Speaker Porn
The Ion Cloud was his coolest speaker.
  • Replies 2.3k
  • Views 658.2k
  • Craig Sawyers
    Craig Sawyers
    Ah - the good old battleship grey Cambridge Audio livery. It was panned by the reviewers, as were the buttons on the CD player (they described them as reminiscent of poking dead flesh). Very unfair, b
  • R5s arrived:
  • I dunno, can i post this here? The leather was just an idea - making some matching wood pulls would be cool - maybe when things die down at M&O of course my speaker cables are too short
Didnt Nelson start out designing speakers? Either way, those are, IMO, some of the sexiest speakers I have ever seen.
Yeah, he worked for ESS from 1972 through 1973 :D and Ion Cloud is very cool.
Here is what Pass said about them in a post at DIY audio:
The "ion cloud loudspeaker" used photocopy
machine ionizing nichrome wire strung in a flat
array a bit like a window screen, but with more
space between the wires, and charged to a variable
DC potential of about 10 KV.
This screen developed a layer of ionized air, and was
enclosed between two stators, much like an electrostatic
speaker, except that instead of a charged plastic diaphragm,
you had a charged semi-flat layer of gas, and you could
push-pull it with high AC voltages on the stators.
It worked fairly well, and gave new meaning to the word
"transparency".
It also had several flaws, one of which did result in a
trip to the local emergency room with breathing problems
similar to those sometimes experienced by arc welders and
caused by extended exposure to ozone.
The Wall Street Journal printed my comment:
"It was the perfect high end audio product: Exotic, inefficient,
expensive, unavailable, and toxic."
:P
"...It took several kilowatts to get any sound out of it...It drew so much power at the display at CES that every time there was a loud passage or a transient, the AC line would drop. The tension arms on the tape deck would go slack, the sound would stop, the power would go back up, and it would start again; then the power would go, and it went into an oscillatory loop which included every element of the chain, including the AC line and the tensioning arms on the tape deck. We had a lot of fun doing that—a good demonstration of how much power it required. Fabulous device, but it put out ozone, and after some extensive exposure to the ozone I found myself lacking oxygen in my bloodstream...It was a year before I could go near a copy machine..."
Yeezh.
  • 4 weeks later...
When I saw the first pic I thought "those look an awful lot like the Shackman drivers..." :D
Great stuff, if only I had a garage and new how to DIY :D
The garage I can't help you with but nobody starts out knowing how to do DIY. There are many paths to it, but probably nothing beats just doing it and learning from your mistakes. There are lots of resources on the web and probably there are local adult ed classes that will help.
Note that I can't do DIY either, but I'm starting by making my first mistakes on the Discrete Single Ended JFET Amp group build. :P
It's all about doing and burning/blowing up things while your at it.
:D I do try at times to make something, if it's a simple fix I can do it but at complicated things I just fail, mostly due to my piss pure soldering skilzzz and luck of concentration I guess ;)
How deep is the, uh, "bass port?"
thanks for making me spit my soda all over my screen fitz. bass port.
FTFY
I had to ask. :palm:
You mean assk?
Improper depth could lead to flatulent reproduction.
