TheSloth Posted July 17, 2009 Report Posted July 17, 2009 Another friend had the 988, not sure if they came from UK or China, but those sounded great and had no issues. The only "problem" with those is the frame not being stiff enough to keep the panel steady, so at high SPLs they tend to comb and make sound a bit undefined and diffuse. This is improved on the newer series using a more rigid frame Absolutely, but it should be noted that the 63's are significantly worse than the 988's in respect to stiffness. I don't know if it's the case in America, but in the EU the 2905's come with a metal weight to attach to the underside of the frame, just to make it harder to topple over and comply with some ridiculous EU regulation. That bar itself, if you are really hard core and have the placement absolutely sorted, can be screwed into the floor directly. I suspect that combined with the tensions strut on the back pretty much solves the rigidity problems for good. Quote
Torpedo Posted July 17, 2009 Report Posted July 17, 2009 Yes indeed, the newer 2xxx series, building quality issues apart, are an improvement over the 9xx. However to my ears they are still handicapped dynamically. It's quite clear that they can't go any louder than 95-98 dB, so when listening classical music decently recorded/produced keeping dynamic swings of 50dB or more, by pumping up the volume you can hear soft sounds louder, but the loud ones can't go higher, which I find a personal deal breaker. That's not and issue with average recordings and pop, rock or jazz, which is compressed at mastering. Quote
swt61 Posted July 17, 2009 Report Posted July 17, 2009 I know that but within that time window, clicking the edit button just gives me a spinning thing and nothing else happens. I guess you'd better get it right the first time then. Quote
guzziguy Posted July 17, 2009 Report Posted July 17, 2009 I know that but within that time window, clicking the edit button just gives me a spinning thing and nothing else happens. Maybe your browser thinks it's on another site? Quote
Duggeh Posted July 17, 2009 Author Report Posted July 17, 2009 Won't be able to audition for about a week. Speakers are still at the sellers house and he's not in atm. Much reading seems to point that the Quad 405, even pimped out, won't cut the mustard as far as power is concerned. I wonder if Quad can turn a regular 909 into a 909 Mono if you send them back... Quote
spritzer Posted July 17, 2009 Report Posted July 17, 2009 If the 909 mono's are just bridged stereo amps then they should be able to do it. Quote
TheSloth Posted July 17, 2009 Report Posted July 17, 2009 Won't be able to audition for about a week. Speakers are still at the sellers house and he's not in atm. Much reading seems to point that the Quad 405, even pimped out, won't cut the mustard as far as power is concerned. To drive what, 63's? I thought pimping out the 405 increased the max. current output, and there's certainly enough voltage to set of the protection circuit... Quote
Duggeh Posted July 17, 2009 Author Report Posted July 17, 2009 To drive the Soundlabs. For them 100watts is a recommended minimum, and from a 405, 115 is the best you can look to get. The 909 mono is 300watts (the 909 stereo is 140 per channel) and is unconditionally stable as Quad factor for their own electrostatics. It has the bonus of being quite reasonably priced and available used and catering to my dads decates long Quad bias. Quote
Duggeh Posted July 17, 2009 Author Report Posted July 17, 2009 If the 909 mono's are just bridged stereo amps then they should be able to do it. That's my understanding from what I have read. It would be the expense of any replacement back panel, added onto the "minimum service charge" that would make things start to stack up. Quote
Torpedo Posted July 18, 2009 Report Posted July 18, 2009 Doug, first decide if the speakers are to your liking, then see how they fit your room. Just then, start hunting the power amp. Those speakers, as long as they sound like the Apogees and other planars, will reveal you too much of your upfront components. More than raw power, I'd be concerned about sound quality. Bridged to mono amps aren't exactly a candy in my experience. Quote
spritzer Posted July 18, 2009 Report Posted July 18, 2009 Yup, find the speaker you want and build from there. Quote
