yoginasser Posted July 11, 2009 Report Posted July 11, 2009 I was told that the Bel Canto USB Link 24/96 was made to allow 24/96 type files to be put out via the computers USB and received via the coax of their USB 24/96 DAC so that people could overcome the limitations of their (and most DACs USBs) to receive anything over 16/44.1 , I was impressed that someone could spend so much money on their DAC and still not have a simple solution for this issue without blowing an extra $500.Before looking into this I just thought that if a USB DAC said 24/96 then that's what you would be getting via the USB.If I'm not mistaken Wavelength DACs deal with this issue without the use of a USB to coax converter just over the USB,does anyone here know if there is a cheap DAC that can achieve this on a budget of $200 or less? Thanks in advance for any help on this. Quote
Hopstretch Posted July 11, 2009 Report Posted July 11, 2009 (edited) E-MU 0404 M-Audio Transit Edited July 11, 2009 by Hopstretch Quote
yoginasser Posted July 11, 2009 Author Report Posted July 11, 2009 E-MU 0404 M-Audio Transit Thanks for those suggestions. The 0404 may be the closest thing to what I'm looking for but some have reported issues with vista (and some have reported that they have had no issues with even vista 64),Any idea if any of the cheapy DACs off of fLeBay (Zero or Zhaolu ) would deliver?I'm not really looking for a soundcard or interface solution,just a stand alone DAC that can accept USB at 24/96. Quote
Icarium Posted July 11, 2009 Report Posted July 11, 2009 Yup emu 0404 usb... i wouldn't bother with the rest. I have no problems in vista64 Quote
Azazel Posted July 11, 2009 Report Posted July 11, 2009 Audiotrak Prodigy Cube: around $90, no drivers needed for 24/96 on XP/Vista/MacOS. Quote
Cankin Posted July 11, 2009 Report Posted July 11, 2009 I believe 0202 USB is 24/96 too but at even cheaper price point? Quote
jinp6301 Posted July 11, 2009 Report Posted July 11, 2009 M-Audio Audiophile USB should do 24/96 iirc Quote
Beefy Posted July 11, 2009 Report Posted July 11, 2009 This is something I have always been curious and annoyed at...... I can absolutely see the point in striving for a 24/96 USB transport if you have 24/96 source material. But if you are like the vast majority of us just running CD audio at 16/44.1 ripped to FLAC, then what is the point of using 24/96 from the PC? It means you are upsampling in software, giving your PC more to do in real time, and sending large amounts of unnecessary data over USB - all of which I would argue would significantly amplify the potential for audible jitter. Surely it is better to leave the audio in its native format, let the DAC do any upsampling, and minimise the amount of data that needs to be sent? Or is there something I am oversimplifying here? Quote
deepak Posted July 11, 2009 Report Posted July 11, 2009 Some audiophile websites sell high res downloads in 24/96. Quote
justin Posted July 11, 2009 Report Posted July 11, 2009 This is something I have always been curious and annoyed at...... I can absolutely see the point in striving for a 24/96 USB transport if you have 24/96 source material. But if you are like the vast majority of us just running CD audio at 16/44.1 ripped to FLAC, then what is the point of using 24/96 from the PC? It means you are upsampling in software, giving your PC more to do in real time, and sending large amounts of unnecessary data over USB - all of which I would argue would significantly amplify the potential for audible jitter. Surely it is better to leave the audio in its native format, let the DAC do any upsampling, and minimise the amount of data that needs to be sent? Or is there something I am oversimplifying here? It only means 24/96 is the highest supported rate. 16/44.1 will stay 16/44.1 Quote
Beefy Posted July 11, 2009 Report Posted July 11, 2009 Some audiophile websites sell high res downloads in 24/96. Oh sure, if you have a big collection of high-res material, I can understand completely. But it seems that the vast majority don't, and it is just a case of moar USB! It only means 24/96 is the highest supported rate. 16/44.1 will stay 16/44.1 I've seen quite a few cases of people installing upsampling DSPs in Foobar just so that they can use the 24/96 capabilities of their shiny new transport Quote
yoginasser Posted July 11, 2009 Author Report Posted July 11, 2009 WOW!Thanks everyone for your suggestions. I have not heard anyone mention the Audiotrak Prodigy Cube before (especially at that nice price),do you use it yourself Azazel?It would be cool if someone here has used the 0404 and the prodigy cube to see the differences in performance between the two.The 0202 was a consideration for me until I read the reviews on amazon. Beefy:There are lots of guys on the P2P torrent sites that rip their vinyl collections in 24/96 WAV/FLAC files and share them. Quote
Grahame Posted July 11, 2009 Report Posted July 11, 2009 moar bits moar better! Only if it uses an integer multiplier, otherwise what do you do with the partial bits? (Hint: if an upsample followed by downsample isn't an identity transform, what just happened?) Quote
Sherwood Posted July 11, 2009 Report Posted July 11, 2009 Beefy:There are lots of guys on the P2P torrent sites that rip their vinyl collections in 24/96 WAV/FLAC files and share them. You don't say a thing like that and not send a brother an invite, yogi. That's just not nice Quote
