fordgtlover Posted July 12, 2009 Report Posted July 12, 2009 I stumbled across a device called the 'Musiland Monitor USD 01' mentioned on another forum recently. They are listed on ebay for $65
yoginasser Posted July 12, 2009 Author Report Posted July 12, 2009 I stumbled across a device called the 'Musiland Monitor USD 01' mentioned on another forum recently. They are listed on ebay for $65 That is a very interesting tip!I typed in a search for Musiland and found this 01 US model that has RCA analog out also so I can go straight to my preamp with it:) Does anyone have any feedback on these? Thanks fordgtlover.
yoginasser Posted July 12, 2009 Author Report Posted July 12, 2009 Here is some info from "cougHF!" about the Musiland USD 01.
Azazel Posted July 12, 2009 Report Posted July 12, 2009 I had an Audiotrak Prodigy Cube, and it died. Worked well before that though. Yups... What happened exactly and how was your system setup? Thanks
Beefy Posted July 12, 2009 Report Posted July 12, 2009 I stumbled across a device called the 'Musiland Monitor USD 01' mentioned on another forum recently. They are listed on ebay for $65 Looks like a neat alternative to the M-Audio. Thanks Rob From the thread over there, with Foobar it seems to utilise ASIO and automatically adjust output sample rate depending on the sample of the file - bit perfect passthrough from USB to RCA, BNC and TOSLINK. This might be a good solution for me...... I can just add a second TOSLINK module to my Buffalo instead of adding a USB module. As a bonus, I don't have to worry about any potential grounding issues.
