shellylh Posted November 7, 2012 Report Posted November 7, 2012 PWD MKII upgrade kit on sale for $795. http://www.psaudio.com/shop/mkii-upgrade-kit/ Quote
HeadphoneAddict Posted November 7, 2012 Report Posted November 7, 2012 That's the price I got last week, and it should ship in 4-6 weeks. Quote
jvlgato Posted December 14, 2013 Report Posted December 14, 2013 How do I hook up my 2009 Mac Mini to my PWD mk1 bridge to use the Mini as a music server? The PWD bridge (the expansion port in the pic below) has an ethernet connection and a USB connection, but the USB connection is the thin USB input connector that I see on computers, while the 'digital input' that's on the PWD directly (not the bridge) is the USB accessory square looking input. IIRC, on the PWD Mk1, the networked Bridge input may sound better since it has the Digital Lens to reduce jitter. So I'd prefer to plug the Mac Mini into the Bridge. But i'm not sure if I need to do anything special with the Mac Mini to do that? It seems to me that I can't just plug it in to the Bridge and have it work as a server, and be DLNA compatible. And if I plug it into the regular digital input, it'll probably work ok, but then wouldn't have the Digital Lens, plus it wouldn't be DLNA compatible, and would be harder to remote control? Quote
blubliss Posted December 14, 2013 Report Posted December 14, 2013 You have to use a router to use the bridge, pretty sure, that's what I did with mine. Quote
grawk Posted December 14, 2013 Report Posted December 14, 2013 you could just run an ethernet cable. The mac ethernet port will automagically crossover so you don't need a switch in between. Quote
GeorgeP Posted December 14, 2013 Report Posted December 14, 2013 Ignore the usb on the bridge/expansion port as it is just used to upgrade the bridge software - it cannot be used for a music signal. The bridge is just the ethernet port, which users suggest is better than the other inputs the PWD offers. Quote
jvlgato Posted December 15, 2013 Report Posted December 15, 2013 Thanks x 3. So I can run an ethernet cable to the bridge... Then I can run Amarra, set the sound output to Amarra on the Mini and boom, music? That would be sweet. Although no DLNA, I suppose. But then there's plenty of remote apps for iTunes... Quote
jvlgato Posted December 15, 2013 Report Posted December 15, 2013 ... If I can get the wifi to reach Quote
blubliss Posted December 15, 2013 Report Posted December 15, 2013 No, if you want to use Amarra, you have to use the USB input...the mini would just serve the music if you use the bridge, you put the PS server software on your mac. Quote
manaox2 Posted December 15, 2013 Report Posted December 15, 2013 The USB has one digital lens, the bridge has two. To get all the features through the bridge, you would use elyric music manager. Otherwise, no gapless or cover art with bridge. Any uPnP plugin should work. Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 See that red jumper wire in the terminal block? I'd say that is the voltage setting and this is picture of a 230V unit. Anybody have a US unit they want to open up? Hello. I Have just opened my PWD MKii today. This one is 110V and I want to change it to 230V. You are right, the jumper setting is really diferent. The first screw is connected to the third ans the second screw connected to the forth... Are you sure it is only needed to change this jumper and put it like the above photo? Regards... Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 Attached you can find the image of the PWD DAC the 110V version Jumper settings... Jumper setting really diferent from post from page 6 os this thread... Regards. Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 Sorry to bump the thread. I'm thinking of getting a PWD but not sure if it could be converted to 230v AC. The only clear pic of the transformer I could find is the one from 6moons: The dealer wants $200 to do the conversion, which I never want to do. Also want to change! This is the photo of the PWD for the 110V Jumper settings... Diferent from the above... Quote
spritzer Posted January 11, 2014 Report Posted January 11, 2014 I wouldn't look blindly at the jumpers as there are clearly two ways for them connect the transformer primaries. Those are also not the same transformers. Is the picture you posted of the 117V setup your own unit? If so, look all around the transformer for any writing as to which wire is which. Then remove the jumpers and ohm out the connections to the jumpers. Then you will know how to connect them. 1 Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 I wouldn't look blindly at the jumpers as there are clearly two ways for them connect the transformer primaries. Those are also not the same transformers. Is the picture you posted of the 117V setup your own unit? If so, look all around the transformer for any writing as to which wire is which. Then remove the jumpers and ohm out the connections to the jumpers. Then you will know how to connect them. Hello Spritzer. Thank you very much for the reply. Yes it is my own unit and the dealer is asking 200€ for the conversion (Portugal). Can you help me with the conversion? What do you mean by "remove the jumpers and ohm out the connections to the jumpers"? Thanks. Regards. Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 Hello Spritzer. Thank you very much for the reply. Yes it is my own unit and the dealer is asking 200€ for the conversion (Portugal). Can you help me with the conversion? What do you mean by "remove the jumpers and ohm out the connections to the jumpers"? Thanks. Regards. On the switch it is writen 250v so it is ok to deal with 250v, on the fuses it is writen 250V so it's the same, on the 2 transformet it's writen 120V, so between the fuses and the transformers some "Magic Hapens" Best regards. Quote
spritzer Posted January 11, 2014 Report Posted January 11, 2014 Can you post a high resolution picture of the labels on the transformer and where the wires are soldered into the PCB? It's quite clear what needs to be done but I want to make sure that there is nothing hidden. When configuring a component for 230V you need to wire the primaries in series but for 117V they are in parallel. For this the picture from 6moons makes sense but I just want to make sure that it is the case. Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 Can you post a high resolution picture of the labels on the transformer and where the wires are soldered into the PCB? It's quite clear what needs to be done but I want to make sure that there is nothing hidden. When configuring a component for 230V you need to wire the primaries in series but for 117V they are in parallel. For this the picture from 6moons makes sense but I just want to make sure that it is the case. I hope this will help... One of the transformets is hidden behind some components so i took pictures of the 2 transformers. Thahks. Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 1 transformer. Sorry only can post fotos too small... Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 No more pictures allowed for upload...!!!?!?!?! Cant post the second transforme with all the text written... Maybe tomorow.. Thanks. Carlos Quote
spritzer Posted January 11, 2014 Report Posted January 11, 2014 Yup, we need higher resolution. It's certain though that the voltage can be changed. Quote
correia200 Posted January 11, 2014 Report Posted January 11, 2014 Yup, we need higher resolution. It's certain though that the voltage can be changed. Heelo Sprotzer. I Contacted today Portuguese Dealer, they say they need the Diagram from PS Audio, PS Audio page says it can be done at the dealer very quickly... Can you send me your email so I can send you the fotos high-res? The we post the final result here in the forum to help our coleagues... Because here I have problems with large fotos... Thank you for all tour help. Regards. Carlos. Quote
