spritzer Posted November 2, 2009 Author Report Posted November 2, 2009 Hell yeah!!! I'll drop Craig a line later today.
kevin gilmore Posted November 2, 2009 Report Posted November 2, 2009 Time to show off my bottom (err... panel) http://gilmore.chem.northwestern.edu/t2chassis12.jpg Top and bottom of the power supply box will look similar.
n_maher Posted November 2, 2009 Report Posted November 2, 2009 Cue Justin saying it needs more holes.
nattonrice Posted November 2, 2009 Report Posted November 2, 2009 Good to see you found a solution to your feet problem =]
kevin gilmore Posted November 3, 2009 Report Posted November 3, 2009 Those are temporary vintage feet. Still hoping that craig can get some more of the feet i really want without having to buy 5000 pieces. Weight of amp chassis 15.56 lbs...(no circuit board, or tubes or other parts) power supply would be the same plus 7.5 lbs of transformers (plus parts)
feckn_eejit Posted November 3, 2009 Report Posted November 3, 2009 Cue Justin saying it needs more holes. I anxiously await Justin's ASSessment of KG's holes (or deficiency thereof).
nattonrice Posted November 3, 2009 Report Posted November 3, 2009 Weight of amp chassis 15.56 lbs...(no circuit board, or tubes or other parts) power supply would be the same plus 7.5 lbs of transformers (plus parts) Great so my next diy project will be center supports for my desk Between this, the b22 stack and my computer the thing is like to collapse into a pile of ikea fail.
Quagor Posted November 4, 2009 Report Posted November 4, 2009 Great so my next diy project will be center supports for my desk Between this, the b22 stack and my computer the thing is like to collapse into a pile of ikea fail. Why your only looking at somewhere in the mid 20's (kg) weight wise for the t2, which really isn't bad at all... a 21" CRT monitor for example will weigh about 40kg. By the way I assume it is too late to get on board (even if only for the boards)?
kevin gilmore Posted November 4, 2009 Report Posted November 4, 2009 I think that there will be a couple extra circuit boards... Will know next week when i decide how many to buy.
kevin gilmore Posted November 6, 2009 Report Posted November 6, 2009 amplifier back panel. The amphenol power jacks can mount on the inside as shown, so you can build it and wire it and then bolt it to the back panel from the inside. Makes taking it apart if necessary a breeze (something mikhail needed to learn). And the neutrik's are in 2 pieces too... http://gilmore.chem.northwestern.edu/t2chassis13.jpg
Kerry Posted November 7, 2009 Report Posted November 7, 2009 Looking good. How are you connecting the chassis earth? Through ground or a separate connector. amplifier back panel. The amphenol power jacks can mount on the inside as shown, so you can build it and wire it and then bolt it to the back panel from the inside. Makes taking it apart if necessary a breeze (something mikhail needed to learn). And the neutrik's are in 2 pieces too... http://gilmore.chem.northwestern.edu/t2chassis13.jpg
nattonrice Posted November 7, 2009 Report Posted November 7, 2009 Looks great! What do you mean that the neutrik's are in 2 pieces?
kevin gilmore Posted November 7, 2009 Report Posted November 7, 2009 Neutrik nc3fdh connectors. Go look it up on their website. krell uses a lot of these. you solder the inside piece to the circuit board directly. Then insert thru the panel, add the outside piece, and then there is a slot for a small screwdriver that locks them together. craig also uses them on his BA. The one hole that is missing on the back panel is the hole for the ground wire which connects thru the umbilical cable to the same place on the power supply. Everything floats inside both boxes to get rid of any ground noise. There is a switch on the amp board that connects amp ground to chassis ground for those situations where it is necessary.
kevin gilmore Posted November 7, 2009 Report Posted November 7, 2009 (edited) quick pic that explains the concept http://gilmore.chem.northwestern.edu/nc3fdh.jpg Correction... There is a switch on the amp board that connects amp ground to the neutrik ground pin for those situations where it is necessary. Like using the xlr for single ended inputs. The outside of the xlr connector is connected to chassis ground. Edited November 7, 2009 by kevin gilmore
justin Posted November 7, 2009 Report Posted November 7, 2009 if mikhail had used those, which half would have fallen off?
nattonrice Posted November 7, 2009 Report Posted November 7, 2009 Naivety in action there; I had no idea they existed =P if mikhail had used those, which half would have fallen off? Both O.o
spritzer Posted November 7, 2009 Author Report Posted November 7, 2009 if mikhail had used those, which half would have fallen off? It would have exploded...
nattonrice Posted November 7, 2009 Report Posted November 7, 2009 It takes a lot of skill to make a xlr jack explode.
spritzer Posted November 7, 2009 Author Report Posted November 7, 2009 True but I really believe Mikhail would be up for the job.
kevin gilmore Posted November 9, 2009 Report Posted November 9, 2009 board files for the amplifier board just shipped to pcbnet to be produced. The amp board should be $93.32 + tax (i'm in illinois, no way around this) +shipping. Still have a bit of work to do on the power supply board.
Quagor Posted November 14, 2009 Report Posted November 14, 2009 I reread my earlier post and noticed it was rather unclear, By the way, I assume it is too late to get on board (even if only for the boards)? Should read, I assume it is too late to participate even if I'm more than willing to take a non complete set of spares. Also $93.32 is surprisingly cheap which is rather nice compared to the 150-200 dollars a board quoted at the start of the thread.
nattonrice Posted November 14, 2009 Report Posted November 14, 2009 That is just for the amp board sans shipping. After getting both boards to your door it will prob be about 250ish for the board set like Kevin said earlier in the thread.
Quagor Posted November 14, 2009 Report Posted November 14, 2009 That is just for the amp board sans shipping. After getting both boards to your door it will prob be about 250ish for the board set like Kevin said earlier in the thread. Was it not per board? (not board set). Yeah, scratch that. Just did a bit of estimating on Imagineering and $150 per board is not at all out of the question. That would put me firmly out of the "I'll pitch in to help" camp. A $150 board I'll never use is not something I can do right now. At least how I read the posts. Either way its far cheaper than I was expecting. Edit: The circuit boards are going to be $267 for the board set (one of each) if i buy 10 sets. Looks like I just failed at reading.
