grawk Posted September 28, 2009 Report Posted September 28, 2009 Did you try resetting your PMU, like suggested in that thread?
n_maher Posted September 28, 2009 Report Posted September 28, 2009 Seems that I'm not the only one to have experienced it, and it always seems to go back to the issue of OS update. Yeah, my sister's Macbook started acting up yesterday and will no longer connect to her preferred network.
The Monkey Posted September 28, 2009 Report Posted September 28, 2009 I am of the opinion that Snow Leopard sucks.
Hopstretch Posted September 28, 2009 Author Report Posted September 28, 2009 The randomly-flaky-Airport issue has been around in various forms since Tiger, I believe. It is particularly annoying because it is so unpredictable. Some people have no problems at all, while others using the same hardware and same software versions get driven to near insanity. It Just Works. (Usually. Unless It Doesn't. For No Apparent Reason. Um ... Sorry?)
GPH Posted September 28, 2009 Report Posted September 28, 2009 I am of the opinion that Snow Leopard sucks. Really? Did you do a clean install or just an upgrade? On my Santa Rosa Macbook, all the Apple apps are much snappier than they ever were on Leopard and I don't have any problem with third-party applications. Boot time and shut down time are much faster also. At this point, I'm not sure if it was worth 30$, but I'm curious as why you think it sucks.
The Monkey Posted September 28, 2009 Report Posted September 28, 2009 I did the upgrade after considerable debate and research about the clean install. My experience, oddly, has been the exact opposite of yours. Everything is slowing down and boot time is longer. Definitely could be something other than the new OS, but that's the easiest thing to blame right now, so that's what I'm going to do.
Hopstretch Posted September 28, 2009 Author Report Posted September 28, 2009 Something shitasmic is going on.
n_maher Posted September 28, 2009 Report Posted September 28, 2009 (edited) Something shitasmic is going on. I don't care if every Mac product comes equipped a magic button on the side that causes it to piddle gold coins and resurrect the dead and make holographic unicorns dance inside your head. I'm not buying one, so shut up and go home. and jebus, i'm crying here... I know Windows is awful. Everyone knows Windows is awful. Windows is like the faint smell of piss in a subway: it's there, and there's nothing you can do about it. Edited September 28, 2009 by n_maher
uberburger101 Posted September 28, 2009 Report Posted September 28, 2009 @grawk: I'll try the PMU method. Still a little new to Apple.
uberburger101 Posted September 28, 2009 Report Posted September 28, 2009 Damn. Resetting the PMU didn't work.
VPI Posted September 28, 2009 Report Posted September 28, 2009 I have found that all three of my Macs have slowed down and I am getting many more spinning beach balls than before. Mine are all less than a year old and worked fine before SL. I did not do a clean install so I might have to try that next. I have not noticed any wireless issues with the MacBook Pro and the others are hard wired.
morphsci Posted September 28, 2009 Report Posted September 28, 2009 Well the iMac and Mac Mini are going along, blissfully ignorant of how badly their new operating system sucks.
Dusty Chalk Posted September 28, 2009 Report Posted September 28, 2009 he's right when he call's himself a bloody idiot.I disagree -- I thought that was a fine bit of writing. He did a shitasmagorific an admirable job of capturing and conveying a mentality that I believe exists in large numbers. I think you just may have shitasmagoriphobia.
The Monkey Posted September 29, 2009 Report Posted September 29, 2009 I badly want a MacBook. not a DACbook.
grawk Posted September 29, 2009 Report Posted September 29, 2009 not particularly, that's why it's broken
Currawong Posted September 29, 2009 Report Posted September 29, 2009 If you are getting wireless drop-out, change your wireless channel in the router to something different. They all default to channel 11 I've found, so you only need a couple of neighbours with wireless access points to get drop-out issues. Those of you getting beachballs, do you get them with the same software while logged in to your Mac as another user? Do you get any interesting errors in the Console?
mirumu Posted September 30, 2009 Report Posted September 30, 2009 As an addendum to that, there are really only three distinct wifi channels that do not overlap with others. These are channels 1, 6 and 11. The lower channels work at lower frequencies and hence tend to be more reliable and have better range. Also the internal antenna will be tuned for one specific channel and as far as I'm aware this is usually channel 6. So other factors aside channel 6 is probably the best choice if you don't have other networks to worry about. Personally though I find my network performs best using channel 1 since the other networks nearby tend to use either 11 or 6. There's simply less interference for me on channel 1. YMMV.
Currawong Posted September 30, 2009 Report Posted September 30, 2009 Thanks for the info mirumu, I'll add that to my store of random Mac knowledge for future use. I tended to use channel 1 most of the time, as I figured it was the least likely to be used by other people.
GPH Posted September 30, 2009 Report Posted September 30, 2009 I installed Snow Leopard yesterday on my MSI Wind U100 (1.6GHz, 1GB RAM, 160GB HDD) and I'm pretty damn impressed to say the least. I had been running Windows 7 Pro for a couple of weeks and it ran OK with some big slowdowns from time to time. SL, on the other hand, runs very smoothly, with all the visual effects, just like what you'd expect from a recent Mac, except the Wind only cost me 240$. It seems to manage intense multitasking much better than XP or Win7 on the little Wind. The cool thing also is that I installed Snow Leopard in such a way that I can download system updates without breaking the whole thing. Now, I just need to find a way to sync my iCal and address book with my MacBook and I'll be a happy camper.
grawk Posted September 30, 2009 Report Posted September 30, 2009 They got the snow leopard drivers worked out for the hackbooks now? You can sync ical and address book to gmail now...
GPH Posted September 30, 2009 Report Posted September 30, 2009 They got the snow leopard drivers worked out for the hackbooks now? Yes, there's plenty of info on the MSI Wind forums. I did the "vanilla" install using Chameleon2 bootloader. You can probably do something similar on your Toshiba. Thanks for the Gmail suggestion, I'll try that.
feckn_eejit Posted October 7, 2009 Report Posted October 7, 2009 Since taking a sabbatical from work, it has been at least a month since I've touched Vista. Got conned into setting up a wireless router for a friend last night. Is it that Vista gets even worse with time, or is my lack of exposure and subsequent coddling in the supple, perfectly proportioned bosom of OS X the cause of my lack of tolerance for Windows bullshit? I just fucking love solving problems in Unix and hate it in Windows. You get under the hood and everything is nasty and recalcitrant. Sorry for the OT rant but had to vent somewhere...
