Ok, so we all know that I'm DACrazy. I recently purchased a Dodson DA-217 MK II D, which is a vintage '90s DAC. I have yet to see a bad review of the unit, but there also is not a tremendous amount written about it. Also, the designer is dead.
Regardless, after 1 hour, I can say that this DAC sounds pretty damn good. As many of you know, I have been very much in love with my ECD-1. Well, the Dodson may be better. I have a lot more listening to do, and I will post some internals here. But I think this is a pretty promising find.
Oh, and I'm fully willing to admit this could be placebo...
  • Replies 57
Hello. My name is Josep, and me too :palm:
My last (better say 'more recent') buy has been a Pass Labs D1 unit, 90s too but a bit later, and -fortunately- its father/s are still alive (Wayne Colburn and Nelson Pass).
Good. Waiting for those stripped nudity pics :rolleyes:
^Oh, are you Josep on HF? If so, there is about nothing to indicate you're the same guy. ;)
Yeps yes I am ;D. Showing similar interests hehe ;)
When I joined HF long ago I was so naif as to use my own name (and there were not much members so the nick was free...).
The Dodson dude being dead really does ring a bell from when I was researching the DA-218 a couple of years ago...
Just to be a douchebag -- what's the difference between a DA-217 MKII D and a DA-218?
Some internals. I'd appreciate it if you guys could help me understand what's going on inside.
The big yellow things are called "tubes". Probably the blue ones too.
The way the BB 1704 DACs are mounted is, to say the least, curious. When seeing them on daughter boards on thinks of a 'pop' replacament were there have been pcm63, but not here.
Also, how the I out goes to the first opamp (many good 627 in sight btw) with a Caddock resistor for I to V is... curious too?
A bit too (bad) DIY to my taste.
Now I am curious to see what's inside the metal box (input receiver and digital filter).
whoa, PCM1704! I see only two 1704s though, are there two more? Like maybe on the underside of each of those "daughterboards"? I'd be disappointed if the balanced output was achieved through phase inversion.
The four big caps makes one think there is a real balanced source, but... just two 1704 with its obvious IV resistor makes me think this is not a "true" balanced source.
After I discovered the popular Benchmarck DAC1 is'nt either, no surprises for me...
The pin on the 1704 lifted going directly to the opamp and caddok i/v feedback
resistor is done that way to avoid any possible extra capacitance on the dac
output wire. I have seen lots of high impedance circuits built this way for
a minimum of interactions from circuit board materials. Not really a bad thing.
There were regular dip versions of the 1704 available that probably plugged
in directly into the socket, but still the one wire would have been lifted and
soldered the same way. Definitely not enough parts to be balanced with
4 dacs. After the I/V conversion is a 4 pole active filter with a pair of 627's.
Then the 712 as the phase inverter, and another pair of 627's as the
output amplifiers. Standard sort of thing.
Open up the RF can and lets see how good the build quality really is. The metal
can just pulls up.
For its time it is built reasonable. Definitely not crummy diy. But not 4 layer
shielded circuit board either.
Thanks Kevin. The metal can is proving to be a bit more difficult to remove than I anticipated. I think it may be soldered at one point. I'll post a pic. I'm kind of disappointed that it doesn't have 4 1704s. I was under the impression that it did. Still sounds pretty good, though.
Register a new account
Sign in
