Spiug31 Posted April 27, 2009 Report Posted April 27, 2009 What good/excellent sources are there with usb and toslink inputs that have an inbuilt preamp or have consumer (-10dBu) rather than line-level (+4dBu) analog XLR outputs ? It`d need to have usb and toslink inputs at a bare minimum, i2s would help future proof it . I am looking for a quieter source than my line-level mini-dac so that I can remove the voltage divider I`m having to use to reduce its volume. A source with as good or better performance than the mini-dac is preffered. my current solution http://www.head-case.org/forums/do-yourself/5997-resistor-type-make-volume-attenuation.html#post218512 Quote
penger Posted April 27, 2009 Report Posted April 27, 2009 Haven't heard it, but the Bel Canto DAC might fit the bill? Quote
n_maher Posted April 27, 2009 Report Posted April 27, 2009 It is highly unlikely that you'll find what you're after. Balanced DAC's, by default, tend to have a hot output. There's absolutely nothing wrong with the voltage divider approach. Quote
Dreadhead Posted April 27, 2009 Report Posted April 27, 2009 Haven't heard it, but the Bel Canto DAC might fit the bill? The Bel Canto DAC3 is an excellent DAC but it is rather "hot". It's actually hotter than my +12 dBu DEQ2496. I'm doing a voltmeter matched comparison right now and the DAC3 sits at a volume of 96 which means it's probably +16 dBu at full scale. Voltage divider is perfectly fine as long as it's done well. Quote
luvdunhill Posted April 27, 2009 Report Posted April 27, 2009 I know most of the Muse Electronics devices have 1.99 Vrms output on the balanced outs. I was on a similar quest and settled on one of their players and am very happy with it. Quote
penger Posted April 27, 2009 Report Posted April 27, 2009 The Bel Canto DAC3 is an excellent DAC but it is rather "hot". It's actually hotter than my +12 dBu DEQ2496. I'm doing a voltmeter matched comparison right now and the DAC3 sits at a volume of 96 which means it's probably +16 dBu at full scale. Voltage divider is perfectly fine as long as it's done well. I stand corrected. Thanks. Quote
Dusty Chalk Posted April 27, 2009 Report Posted April 27, 2009 Didn't the Benchmark DAC1 have some internal jumpers to alter gain? Or am I thinking of something else? Quote
Dreadhead Posted April 27, 2009 Report Posted April 27, 2009 Didn't the Benchmark DAC1 have some internal jumpers to alter gain? Or am I thinking of something else? Oh yeah it does..... I don't remember the details but it's in the manual: http://www.benchmarkmedia.com/system1/files/documents/DAC1_-_Manual_-_Rev_L.pdf Quote
Torpedo Posted April 27, 2009 Report Posted April 27, 2009 Also Lavry DA-11 has USB, Toslink, AES/EBU and SPDIF coaxial inputs, with regulated balanced output, but it's not a preamp itself. No analogue inputs. It sounds quite well. I got mine a week ago and it's better than I expected. Quote
Spiug31 Posted April 28, 2009 Author Report Posted April 28, 2009 Oh yeah it does..... I don't remember the details but it's in the manual: http://www.benchmarkmedia.com/system1/files/documents/DAC1_-_Manual_-_Rev_L.pdf page 17 of the 40 page pdf, xlr volume attenuation with 4 positions for jumpers 0 dB, -10dB, -20dB, -30dB. Also Lavry DA-11 has USB, Toslink, AES/EBU and SPDIF coaxial inputs, with regulated balanced output, but it's not a preamp itself. No analogue inputs. It sounds quite well. I got mine a week ago and it's better than I expected. page 18 of the 21 page pdf, impressive range (-31 dBu to +24 dBu, balanced) and lots of steps (56). certainly food for thought Quote
Torpedo Posted April 28, 2009 Report Posted April 28, 2009 page 17 of the 40 page pdf, xlr volume attenuation with 4 positions for jumpers 0 dB, -10dB, -20dB, -30dB. page 18 of the 21 page pdf, impressive range (-31 dBu to +24 dBu, balanced) and lots of steps (56). certainly food for thought Yep, it includes a plot where you can estimate the dBu or Volts (RMS and p-p) the DAC outputs at every step on balanced and SE operation. This allows setting it up to match any other source you're using. Quote
