screaming oranges Posted June 29, 2009 Report Posted June 29, 2009 ... and ATH ESW10. Alex - what voltage is your Stax 007Ta at now? (100 or 220) If 100V, I have a 115 x 100 Volt converter that I can bring over for you. It is high power capacity, and wouldn't break a sweat supplying the 7T. I'll refrain from bringing my own ESW10 then. The less I have to carry, the better. As for the amp, it is 100V, so it works out. Thanks! AS FOR FOOD: I don't know what is planned? Are we all going out to eat, ordering? The Super Target near where I live sells Cheesecake Factory cheesecakes. Damn good cheesecake... hint hint. RAFFY: what happened to your extreme? I happen to have two: the platinum and the standard. I haven't used the standard Extreme because I tried to remove the hex screws and they got stuck and I just gave up on the thing, decided to keep it for spare parts in case the Platinum needs fixing sometime. Quote
agile_one Posted June 29, 2009 Report Posted June 29, 2009 ... Also, I'd appreciate it if anyone with ANY amp that can drive an O2 takes it, since I want to hear options. On same topic, don't know if any of you can DIY, and I'd appreciate help in rewiring a STAX 007ta amp to US voltage (I will pay for services of course). Like Mike said, flecom is your man, should he be in the mood to fire up his iron. btw, I assume you've seen this Head-Fi thread specifying changes needed? Need Help Converting STAX SRM-007tA from 100V to 117V - Head-Fi: Covering Headphones, Earphones and Portable Audio Looks simple enough that anyone with an iron and multi meter could do. Quote
raffy Posted June 29, 2009 Report Posted June 29, 2009 RAFFY: what happened to your extreme? I happen to have two: the platinum and the standard. I haven't used the standard Extreme because I tried to remove the hex screws and they got stuck and I just gave up on the thing, decided to keep it for spare parts in case the Platinum needs fixing sometime. One of the resistors blew and would supply power to the tubes. The trafo still gets some juice as I can still hear it humming lightly. At least for now, the trafo is not busted. Your extreme is still working right, it's just the hex screws that are busted? Quote
screaming oranges Posted June 29, 2009 Report Posted June 29, 2009 One of the resistors blew and would supply power to the tubes. The trafo still gets some juice as I can still hear it humming lightly. At least for now, the trafo is not busted. Your extreme is still working right, it's just the hex screws that are busted? Correct, it is still functional. I just wanted to open it because there is something that fell inside and is rattling at the bottom. I wanted to remove it but gave up on the hex screws from hell. The only option is to drill the screws out now, but I just never got around to it. Quote
raffy Posted June 29, 2009 Report Posted June 29, 2009 Correct, it is still functional. I just wanted to open it because there is something that fell inside and is rattling at the bottom. I wanted to remove it but gave up on the hex screws from hell. The only option is to drill the screws out now, but I just never got around to it. Lucky you, I'd take a broken hex screw over a broken resistor anyday! Quote
tyrion Posted June 29, 2009 Author Report Posted June 29, 2009 btw, I assume you've seen this Head-Fi thread specifying changes needed? Need Help Converting STAX SRM-007tA from 100V to 117V - Head-Fi: Covering Headphones, Earphones and Portable Audio Looks simple enough that anyone with an iron and multi meter could do. Hey, I have a soldering iron and multi meter. Quote
crappyjones123 Posted June 29, 2009 Report Posted June 29, 2009 more sp amps down the drain. i wont have any gear to bring. im sure someone will have a pair of 650s there. will bring marks cable if anyone cares to listen to it. hopefully the stitches dont hurt by then. Quote
agile_one Posted June 29, 2009 Report Posted June 29, 2009 Hey, I have a soldering iron and multi meter. you're hired! Quote
tyrion Posted June 29, 2009 Author Report Posted June 29, 2009 you're hired! That is a scary thought. Quote
crappyjones123 Posted June 29, 2009 Report Posted June 29, 2009 mike with a soldering iron, maybe i should just stay home for this one. Quote
n_maher Posted June 29, 2009 Report Posted June 29, 2009 mike with a soldering iron, maybe i should just stay home for this one. Quote
agile_one Posted June 29, 2009 Report Posted June 29, 2009 not scary for me ... it's Alex's amp. let's wait till after dark to do it, so we can see the sparks fly when it gets turned on after your mod. Quote
Dusty Chalk Posted June 29, 2009 Report Posted June 29, 2009 And don't touch the soldering iron to the backs of any bullets. Quote
screaming oranges Posted June 29, 2009 Report Posted June 29, 2009 Maybe Mike just needs some encouragement: If Mike succeeds, I will definitely sell him the Aero DAC plus $50 discount, if not, he needs to replace my amp/have it fixed. ...wait, this might be a bad idea. Quote
raffy Posted June 29, 2009 Report Posted June 29, 2009 Maybe Mike just needs some encouragement: If Mike succeeds, I will definitely sell him the Aero DAC plus $50 discount, if not, he needs to replace my amp/have it fixed. ...wait, this might be a bad idea. How about this: regardless of whether Mike succeeds or not, you'll sell me the Aero DAC for a $50 PREMIUM? Quote
grawk Posted June 29, 2009 Report Posted June 29, 2009 How about this: I'll give you $50 and won't have boo shoot you for the aero Quote
screaming oranges Posted June 29, 2009 Report Posted June 29, 2009 How about this: I'll give you $50 and won't have boo shoot you for the aero How come it's funny when you say it? Quote
grawk Posted June 29, 2009 Report Posted June 29, 2009 I thought it was funny when you said it too Quote
tyrion Posted June 29, 2009 Author Report Posted June 29, 2009 How about this: regardless of whether Mike succeeds or not, you'll sell me the Aero DAC for a $50 PREMIUM? How about this: I'll give you $50 and won't have boo shoot you for the aero Back off there you two. If anyone is buying the aero for $50, it's me. Quote
screaming oranges Posted June 29, 2009 Report Posted June 29, 2009 Haha, my colleague's radio was playing "It's my party and I will cry if I want to, cry if I want to..." while I read Mike's post. Quote
NightWoundsTime Posted June 29, 2009 Report Posted June 29, 2009 I'm afraid to bring my MPX3, what with the recent rash of dead SP amps. Oh well, it's made it this long, one more trip won't kill it. Quote
boomana Posted June 29, 2009 Report Posted June 29, 2009 I don't know what I'll be bringing, but I'm going to try and get whatever it is to Mike's on Thurs. Quote
crappyjones123 Posted June 29, 2009 Report Posted June 29, 2009 might be able to bring 2 power amps + 3 pre amps if you interested mike. and some abs speakers. rather not bring the speakers, annoying to move as they are rather bulky. Quote
tyrion Posted June 29, 2009 Author Report Posted June 29, 2009 I don't know what I'll be bringing, but I'm going to try and get whatever it is to Mike's on Thurs. If it's not a BHSE, get a refund. might be able to bring 2 power amps + 3 pre amps if you interested mike. and some abs speakers. rather not bring the speakers, annoying to move as they are rather bulky. I wouldn't bother. I'm sure it will be more headphone listening. Quote
screaming oranges Posted June 29, 2009 Report Posted June 29, 2009 I wouldn't mind listening to some speakers. Is it a must to have pre-amps for a speaker rig? Quote
