CTC blowtorch, but about 3 times bigger. Very nice KG, so when is the Blowtorch successor coming out from you? edit: I honestly didn't read the last line I just clicked the pic, and the first thing that came to mind was Blowtorch
luvdunhill Posted March 25, 2010 Report Posted March 25, 2010 So seeing this reminds me how much i want a single piece machined T2 chassis. please enclose two Ayre MX-R clones for me. k thx bye moar pics here: [url=http://blog.livedoor.jp/morohide/archives/51668266.html]
Guest sawyers Posted March 25, 2010 Report Posted March 25, 2010 please enclose two Ayre MX-R clones for me. k thx bye [url=http://blog.livedoor.jp/morohide/archives/51668266.html]
Hopstretch Posted March 25, 2010 Report Posted March 25, 2010 I heard a pair of those driving Hansen Emperors the other day. It was the silver setup of my dreams.
kevin gilmore Posted March 25, 2010 Report Posted March 25, 2010 Ayre is absolutely magnificent stuff and Charles Hanson is actually a really nice guy that tries to help people. It uses the on-semiconductor 5 wire thermal track output devices. Its not actually vacuum sealed, there is no gasket. The input connectors and output connectors are definitely not hermetic. It would be kind of hard to do a hermetic system with tube sticking out. See... I'm not the only one that is completely nuts... For the pair of units, the amplifier bottom would be the cover, and the power supply top would be the cover. When you put them on top of each other it would look like 2 slabs of stuff with no visible screws from the front, sides or top. Just like the Blowtorch. Except with heatsink fins and 3 times bigger and 5 times heavier.
spritzer Posted March 25, 2010 Author Report Posted March 25, 2010 Its not actually vacuum sealed, there is no gasket. The input connectors and output connectors are definitely not hermetic. It would be kind of hard to do a hermetic system with tube sticking out. KGSS?
jgazal Posted March 26, 2010 Report Posted March 26, 2010 Large Hadrons Collider – LHC consumes 1% of liquid nitrogen produced in the whole world to induce its superconductors. 30 fellows forcing gas refrigeration into theirs T2's would consume almost the same... Then labs would have to pay more for nitrogen with the increasing demand. But they use that for physics, medicine etc. People use T2 for music, funny thing... Would not be better (cost efficient) to water cool only the semiconductors (like core processors in PC’s)? How much distortion is induced by heat on capacitors, resistors etc?
Emooze Posted March 26, 2010 Report Posted March 26, 2010 If you were filling the enclosure with thermally conductive gas, would you need the tubes sticking out? And what about using a non-conductive liquid like mineral oil?
