My very own Beta 22 thread
Possible that the LEDs on the boards are not oriented correctly.
  • Replies 222
  • Views 36.5k
Well it didn't last long, I gave it the 10 minute warm up before final tweaking then smelled some faint smoke... switched it off, reset the trimpots to zero on the board I was working on and now nothing lights up :(
I killed it.
yeah, got 30V coming in... 0.3V going out of the sigma.
*sigh*
bollocks!!:mad:
Indeed!
:sadcat:
Pars, how would I know if the sigma was made for 24 or 30V? I was measuring 30 at the terminals
Indeed!
:sadcat:
It depends on the transformer you are using as well as the value of R10.
If R10 is 10kohm then it is wired for +/-24Volts
If R10 is 6.81kohm then it is wired for +/-30Volts
At which terminals were you measuring 30 volts?
the outputs to the boards, and the input, input had a smidgen more volts. It was like 30.xx in and 29.xx going out I think
I had my 65mv, my 4.5v, my 0 dc offset and was just resetting offset after the 10 minute thermal drift period.
So your S22 is working fine then....you are getting +/-30 volts DC on all the 4 outputs, in your case you need 3?
The input is of course in AC volts..right?
SO what did you smoke out?..one of the B22 boards?..the ground channel or the amp channels?
yep, 30v ac in, 30v dc out
Well that's good..just need to debug the amp boards..connect them up one at a time and go through the amb checklist for each then..unless you know which particular board you smoked
It's the sigma that got smoked, not the boards, it's only outputting 0.3V now.
oh...bollocks!!:palm:..
replacing burnt silicon is never fun.
The good news is that the B22 is safe. The bad news is that you have no working power supply for your new baby. :(
heh, looking at the sigma shows no obvious signs of toast which is a pity because at least I'd have something obvious to replace :(
Everything looks perfect.
Now you get to experience the joys of electronics troubleshooting and replacing blown parts! :o
only if I can figure out what's blown... I have no idea what to even check.
Hah, D5 is looking suspicious... and it was in the right area. It's the smallest whatever on the board and it's giving an add reading. Meter set to 200Kohms it's constantly rising from a -48kohms???
What the hell is that thing?
*runs off to check ambs site again...
*EDIT* D5 not C5
Ok, looks like it's a 12V zener diode, and a very important one. I don't know how to test it, any clues?
Edited by Smeggy
Check the output resistors first - R12, 13, 14 and 15. I recall reading on Head Wize that they are almost like fuses when you short the outputs.
Though they are only 0.47 ohm resistors; many multimeters are not accurate that low.
Hah, =c5 is looking suspicious... and it was in the right area. It's the smallest whatever on the board and it's giving an add reading. Meter set to 200Kohms it's constantly rising from a -48kohms???
By measuring the resistance, you are actually charging the capacitor. It causes funky readings.
see above, I wrote C5 instead of D5.
The zener reads .759 on my diode setting
looks like R12 and 13 are popped, 14 and 15 are reading 0.4
Edited by Smeggy
Check. NFI to answer your question regarding testing it. What I do know is that it is just a few cents to replace.
Cheers Beefy, you identified a couple of bits already :dan:
Further testing, with the sigma powered by itself I'm reading 1.6V +/-
R12 and R13 are reading 41V one side, 1.6V the other.
R14 and 15 are reading -1.6V at both ends of the resistors.
The LED is glowing faintly, but glowing.
many of the checkpoint voltages on the board seem fine, others not so.
R12 and R13 are blown. Replace them and re-check the voltages. Don't connect the amp boards until you get the PSU fixed first. Then, connect the amp boards one at a time to set them up.
