Stupid M3 questions which I'm sure have been answered before...
So I am just about to start building an M3. I have several questions and was hoping to clear them up here. If these questions have already been answered feel free to point me to another site/thread. I think M3, M^3 and MMM are too short search terms but I got nada in thread titles.
My plan is to build an M3 using the AD8610s, with adjustable gain. I would like to use switch-controlled digital potentiometers for both the gain and the volume, but I haven't finished designing that circuit yet (and I also haven't found a readout LCD w/ microcontroller mini board suitable yet) so in the meantime I am going with an RK27 for volume and a gain of 8. I only have low impedance headphones. I was thinking to go a bit higher than 24V, but I am building the amp before the power supply (I have plenty of bench supplies to use in the meantime).
Summary:
AD8610s
Hardwired gain of 8 (adjustable later, no bass boost).
Maybe higher than 24V (will test with benchtop supplies)
My questions:
1) Should I go with a lower R1 value? I have ordered 680 KOhm to test with.
2) Since I am baselining a gain of 8, I was thinking about going with 15 pF C1L and C1Rs, but in the end I will (hopefully) have adjustable gain, so should I just go with 22 pF right off the bat?
3) It makes more sense to me to use C3 in conjunction with R8+ and R8-. I can't really see any benefit to adjusting the value of the two resistors. Am I missing something?
4) Some of the transistors for Q2, Q5+ and Q5- have been obsoleted. I am torn between using (mouser) 864-2n3904g/864-2n3906g combo or an 863-2n4401G/863-2n4403G combo. Is there any difference? Am I correct in that the main parameter to pay attention to is Hfe?
That's basically it. My final plans involve a relay switched input selector and digital volume/gain with LCD readout. If anyone knows where to find either of these three circuits (relay switched inputs, digital volume control, and LCD mini-board with on-board controller) ready-made, I would be appreciative. I really like the twisted pear audio 'darwin source selector', but it is out of stock.
  • Replies 54
Check out Dantimax - Remote control audio kits for an input selector + digital volume control.
1) Changes to R1 have very insignificant impact on the performance of the M3.
2) Yes.
3) I do not see any reason to change those either.
4) Maybe your parts list is what is obsolete? Because there are a myriad of 2N3904/2N3906s in stock at Mouser.
What's a supply voltage higher then 24 going to do for you except add more heat? ;)
A gain of 8 is FAR too high for low impedance phones. With my 32ohm AD900 at a gain of 2, I get less than 1/6 of a turn on the volume knob before it is too loud.
For everything else, stick with AMB's values. He is all knowing.
I agree with gain@2, unless you know you listen to louder volumes, will never use anything sensitive, will never use anything other than low output sources, or need higher gain for stability with certain opamps.
Thanks for the tip on the Dantimax. Their vol. 2 boards may just be the ticket.
MisterX: sorry to bother again, but when you say 'yes' to question 2, you are agreeing that I should just put in the 22pf for C1L and C1R right off the bat?
Gain of 8 is way too high? I wasn't expecting that! Especially since the default is 11. In rockhopper's page he says "Gain of 11, perfect for a wide variety of headphones, high and low impedance". I figured I was being conservative by starting with 8! Primary phones with this will be Grados, so I guess I will go with a lower gain initially.
Thanks for all the the help so far. I'm sure I will have plenty more questions later.
Oh, anyone have any thoughts about going higher than 24V with the 8610s? Is it worthwhile?
I would not suggest going higher than 24V unless you have headphones that you know are going to need an enormous amount of voltage swing. 24V isn't that far away from the max the 8610 is rated for too (26V) and it's better to have a little safety margin.
FWIW, my MMM is running just under 27V and AD8610. By the time you get voltage drop across D1 and various other losses before the OPAMPs, you drop 1.5-3.0V according to AMB; in my particular case, the OPAMP is only seeing 23.5V.
Also, Regarding Q2, Q5+ and Q5-, the BOM on the M^3 front page at the AMB site is what lists the obsolete parts. There are other 3904/3906 parts but not from the same vendor. It probably doesn't matter as the specifications are not all that different.
Yeah the guy who put that together is a jackass.
Or it could be that the BOM is 4 years old and references parts that were obsoleted by ROHS compliance.
I'm certainly not criticizing. And I understand that the RoHS compliance that obsoleted those items. I couldn't find the fairchild 390x series, even in G. I appreciate the BOM you put together and have referred to it extensively.
I didn't take it as criticism, I was just joking around. But a simple search of Mouser using "2n3904" yielded many results including parts man'f by Fairchild.
Oh ok. I saw the other 390x parts but they all had Hfes of 40, whereas the part from the BOM had an Hfe of 100, which is why I picked the ON semi parts. I was asking if that is really the only param. I should really care about.
Yes. Nothing audio related though. I'm an electrical engineer. I have plenty of standard eutectic solder, but I'm wondering if I the Cardas solder (or equivalent) would represent a significant improvement.
I graduated from Georgia Tech with a BSEE in 1999.
I don't actually believe that it makes a difference, but I'll be the first to admit I don't know everything.
Besides, I do mostly digital stuff...
The Cardas quad eutectic solder is a little easier to work with and I kinda like the way it smells but I would not suggest there is a notable sonic difference between it and random eutectic solder.
I almost forgot.
DIY club offers a couple of different volume control kits as well.
Here is the link------->
DIYCLUB
You can find a lot of the same stuff on Ebay
Here is a random example:
Hi-End Volume Control DIY Kit,LED, Remote Control /V-02 - eBay (item 250349671795 end time Jun-27-09 20:43:25 PDT)
And...
It may be a good idea to pick some op-amps that are a better synergy match for your headphones?
(bright op-amps with bright headphones = an unpleasant experience!)
I like bright. I'm not opposed to rolling but I like the really tight dynamics.
Thanks for the link. I already ordered a volume control/remote/input selector kit from bbp at diyaudio. The same one that is in naamanf's b22. Quite inexpensive and only 1 left so I pulled the trigger. It's not that big a deal if it's a bust. I have to say, I have been shopping for a headphone amp for a while, and they DIY route is amazing in the feature/dollar ratio!
naamanf's b22: http://www.head-case.org/forums/do-yourself/476-diy-amp-such-build-gallery-87.html#post235506
thread about kit: diyAudio Forums - New project : R-2R Attenuator With Remote Control V2 - Page 1
I will have to do something else about gain control. At the moment I'm thinking i will have to open the top cover to change the gain, which isn't that bad.
I have also decided to start with a gain of 5. I know some folks recommend 2, but I have to think that has a lot to do with the source as well.
Thanks for all the help! My summer intern is eager to get building. ;-) The vast majority of the parts will be here next week.
The only things really left to purchase now are the case, transformer for the sigma-11 and a 5V supply for the volume/input selector kit.
I am toying with the idea of peak-meters. Maybe ones that can be switched in and out of the signal path.
