Gentlemen, I've just read the first 70 pages of this thread.
Beside the reading pleasure (yeah, I'm getting as crazy as you all, finding that reading technical things is enjoyable), I saw something extremely special...
This project is something I haven't seen before, and my English is too short to put proper words on it.
Dr Gilmore, you have been quite busy doing this between bottle washing.
Congrats to everyone that finished their T2.
Edited by G600
  • 4 weeks later...
The on-semi announcement kind of throws a wrench in the works for the newer version of the T2 doesn't it?
That being said, I have a few pieces of the mpsw06 left. Do we need to match the hfe, since it's a sub for the 3381?
We can use the Fairchild parts but I don't relish the thought of having to do the matching for a couple of T2's.  I might have a line on some 2SC3381's so there will probably be two layouts.
To add to your pleasure I will probably do a third version.  It will be tailored to the parts I can buy in bulk but leaning more towards the original design.  I've been stocking up on parts just in case I build some so a special version is in order.
  On 12/3/2014 at 2:35 PM, nikongod said:
All of them.
Because d-_-b
It's kind of an issue Ari, if I have boards lying around I somehow always end up populating them. It's part of the reason I have shied away from p2p work, aside from incompetence.
I started looking at the newer board files, do they have to have offboarded heatsinks? I got the impression that the original footprint was to match with aesthetics of the amplifier board.
I was looking for one-off deals and found this for fabbing the boards. There's enough area to do a run of the original, so that should encompass all of the current variations that currently exist. Plus black is free, which is of course priceless
Also some leftover space to add some boards if you were so inclined, was going to try to see if I could shove a dynalo in there
Does anyone see issues using 1oz copper for this?
There are also some more recent options such as PCBway which has criminally low prices, but I can't justify using this without forming a group
If you want to split the cost I wouldn't mind taking an original board set (with the old sand like the 2sc3675's). Is that quote for the shrunk (400mm depth) boards?
I am not sure it would. In the BH I can say it sounds much better to my ears* but didn't really measure any different.
Edit: compared to the CCS that the BHSE uses. I still prefer the original CCS.
Edited by luvdunhill
