I used MCM to source some K216s and they were legit. I bought a 10 of the J79s from BDEnt. Interestingly I got 10 pairs. I was going to order some of the K216s, but then they ran out. Summer sale I think :)
On another note...
I've been playing with designing an SS front end and I've posted my first component (active batteries) in the T2 design and other circuitry thread. I'll keep my progress of this in the other thread.
For anyone interested here's the link:
I have no idea that use semis for first stage is good or bad for the sounds.
Article from MJ 1995/5 (Page 37)
“The first stage is a cascaded differential circuit that uses two 7308 tubes that are equivalent to the 6DJ8. A transistor constant current source was added to both the plate load and the cathode. The supply voltages for this differential circuit are +250V and -600V.
The reason tubes are used for the first stage is to avoid thermal related parameters. If semiconductors were used in this circuit, the junction temperature would be influenced by the current. It would be easy to unbalance the differential circuit when the current changes. However by using tubes, the temperature is already biased by heaters so regardless of changes in current, the operating parameters will be very stable. These tubes are covered by metal shielding caps.”
Picture looks correct but.............................See post #2405.
Ahhh. Thanks.
I ordered my 2SK216's from Rich-Tech Parts of B.C., they're Canadian, so it's got to be OK, eh?
We'll see.
Hmmm I think the k216 I got from bdent may be fakes... If Inu is correct about the date codes the ones I have use a date code of M, which would be that new month after december when we switch to a lunar calendar. Here is a picture:
Those are genuine Renesas devices I believe.
Yes, it is genuine Renesas FET. I am using same one in my T2.
Thanks guys that is good to know. Now I just wish I had bought more of them, I wasn't expecting them to be so hard to come by.
speaking of fakes...
WARNING TO ALL...
http://gilmore.chem....du/dsc_2288.jpg
The one on the left is real, the one on the right is fake, and breaks down at 200 volts.
birgir and i got nailed on this, about half of the ones i bought were fake, and most of
birgir's (if not all of them) are fake.
Evidently there are also 2sa1486 fakes out there, i don't have any pictures of the
fakes.
Get yourself one of these
http://www.ebay.com/...=item1c1d98666e
and test all the high voltage transistors before you put them in.
My goodness that guy has a ton of negative feedback, didn't see any concerning this device. Did you order one from him Kevin?
Edit: Nevermind, found many more sellers.
Edited by blubliss
I have had one for about 6 months now. I got it from this seller because of the combined cost with shipping and his 100% feedback.
http://myworld.ebay.com/jenny285123/&_trksid=p3984.m1439.l2754
It takes a little bit to figure out exactly how to use it, but it works pretty good for most stuff, and tests Vbr to about 1200v+
http://myworld.ebay....984.m1439.l2754
Just picked one up, would you mind posting some tips on how to use it if it is not straightforward?