swt61 Posted July 18, 2009 Report Posted July 18, 2009 Duggeh, you might also consider finding a used pair of NAD 2200 power amps. The 2200 in bridged mode is rated at 400 wpc. I used a pair of them to drive my old ESS AMT 1D speakers. Those are the ones with the big ass Heil transformer on top, and the 2200's were stable as a rock, with a shitload of power. They can be had quite cheap now. If an amp that old makes you nervous, there's the Emotiva route... Emotiva Audio XPA-2 Two Channel Power Amplifier Quote
Duggeh Posted July 18, 2009 Author Report Posted July 18, 2009 Those Emotiva amps look serious business for the money. Yeah speaker first, true that. I just like to sook up the gear pr0n. Quote
Duggeh Posted July 29, 2009 Author Report Posted July 29, 2009 Went along this afternoon for a listen. 2 MacIntosh 500 watt monoblocks (the power in a Quote
deepak Posted July 30, 2009 Report Posted July 30, 2009 Went along this afternoon for a listen. 2 MacIntosh 500 watt monoblocks (the power in a Quote
spritzer Posted July 30, 2009 Report Posted July 30, 2009 Very power hungry to say the least since they are so... ehhh... small. A nice ESL63 would be a very nice option but do get them off the floor. Despite what Quad says, the new speakers are just redressed 63's with some extra panels on the 9 models. They must have asked Mikhail for help since MOAR!!! is always better... Quote
Duggeh Posted July 31, 2009 Author Report Posted July 31, 2009 (edited) Decided to give them a go anyway. In place and Bryston photos not taken. Sounded much nicer in the room once we had shuffled them around a bit than they did in the demo room at the shop. Bi-amped them with the NAD on the treble and the Quad on the bass. Sounded pretty nice until you turned the volume up into drive and then it went all bad. Additionally, the amps were running hot. The Quad would have certainly overheated and failed if we had kept it up. The shop also loaned us a Bryston 300w/ch. Which did a considerably more admirable job. However, the crux is that while they sound nicer than the Quad 21L. (They sound bloody lovely to my ears). It is very difficult to justify them sounding ten times better at ten times the cost, before amps are added in. I'll chat with dad about it tomo. I think that dad had some secret dream that 'stats would offer him a presentation which was close to that of live music and finds himself dissapointed on that front. And they do pull the hairs on your arms outward. Edited July 31, 2009 by Duggeh Quote
deepak Posted July 31, 2009 Report Posted July 31, 2009 Were they still bass light with a tiny sweet spot in your own setup? The scale picture with your dad next to them is pretty cool. Quote
jinp6301 Posted July 31, 2009 Report Posted July 31, 2009 The scale picture with the quads is pretty funny Quote
Duggeh Posted July 31, 2009 Author Report Posted July 31, 2009 Were they still bass light with a tiny sweet spot in your own setup? The scale picture with your dad next to them is pretty cool. No, proper room filling low end, with a good bit of whack. Got too much with the bass on +3dB. Very different to the 21L low end though. Sweet spot still narrow but not microscopic. Took a bit of experimentation with the toe-in. They were firing straight on in the shop and were further apart too. Quote
spritzer Posted July 31, 2009 Report Posted July 31, 2009 Those are some proper, manly speakers which make amps run and hide. Quote
Duggeh Posted July 31, 2009 Author Report Posted July 31, 2009 They only work with smoke powered amps, and once the smoke gets out of the case, the speakers stop making sound. Quote
aerius Posted August 1, 2009 Report Posted August 1, 2009 Your room isn't nearly as big as I imagined it to be, it slipped my mind that houses & room over here in North America are generally far larger than those in the UK, so when I read "large room" I was thinking of something around twice the size of the room depicted in your photos. This opens up a lot of possibilities, the Living Voice Avatar is back in the game, to me it's a Quad ESL-57 with a slightly warmer balance which can play a fair bit louder. It's also pretty efficient & easy to drive, 30-50W is likely all you'll ever need. You could likely get away with ESL-63's as well, though volume might be a tad limited. Quote
