Knuckledragger Posted October 25, 2019 Report Posted October 25, 2019 Bluesound node 2i, Rogue Sphinx 2 and Sonetto IIIs.
Craig Sawyers Posted October 25, 2019 Report Posted October 25, 2019 (edited) That is one outrageous system - love it! The JBL one with the mega-deck that is Edited October 25, 2019 by Craig Sawyers
jose Posted October 26, 2019 Report Posted October 26, 2019 If I lived on the continent, I would try to get some Olympus C50 / 537-500. In a suitable room and being in good condition, they have to be wonderful.
skullguise Posted October 29, 2019 Report Posted October 29, 2019 That looks like Gryphon electronics on top....that's how we named one of our cats (Gryphon Diablo). 1
Knuckledragger Posted November 2, 2019 Report Posted November 2, 2019 Vivid Audio B1 Decades. Guy is a neighbor of Hopstretch apparently. 3
Knuckledragger Posted November 2, 2019 Report Posted November 2, 2019 Quote After an exceptionally long week, I finally made it to my happy place. Following years of upgrading, acquisition, learning to work with electronics, and tweaking I'm finally really happy with my rather simple vinyl setup. Aside from needing a new set of tubes, I finally have everything really dialed in. Ortofon 2M Bronze Cart: this sucker took a hard month to break in, and I was really worried that it was defective, but it was worth it. Much better than the vintage moving coil I was running. Harman Kardon T-60 Turntable: I found this guy for a steal at $75. It needed a lot of cleanup and tweaking. It took months to really dial in the platter, isolate the motor, and finicky antiskate, but I love this table. I hope it never dies. Known as the "poor man's Linn Sondek" this thing sounds great. My favorite feature is the auto lift that is triggered by optical sensor. It's an audiophile solution that is totally isolated from the tonearm with no gear mechanism. Why dont we have these on modern decks??!! Pro ject Phono Box DS: a great little phono preamp with a lot of flexibility. After rolling some tubes, I settled on a vintage set of MILSPEC Raytheons. Bob Latino ST-120 (high gain): The centerpiece of my setup. This thing is fully loaded after installing a bunch of upgrades. With the input attenuator, I can run the amp without a preamp for simplicity and pure sound. I'm running it with KT-120s and Mullard CV 4024 drivers. The drivers made a HUGE difference. If you have a setup with 12AT7 tubes, you NEED to get these. Mullard made hundreds of thousands so they are still really cheap for their performance. Buy a bunch now while you can. Klipsch Fortes (originals): A compromise for the Forte 3s which I cant afford. I found these locally for pretty cheap. I replaced the crossovers and tweeters with Bob Crites products for a huge improvement in audio. I built my own stands to elevate them. My next project is to reveneer the oak cabinets. Furman Elite 20PFi power conditioner: an unexpected bargain find that definitely helped clean up the sound and really drop the noise floor. Audioquest bridge series interconnects: I have a love hate relationship with these. Mechanically, they suck. the internal connections are shoddy, but I cant find anything that I've liked better, especially between the turntable and the preamp. Anything else I've thrown in the system(that I can afford) throws a blanket over the music. For now, these are what I'm sticking with. DIY Crutchfield speaker cables: I run my TV and vinyl setup on the same speakers (different amps) so I needed a solution that would allow me to quickly and safely switch between the two. The solution was to build a set of "bi-wire" cables where both amps are always plugged in and I can change between the two at the speakers. With some techflex, bannana plugs, lots of heat shrink, and Crutchfield, 10awg oxygen free cable, I turned out some snakes that look pretty professional and sound good enough for me. 1
Knuckledragger Posted November 10, 2019 Report Posted November 10, 2019 Quote After losing a high end projector based multi channel amp and speaker home theater system in a divorce, I finally had the justification to build a worthy two channel system. This has been put together beginning in 2016. The space is not ideal, and the gear is mostly mid-fi, but for my budget it sounds wonderous. The addition of the Rega wall mount helped with the subs. The GIK panels made a big difference, especially the corner traos. First reflection points on the walls are basically impossible in my room, so it's a compromise. The Vito Acoustics diffusers are basically just for looks, they don't seem to do much for my ears. PrimaLuna DiaLogue premium HP integrated tube amp Rega RP-10 w/Aphelion MC cart Technics SL-10 turntable w/Technics 310MC cart Herron Audio VTPH-2A tube phono stage Revox B77 MKII reel to reel Nakamichi ZX-7 Cassette deck Rotel RCD-855 CD player Bluesound Node 2i streamer Focal Aria 948 speakers w/Isoacoustic GIAI II footers REL Acoustics S3/SHO Stereo pair subs Furman M 8X2 power Monoprice Interconnects Monoprice 12 Ga speaker cable GIK Acoustics Bass traps, gobos, clouds Vito Acoustic Diffusion panels Rega Wall Mount 3
Dusty Chalk Posted November 10, 2019 Report Posted November 10, 2019 Nice to see someone taking room treatments seriously.
Craig Sawyers Posted November 19, 2019 Report Posted November 19, 2019 Needs some carpets and soft furnishings. Just sayin.
jose Posted November 19, 2019 Report Posted November 19, 2019 I like that equipment, but with these speakers adding a subwoofer is stupid. The bass must be totally out of control.
EdipisReks1 Posted November 19, 2019 Report Posted November 19, 2019 28 minutes ago, Craig Sawyers said: Needs some carpets and soft furnishings. Just sayin. Oh, that room badly needs some sort of damping, but I love that staircase, and the art. And that console table. 4 minutes ago, jose said: I like that equipment, but with these speakers adding a subwoofer is stupid. The bass must be totally out of control. Sometimes you want things to be a little out of control.
jose Posted November 24, 2019 Report Posted November 24, 2019 EMMESpeakers "The Da Vinci" Loudspeaker 5
jose Posted November 25, 2019 Report Posted November 25, 2019 Is the rooster to enhance the treble? 1
Knuckledragger Posted November 25, 2019 Report Posted November 25, 2019 Quote Gear List: - Micro Seiki 1500 - Fedelity Research Cartridge PCM1 - Sony 12in Tone Arm - Accuphase C - 17 Head amp - Accuphase DC - 37 Digital Processor - Accuphase DP - 900 CD Transport - Denon PRA-QS1 Pre amp and Power - Denon POA-QS1 Amp - Magnepan 20.7 4
