Quad Posted June 1, 2009 Report Posted June 1, 2009 Could anyone point out the precise differences between the Stax SR-202 and the SR-303? I understand that the difference between the '303 and '404 is only the cable, but I was wondering what about the '202? I have read something about it somewhere (how's that for being vague.. . Maybe in the Stax thread), but I am unable to trace it back. Thanks for the help!
padam Posted June 1, 2009 Report Posted June 1, 2009 Both the cable (OFC vs. PC-OCC) and the drivers are different, audiod wrote that it is a great value choice if driven by a good amp because it doesn't have the midrange 'etch' of its bigger brothers.
Quad Posted June 1, 2009 Author Report Posted June 1, 2009 Thank you padam. Would you happen to know what the precise difference w.r.t. the drivers is? I too am a bit dissapointed by the coloration of the SR-404 (compared with my SRX-mkIII) and by the pronounced s-sounds (most noticeable in female vocals). Thanks. best wishes, Quad
padam Posted June 1, 2009 Report Posted June 1, 2009 The specs seems to be the same apart from the cable, so I don't know but the drivers are definitely not the same, so the difference should be bigger than between the SR-303 and SR-404. I found a thread at the other forum where they had written that the difference is little between them, so the opinions may vary. audiod's comparison thread about the two
Quad Posted June 1, 2009 Author Report Posted June 1, 2009 Thank you padam, One of them indeed is the post I had read sometime, but was unable to find back. It all helps to get a better picture of the 202-303-404 relationship and preferences. Quad
spritzer Posted June 1, 2009 Report Posted June 1, 2009 I've never had to open up any of the new drivers (or seen pics for that matter) but from the outside it looks like the SR-202 uses the old style drivers with an etched copper plate for stators encased in plastic supports. These are then bonded to the metal rings used to support the diaphragm and carry the bias voltage. The new drivers are certainly different and appear to be some form of plastic with a conductive layer on the bottom. There is no way to be sure and I won't split open a working driver just to take a look. It takes a lot of delicate work to get them back together but if somebody had a broken set that's another thing...
Quad Posted June 1, 2009 Author Report Posted June 1, 2009 Thanks Birgir, If the construction is different, it certainly would go a long way towards explaining the claimed sonic differences between SR-202 and SR-303 / SR-404. And puts some light on the opinion that the 202 is, soundwise, more closely related to some of the Lambdas than to the 303-404.
Duggeh Posted June 1, 2009 Report Posted June 1, 2009 I really liked my 202s out of the 717. Couldn't touch the O2 though.
