Stupid M3 questions which I'm sure have been answered before...
The mosfet power is not symetrical, V- is ground. Am I wrong about this ?
Last project I did was stupidly populating a printed PCB (dynalo). I learnt lots about how the amp works but nothing about layout.
V- in the case of the M3 (and many other virtual ground amplifiers) depends upon your perspective, but is actually the - of the single ended power supply. It functions on this schematic as the - rail, (or V-). Ground reference is generated by a TLE2426 and is 1/2 the potential of V+ and V-. So for example if you are using a 24Vdc power supply, if you measure V- in relation to the - lead of the PSU, you would get 0V. However, if you measure it in relation to the virtual ground (SG on the schematic), you will see -12Vdc for V- (and +12Vdc for V+).
  • Replies 54
This is a question that just crossed my mind:
Would there be any advantage in powering an M3 with a o22 bypassing the railsplitter instead of just using a o11?
