kevin gilmore Posted August 3, 2010 Report Share Posted August 3, 2010 Now i'm downright hostile. No amp bottoms... Will ship out 4 more bottoms and 4 more heatsinks today. Inu and Birgir parts will ship today. Quote Link to comment Share on other sites More sharing options...
nattonrice Posted August 3, 2010 Report Share Posted August 3, 2010 Just like all UPS fuck ups, you'll write them off only to have it all turn up 2 months later with out so much as a sorry note. Rage ensues Quote Link to comment Share on other sites More sharing options...
Fing Posted August 3, 2010 Report Share Posted August 3, 2010 I would be more than interested! Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted August 3, 2010 Report Share Posted August 3, 2010 (edited) Found the four heatsinks in someone elses delivery... Can't find the 4 amp bottoms yet, so 4 more will be at the anodizer later today... You would think it would be simple enough to keep order A seperate from order B... Especially when they were different colors... And yes, all of my stuff is the same color. Edited August 3, 2010 by kevin gilmore Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 3, 2010 Report Share Posted August 3, 2010 Just like all UPS fuck ups, you'll write them off only to have it all turn up 2 months later with out so much as a sorry note. Rage ensues Don't start me on a carrier rant - they are all as bad as each other. The Tekscopes mailing list is a regular litany of test gear bought off eBay that arrives looking like it has been thrown out the back of a moving truck (maybe it has). Or two identically labelled identical parcels I shipped to the La Palma observatory. One arrived OK, and the other was returned - somehow separated and the sender's address had been interpreted as the "to" address by some blithering idiot. Or the piece of gear coming from Ca to the UK. Never arrived. 8 weeks later it got back to the sender - our idiot parcels service Parcel Force (or Parcel Farce as it is known) failed to deliver the correctly labelled package, failed to leave a note three times (they are required to make three attempts, and leave a card if there is no answer), and then returned to sender using the cheapest and slowest method (pony ). And that is just for starters.... Quote Link to comment Share on other sites More sharing options...
digger945 Posted August 3, 2010 Report Share Posted August 3, 2010 I would like to compensate you for your trouble if the parts are not found or whatever. I would be interested in the heatsinks, not the T2 chassis though. Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted August 3, 2010 Report Share Posted August 3, 2010 (edited) I have a receipt from the anodizer for accepting 16 heatsinks and 16 tops/bottoms and 16 fronts/backs So he will be paying for the missing stuff. Or he has to find the stuff. I really don't care. justin might have some more of the heatsink. Otherwise i have just enough heatsinks to match the fronts and backs. If justin does another batch of heatsink there will be plenty more. This time i will order extra. If people want me to ship what i have now, i can do that, the amp works fine without its bottom. That way you can start assembling now. All you need to do assembly is the fronts/backs,heatsinks and power supply bottom. Edited August 3, 2010 by kevin gilmore Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 3, 2010 Report Share Posted August 3, 2010 I have a receipt from the anodizer for accepting 16 heatsinks and 16 tops/bottoms and 16 fronts/backs So he will be paying for the missing stuff. Or he has to find the stuff. I really don't care. Anodisers never fail to amaze me. I use MetroPlating in Uxbridge Metro Plating - Sulphuric - Chromic & Hard Anodising - Alochrom - Aluminium Finishing Absolutely first rate, but I always drop off and collect, and check each piece. Good they are, very good, - but it is absolute chaos in there, a real bloody mess. This seems to be the standard way of working - I've visited several over the years. I'm lucky that I'm only about an hour's drive from Metro; god knows what would happen if they shipped. If people want me to ship what i have now, i can do that The only thing that would worry me about that is the delta cost of sending the final bits across the pond. How long will the replacements for the lost bits take? Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted August 3, 2010 Report Share Posted August 3, 2010 Kevin: I'm curious, why do you have to use a separate vendor for polishing? Is this prep work not something the anodizer can usually take care of? Quote Link to comment Share on other sites More sharing options...
