The ultimate DIY? A Stax SRM-T2!
spritzer
updated parts spreadsheet including resistors for the power supply and
the .1uf/50 volt caps i was missing as i stuffed the board...
(what a mess... the spreadsheet that is, the board is gorgeous)
having imagineering do the circuit boards was definitely a good idea even
though they cost a bit more. Solders just great.
http://gilmore.chem.northwestern.edu/t2parts3.xls
stax X1t ------------- NOPE!
but i am getting closer to wireless hdmi based SACD... :D
Edited by kevin gilmore
Is a DIY version of the X1t inevitably next? ;)
Hell no!! I'm going to track down and buy the unit rumored to be here in Iceland though. :)
Having them made in China wasn't going to be much cheaper and the quality can be pretty shitty. Fine for prototyping though.
You think those boards weren't made in China?
Chances are roughly 1:3.
Take advantage of what our customers already know -- that Imagineering, Inc. has the experience and capability to fabricate printed circuit boards at our offshore facilities in Korea, Taiwan and mainland China. Collectively, our facilities are UL94V-0, ISO-9002, QS-9000, and IS0-14000 certified. By outsourcing your PCB fabrication needs to our manufacturing partners in Asia we will save you money, regardless of the volume of your production
after 6 hours of board stuffing
http://gilmore.chem.northwestern.edu/t2ampboard1.jpg
only errors so far, on one side of the amp 2 of the resistors are
labeled as 100k when they are in fact 10k.
Obviously everything fits perfect.
Custom stainless steel hex head screws the exact length should be
in tomorrow, then i can mount the stuff on the heatsinks.
trimpots go on the top of the board for easy adjustment.
missing resistors are backorder :(
A reasonable person should be able to stuff the board in 12 hours...
Not so bad :D
i love it, stuffed both channels before testing, like an impatient child
But there are 2 power supply connectors, and the whole thing is wired completely
as dual mono. So i built the thing completely so i did not have to go thru
the pile of resistors twice. I can and likely will power up only half of it the first
time.
Besides which the power supply will be tested completely first.
So with the proper tools that i made myself, stuffing the heatsinked transistors
was a snap. Picture with the tools on the left. Since the tools are dirt cheap
(they take me less than a minute to make) i will probably supply them in the kit.
Better than spending over $300 on the real tool.
tool widths... .1618, .3271,.4780,.5780
I'm going to stick with the following numbers :D
superman (as in justin) assembly time 6 hours
me (as in me) assembly time 9 hours
normal human (everyone else) 12 hours
http://gilmore.chem.northwestern.edu/t2ampboard2.jpg
in the case of Justin, are those the same hours that are used to assemble a BHSE? ;)
I don't quite get how the tools are used, but I'm all for custom tools!
