Well, based on Kevin's quote we'd pay no more than $3 per socket more through PCX and really if anyone bitches about $24 ($3 x 8 sockets) on a project likely to cost in the thousands to build I'm likely to :basement: someone.
CMC--Teflon Tube socket
the last time i looked, the prices at pcx were $21 each...
At $19 each the group buy turns into more trouble than it is worth.
You can buy them from ebay too, 2 for about $32
I already have enough for 2 amplifiers...
4 of each of the sockets are required... 4 x 6ca7 4 x 6dj8
Edited by kevin gilmore
If there's enough folks in the US to get over 25 sockets it may still be worth it to group buy through PCX and again, I'm willing to help with this if people are interested.
http://gilmore.chem.northwestern.edu/t2chassis9.jpg
tomorrow i'll drill holes in the fake circuit board and mount the sockets
and see what that is going to look like.
So far i'm very happy. It really does not need more ventilation holes as all
the hot stuff is on the heatsink. May add some more holes to make it look
purdy... 32 machine minutes to do this including the edge...
i disagree i think you'll be surprised how big a difference there is once you add the top/bottom covers. i'd put as much open space in them as possible
But milled holes are so much prettier... .005 countersink...
Fine... More Holez...
Shop is getting a brand new laser cutter next week. Evidently it can cut at the
rate of 1 inch per second in .5 inch material. Much faster in the .125 stuff i'm using.
So i think one more circle of holes around each tube, then ... well i don't know
yet, creativity is zero at the moment... Quite exhausted... And stinking of that
milky white water based machining lubrication crap.
What about T2 square in the middle of the plate? Ohh and laser FTW!!
Laser will leave an entry/exit mark but should be fine if the piece is going to be painted or powdercoated
I think the T2 will be on the front panel with an understated look...
Otherwise it ends up looking like the overblown crap from my friend in skokie...
What i want to see is what the surface looks like from the high pressure water
cutting machines.
In the end i will probably still machine it... Nothing seems to beat the perfect
edge of a sharp carbide bit.
Still have no idea whether i'm going to anodize or power coat... Have a couple of small pieces
of the extrusion to send out for testing... Found a company that will polish all the pieces, they
do a lot of work for Fermilab... Relatively cheap too, but they just polish stuff, they don't do
the rest of it.
Kevin, what would one use to get the Jeff Rowland ripple effect? I think that's a cool look, just not sure how one would do it...
Me not being clear as usual. :palm: What I meant to say was a cluster of holes with T2 squared inside that cluster, made with smaller or larger sized holes.
cutting machines.
Well I can tell you what those machines do to cakes, the most perfect cut one can imagine with almost no water residue. :)
the rest of it.
Either way works for me. :)
Thanks for that Nate. I'm getting a quote from the TKD factory on both the 2500 and 600 series. It's not like we couldn't use a small 4-gang pot... :)