Icarium Posted August 3, 2010 Report Share Posted August 3, 2010 Jesus. Good luck and hopefully sorting that isn't too painful for you :/ Yeah I'm down to do whatever is easier for you as well Kevin! Yay chassis! Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted August 3, 2010 Report Share Posted August 3, 2010 For whatever reason the really good polishers don't do anodizing, and vice versa. This all has to be local, and both of these companies are real good at what they do. Very different machining and processes. Really don't want to go into the anodizing company ever again. Boiling vats of boric acid. Lots of chemicals that just can't possibly be good for you. The fihisher for the flat parts has this absolutely huge sanding/buffing thing. Really neat, and something else i would rather not mess with. The heatsinks are polished by hand. Hopefully another 10 days or less to anodize the bottom panels. I think people should wait until its done, and ship in one box. But for me personally i would take it in two shipments just to get working on it that much quicker. Then soon, like next week i will ship the next batch for polishing and finishing. Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 3, 2010 Report Share Posted August 3, 2010 I think people should wait until its done, and ship in one box. Since I'm still waiting for mains transformers, I'll hang on until it is complete. Give my regards to your anodisers Quote Link to comment Share on other sites More sharing options...
struts Posted August 3, 2010 Report Share Posted August 3, 2010 I think people should wait until its done, and ship in one box. Jeez what a PITA. Having spent virtually all day on the phone to my insurance company (my wife backed into a rock, thanks honey!) I can certainly empathize regarding companies that needlessly raise your blood pressure. I'll hang on too. I am anyways still waiting for my RK50, 3381s backordered at Dalbani and the relay backordered at Mouser. Quote Link to comment Share on other sites More sharing options...
justin Posted August 3, 2010 Report Share Posted August 3, 2010 i have 3381's listed at fleabay. they are BL, not GR, does this matter? Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 3, 2010 Report Share Posted August 3, 2010 i have 3381's listed at fleabay. they are BL, not GR, does this matter? I think Inu had some initial problems getting the 740V batteries to lock, even after screening his BL's for low beta (at the high end of the GR range). Could be misremembering - so check back in the thread. Quote Link to comment Share on other sites More sharing options...
struts Posted August 3, 2010 Report Share Posted August 3, 2010 I think Inu had some initial problems getting the 740V batteries to lock, even after screening his BL's for low beta (at the high end of the GR range). Could be misremembering - so check back in the thread. Those were the 2SK246s. Don't know if the 3381s are equally critical. Anyone? Quote Link to comment Share on other sites More sharing options...
Nebby Posted August 3, 2010 Report Share Posted August 3, 2010 I would like to compensate you for your trouble if the parts are not found or whatever. I would be interested in the heatsinks, not the T2 chassis though. I would also be interested in the heatsinks alone Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 3, 2010 Report Share Posted August 3, 2010 Those were the 2SK246s. Don't know if the 3381s are equally critical. Anyone? Thanks for straightening that out! I dunno about the 3381's. But they all seems to be used as simple current mirrors, so probably not critical. Quote Link to comment Share on other sites More sharing options...
Inu Posted August 3, 2010 Report Share Posted August 3, 2010 i have 3381's listed at fleabay. they are BL, not GR, does this matter? I am using 3381-BL Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted August 3, 2010 Report Share Posted August 3, 2010 Replacement parts delivered to anodizer. Going to have some high power liquid refreshment and then measure my BP. Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 3, 2010 Report Share Posted August 3, 2010 Replacement parts delivered to anodizer. Well done sir! Going to have some high power liquid refreshment and then measure my BP. Bet that was what Tony Hayward said Quote Link to comment Share on other sites More sharing options...
nattonrice Posted August 3, 2010 Report Share Posted August 3, 2010 Wow you moved quick on that. I hope the high powered refreshment did it's job =) Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted August 4, 2010 Report Share Posted August 4, 2010 I never noticed this before, but there is a REF102C part that is even more improved over the B version. Perhaps a new part, I'm not sure. Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted August 4, 2010 Report Share Posted August 4, 2010 .1% on the power supply is more than sufficient, but hey go for the better part. In other news the anodizer found the 4 missing panels. That he never anodized... Quote Link to comment Share on other sites More sharing options...
justin Posted August 4, 2010 Report Share Posted August 4, 2010 .1% on the power supply is more than sufficient, but hey go for the better part. In other news the anodizer found the 4 missing panels. That he never anodized... who wants mismatched purple and black sets?? Quote Link to comment Share on other sites More sharing options...
