Just measured my output voltage, and it was slightly out of balance:
(which corresponds to R-channel having a very small weight)
L+ 100%
L- 110%
R+105%
R- 110%
(Switching input channels produces same result, so it wasnt the signal source)
What primarily controls the gain? EL34? K216?, ecc88?
Gilmore's Corollary of Murphy's Law states that the counterfeit MOSFET from eBay which saved $5 will take $350 of hard-to-find parts with it.
Edited by Milosz
I lost at least a hundred dollars to counterfeit parts. Also, 2SC3675 is 6.97 per piece at bdent for 30 pieces right now. That's over 200 dollars for just that part, and more if you want spares to do repairs. It's getting harder and harder for people to build this thing nowadays.
IIRC the J79 (or K216) was the most expensive part when this thread was started a few years ago. Ironically it has not changed in price much.
We should have cleared out Sanyo's entire stock of 3675 when they were $.50 each instead of being 'practical' and only taking 50-100 each per person tongue.png
A little update on the futurlec C3675 devices.
They were sent from bangkok, delivered by Deutsche Post, and invoiced from Australia. That's interesting.
http://i.imgur.com/AbRHB.jpg
okay... bent legs, like the ones I saw in my local hobby shop. Fair enough. Anyways, from left to right: utsource, futurlec, and bdent
http://i.imgur.com/PLmj1h.jpg
straighten out the leads. All of them look similar. The futurlec devices have similar letterings to the utsource devices.
Measured the Vbr and hFe using the handy measurement tool recommended by KG:
voltage breakdown:
utsource 1057V
futurlec 1252V
bdent 1117V
hFe:
utsource 46 @ 10uA(Ib)
futurlec 23 @ 10uA(Ib)
bdent 41 @ 10uA(Ib)
Hmm... So the hFe of the futurlec devices is a bit low. However, I am not testing at database conditions, so that might be the cause. Will have a curve tracer in 2 months time, I'll learn how to use it, and report back again.
Yes, interesting. Fake parts are real nuisance and trouble causer.
Have a look at this video clip
For those of us who don't have full facilities to check the parts including myself, can only hope that, even if all effort is put in to make sure that the build is good, can only pray that when the switch is flipped everything works. Also hopefully, it continues to work properly for a long time to come. I only have the vbr tester which is insufficient to check other important perimeters.
Edited by Victor Chew
So I was blowing these 4A rat shack fuses (had no problem with a higher quality 4A fuse that I pulled from the BA) on a T2 (blubliss DIY), and decided to hook up the wattage meter just to see what was going on. The logger can only take data once every second, so I assume the "Max Amps" and "Max Wattage" mean the max recording during that one second interval. Hopefully this will be some use.
Edited by purrin
Gotta love the inrush current. :) I think I used 3.15AT fuses up here (230V) but that is probably overkill. Mikhail used 6.3A in the ES-1 but those transformers dim the lights.
I was lucky enough to get a set of boards from lil knight. I have been trying to get all the orders ready for the hard to get parts for this amp. Right now bdent.com has all but the 2sk246gr. I found some on ebay but after reading through the thread am not sure whether they are real or fake.
A lot of the parts have gone way up in price and I understand that since most of these things are now obsolete. The current pricing from bdent is
2sa1486 $3.52
2sk216 $5.69
2sj79 $8.82
Are there better prices out there? If this is what I have to pay, okay. But if there are more reasonable prices out there I'm having a hard time finding them and knowing that the parts are real.
Thanks for any help guys.
2sa1486 $3.52
2sk216 $5.69
2sj79 $8.82
i can get way better pricing (at least, a year ago when i last ordered) on 2sk216/2sj79 but i'd be looking at ordering about 1,000 of each
