Never got off the semi... On thursday its coming on a truck with a lift gate.
Will drop it in the driveway, then i get to take the boxes inside myself.
Looks like all the metal pieces together will end up about 40 lbs per amp.
Well all the resistors and caps showed up today.
I'm glad to report that all the parts for the amp board are the sizes they
are supposed to be, and the holes are the right diameter. Neutrik connector
really was the right diameter because they are flat blades not round.
Will check the power supply board later today.
Soon this project is going to take over the house. :D
Anyone know where craig gets his rubber/metal feet with the #10 screws??
I kind of like those, as i plan on 4 of them, not 3 because the thing is going
to be so heavy.
What version of the BOM did you use? Vishay resistors or my rather nutty collection from PCX? :P
to be so heavy.
Those do look nice and good show for not using cones. I hate those...
Actually i was thinking of hiring a couple of has been fanboys...
Afterall, they have nothing else to do now...
Have pretty firm pricing on the heatsinks with machining, and the angle
pieces, will post soon.
If it sounds as projected there will be a lot of Fan Boys...
Actually i was thinking that tuberoller would be the best to supply ventilation...
Although i really had two other "HAS BEEN" fat fan boys in mind :D
There are definitely some current fanboys that might work... Tomato comes to
mind.
So as we all know the amphenol stax connectors are less than ideal, and the
real stax ones are generally unobtainable.
so i got these guys to sell me just the pins from these sockets
CMC--Teflon Tube socket
and i evidently got the measurements right on the first try. (well to .0001 anyway)
http://gilmore.chem.northwestern.edu/staxc1.jpg
http://gilmore.chem.northwestern.edu/staxc2.jpg
Was thinking of a dual stax connector made out of some crazy hard
wood.
Need to find the electrical impedance of hardwoods...
Anyone know??
If i can get some more machine time this week i should have a finished amp chassis
by saturday. :D
Register a new account
Sign in
