That looks fantastic Inu! Can someone explain to an idiot about the TRS jack though?
It's the panel bearing for the shaft extension kit, looks a lot like the front a Neutrik jack so the mistake is understandable. :)
Based on the assumption that KG's knob is 1/4" (waits for the inevitible comments...), since the panel bearing specced is for 1/4" rod, I need to transition from 1/4" rod to 6mm shaft for the DACT.
I've therefore bought a 6mm shaft coupler (Rapid Electronics), and will ream half the length out to 1/4". I could of course turn the 1/4" rod down to 6mm at one end, if I had a lathe (but I don't), so adapting the hole size in a coupler is much easier.
Ah, that makes perfect sense. I couldn't for the life of me figure out how a TRS jack was going to work on an electrostatic amp. So the shaft goes into the bearing and back to the attenuator, gets locked down into the attenuator, and then the knob goes onto the shaft end? Very nice setup, wasn't aware they worked that way.
I need to order another 450V 680uF.
Won’t fit if height is 50m/m, need 45m/m. :palm:
The edge of front panel touches the head of capacitors.
Panasonic 450V 680uF (35mm x 45mm) is out of stock... :palm:
Craig,
How about your EPCOS caps?
Craig,
Maximum EPCOS height above the board is 47mm. How about slightly shorter spacers? Specced ones are half inch, so would 10mm work better?
Well pretty close. The shaft is machined single piece out of the knob material. Then there is a coupling right behind that
to the extension shaft, and another coupling to the pot. Depending on which pot you get, the second coupling needs
to be a different diameter on the pot end. The picture posted previously showed this.
http://gilmore.chem.northwestern.edu/t2chassis29.jpg
I wondered what the second coupling was - that is a really neat design, and keeps visible shaft grub screws completely out of the equation!
With the fancy Alps, you have to go *up* from 1/4" to 8mm, whereas with the DACT you need to go "down* to 6mm.
Scratch the 10mm comment - the board height is fixed by the heatsink bracket position.
The space between PCB and edge is 49m/m so your EPCOS are safe.:D
I uploaded more pics.
Here is a quick snapshot I took before I packaged it all up again for storage.
The heatsinks look great, beyond great even but the other panels are a bit flat. Also notice the small marks on each end of the panels which go right through the finish.
Yeah, one of the Stax jacks is messed up but I'm too tired to take a picture of it.
Not sure what happened with the stax jack. it may have been one of the first 3 that i did, and maybe
i machined it a bit too fast. From now on i will test the fit before i ship any more stax jacks.
The problem with teflon is that it likes to get out of the way of the end mills as it is being machined.
Maybe i bumped the speed knob...
It will be replaced. When i send birgir his "custom pure titanium" knob. :D
Hopefully the material for that will be in the end of this week.
Yep we are at the silly stage...
Need to find a 2 inch cube of aged lignum vitae.
I don't believe the moisture content for one second. I have lots of lignum vitae here, after
you take the wax off, it usually takes about 10 years for it to be usable and it shrinks
well over 10%. My wonderful hardwoods store went out of business last year, so no
more of the exotic stuff for me till i find some place else where i can look at the stuff first.
I always test the AC out of all transformers first.
And unloaded power draw checking for shorted turns
did you test the transformers with a load as well (rated maximum load or actual load?)
Also, thanks for the transformer specs. Could you also give us the maximum gauge that each lead can be (so, pad diameter) and the maximum lead length we need?
One additional thing that is worth mentioning to a transformer manufacturer is that some of the windings float at high DC. Specifically the heater windings to the EL34's (-500V), and two of the HT transformer windings are referenced to -560V or -500V. So those windings in particular need an insulation barrier - just overlaying one secondary over another probably won't work (it *should* in principle, because winding wire is good for more than that - but not if any insulation is compromised through nicks during winding, or just thinned because of winding pressure).
I tested at 10% over maximum rated load (which is dc because its pure class A)
out of the power supply with a stack of resistors.
The leads out of the high voltage transformers are 14 inches long.
And yes you have to tell them to do 600 vac wire for all of the transformer windings.
Which SumR does anyway i think.
Register a new account
Sign in