guzziguy Posted July 11, 2009 Report Posted July 11, 2009 Only if it uses an integer multiplier, otherwise what do you do with the partial bits? (Hint: if an upsample followed by downsample isn't an identity transform, what just happened?) Magic? Isn't it kind of like what happens when cables improve the sound? Quote
Beefy Posted July 11, 2009 Report Posted July 11, 2009 Beefy:There are lots of guys on the P2P torrent sites that rip their vinyl collections in 24/96 WAV/FLAC files and share them. Cool bananas. Just checking that you are striving for 24/96 for the right reasons. Only if it uses an integer multiplier, otherwise what do you do with the partial bits? (Hint: if an upsample followed by downsample isn't an identity transform, what just happened?) Not that I would ever use it, but I was pleasantly surprised to see the other day that the el-cheapo Philips DVD player I bought upsamples CD data to 24 bit, 88.2kHz or 176.4kHz. Quote
Augsburger Posted July 11, 2009 Report Posted July 11, 2009 By this do you mean that it plays SACDs, or that it does it's own upsampling of RB CDs in which case why wouldn't you? Quote
Beefy Posted July 11, 2009 Report Posted July 11, 2009 By this do you mean that it plays SACDs, or that it does it's own upsampling of RB CDs in which case why wouldn't you? No, just redbook. I won't use it because I'm pretty sure my Buffalo DAC will do a better job upsampling job than a CA$64 DVD player Quote
yoginasser Posted July 11, 2009 Author Report Posted July 11, 2009 You don't say a thing like that and not send a brother an invite, yogi. That's just not nice Consider an invitation always open to you good sir:dan: Cool bananas. Just checking that you are striving for 24/96 for the right reasons. This reminds me of when I was first interested in hearing a hi-rez download,so I downloaded Amadeus soundtrack (at a retarded price if I might say) and when I was listening very carefully I could hear the stylus contact with the vinyl:palm: It sounded great but it made me appreciate what the P2P community are doing and realize that their methods are no so different. I share your opinion on the upsampling BTW. Quote
Dusty Chalk Posted July 11, 2009 Report Posted July 11, 2009 It means you are upsampling in software, giving your PC more to do in real time, and sending large amounts of unnecessary data over USB - all of which I would argue would significantly amplify the potential for audible jitter.I'm not sure I see how you get to your "if A then B" B. If you're upsampling in software, then you're probably not doing anything to the driver. Large amounts of data, yes, unnecessary -- well, only if you don't care about upsampling, in which case, why are you upsampling? And now you're at 24/96, not 16/44.1, I don't see how that can amplify the potentional for audible jitter. Going from 16/44.1 to 24/96 -- in, for example, the Monarchy DIP -- inherently reduces jitter (some people use it mostly as a jitter reducer, not because they believe in upsampling).Surely it is better to leave the audio in its native format, let the DAC do any upsampling, and minimise the amount of data that needs to be sent? Or is there something I am oversimplifying here?Depends on whether you believe the DAC's upsampling algorithm is superior to whatever software you plan on using.Only if it uses an integer multiplier, otherwise what do you do with the partial bits? (Hint: if an upsample followed by downsample isn't an identity transform, what just happened?)Transmorphicalization? Quote
Currawong Posted July 12, 2009 Report Posted July 12, 2009 I had an Audiotrak Prodigy Cube, and it died. Worked well before that though. There's some good reading here about DA stuff, including up-sampling and jitter Quote
Beefy Posted July 12, 2009 Report Posted July 12, 2009 I'm not sure I see how you get to your "if A then B" B. If you're upsampling in software, then you're probably not doing anything to the driver. Large amounts of data, yes, unnecessary...... It is my understanding that jitter over USB is a problem only when the frames aren't transmitted at precise 1ms intervals. If you are processing, buffering and sending the smallest possible amount of data, there is less chance of the transmit window being missed than if you have to process, buffer and send much more data. Again, if I am oversimplifying things, I am happy to be corrected. And now you're at 24/96, not 16/44.1 You still haven't gained any extra information. For data transmission over what is possibly the least reliable medium, I personally don't see the point. Depends on whether you believe the DAC's upsampling algorithm is superior to whatever software you plan on using. True. Quote
Dusty Chalk Posted July 12, 2009 Report Posted July 12, 2009 You still haven't gained any extra information. For data transmission over what is possibly the least reliable medium...Depends what algorithm you use. If you use one that invents data, then you have, indeed, gained information. Fictitious information, agreed...as to whether or not it is superior or inferior to the input is subjective.I personally don't see the point.Well then, don't. I explained one or two possible scenarios, but if you don't want to be convinced, then I'll stop trying to teach the pig to sing. Quote
yoginasser Posted July 12, 2009 Author Report Posted July 12, 2009 I had an Audiotrak Prodigy Cube, and it died. Worked well before that though. Dying components are not high on my to buy list,thanks for sharing your experience and potentially saving me some grief. Quote
