Dusty Chalk Posted June 4, 2009 Report Posted June 4, 2009 Still name another USB/Coax/Optical-DAC/AMP/Preamp even at the higher price? Musical Fidelity X-Can V8P is $500. Quote
blessingx Posted June 4, 2009 Report Posted June 4, 2009 Good point. Likely superior SQ and a better choice for most, but costing 1/3 more and losing the coax/opt input options. Quote
Dusty Chalk Posted June 4, 2009 Report Posted June 4, 2009 I don't think it costs 1/3 more if you factor in shipping. I guess that depends on the shipping. And then we're also getting into Pico territory. And you're right -- I thought it had (non-USB) digital ins. My mistake. Quote
atothex Posted June 4, 2009 Report Posted June 4, 2009 How much is like a MisterX-commissioned Gamma1 + Starving Student or something? Quote
Hopstretch Posted June 4, 2009 Report Posted June 4, 2009 I got my friend a Gamma lite + Mini3 for about $235, IIRC. Quote
rogue Posted June 5, 2009 Report Posted June 5, 2009 I bought an Audio-GD C2C amp. I gotta stop buying into the hype-fest that is HF. It's decent enough, fairly well-built, but the sound is pretty lacking. While it is powerful and fairly neutral, everything sounds a bit "muffled" and hyper-smooth, to the point where you end up losing musical detail (things like piano note decay). Unfortunately my only real point of comparison is my RS HR-2 (I know, I know), which on the whole sounds better. Anyhow (and sorry for the thread jack), but what's the most decent amp I can get for the HD800's for $400 or so? I need something to hold me over until I can get a Luxman P1 or GSX. Quote
grawk Posted June 5, 2009 Report Posted June 5, 2009 You should be able to pull off a used M3 w/ steps for around $400 Quote
rogue Posted June 5, 2009 Report Posted June 5, 2009 Danke. I shall be on the lookout for an M3. Quote
spritzer Posted June 8, 2009 Report Posted June 8, 2009 I've been thinking about selling the APL and getting a 30.6 for the last week or so. Quote
elnero Posted June 8, 2009 Report Posted June 8, 2009 It's decent enough, fairly well-built, but the sound is pretty lacking. While it is powerful and fairly neutral, everything sounds a bit "muffled" and hyper-smooth, to the point where you end up losing musical detail (things like piano note decay). I got a brief listen to Biggies Compass with my ms2i's today and this pretty much mirrors my impression but I would add that I found the bass quite thick. It's actually quite a beast for size as well, at least in comparison to my Pico. For the price it's not bad considering the level of flexibility but if you don't need the flexibilty the Pico isn't that much more and IMO is a step up. Quote
Guest h.rav Posted June 8, 2009 Report Posted June 8, 2009 I've tried a C2C and Compass. They sounded muffled. Not sure about how their other products sound... Quote
NotoriousBIG_PJ Posted June 8, 2009 Report Posted June 8, 2009 I got a brief listen to Biggies Compass with my ms2i's today and this pretty much mirrors my impression but I would add that I found the bass quite thick. It's actually quite a beast for size as well, at least in comparison to my Pico. For the price it's not bad considering the level of flexibility but if you don't need the flexibilty the Pico isn't that much more and IMO is a step up. I paid half the price of a new pico, so no complaints here. The sr60's match better with the compass than the pico because the sr60's are bright and the pico is a brighter amp/dac. The compass is fuller sounding and easy to listen to. It doesn't make for a good combo with the ms2's, which makes me fear it won't be good with hf-2's either. Biggie. Quote
elnero Posted June 9, 2009 Report Posted June 9, 2009 I paid half the price of a new pico, so no complaints here. The sr60's match better with the compass than the pico because the sr60's are bright and the pico is a brighter amp/dac. The compass is fuller sounding and easy to listen to. It doesn't make for a good combo with the ms2's, which makes me fear it won't be good with hf-2's either. Biggie. I agree the Compass has a full-bodied, easy to listen to sound which at half the price of a Pico and considering it's versatility it certainly is a good deal. I've never thought of the Pico as being bright though, I'd be more inclined to think the Compass is somewhat dark. Quote
ecclesand Posted June 9, 2009 Report Posted June 9, 2009 I paid half the price of a new pico, so no complaints here. The sr60's match better with the compass than the pico because the sr60's are bright and the pico is a brighter amp/dac. The compass is fuller sounding and easy to listen to. It doesn't make for a good combo with the ms2's, which makes me fear it won't be good with hf-2's either. Biggie. You should try the Sun HDAM. It is bright and punchy and sounds pretty good with HD650s. After listening to the Sun HDAM for a week straight, I tried the stock Earth HDAM and it sounded muffled and there was much less bass kick. The reason I was interested in the compass in the first place was the ability to roll HDAMs or other opamps to change the sound up whenever I wanted a different sound. I like it very much. Quote
NotoriousBIG_PJ Posted June 9, 2009 Report Posted June 9, 2009 I agree the Compass has a full-bodied, easy to listen to sound which at half the price of a Pico and considering it's versatility it certainly is a good deal. I've never thought of the Pico as being bright though, I'd be more inclined to think the Compass is somewhat dark. I wasn't comparing either amp to neutral, I was just saying the pico was brighter than the compass, which I agree is somewhat dark. And I don't use any of the compass's versatility. Oddly enough, my compass is set to the 'bright' setting heh. You should try the Sun HDAM. It is bright and punchy and sounds pretty good with HD650s. After listening to the Sun HDAM for a week straight, I tried the stock Earth HDAM and it sounded muffled and there was much less bass kick. The reason I was interested in the compass in the first place was the ability to roll HDAMs or other opamps to change the sound up whenever I wanted a different sound. I like it very much. I've got the moon opamp in there right now. I also own and earth, but it is more boring in the mids. Might be worth trying a sun with the hf-2's. Biggie. Quote
blessingx Posted June 9, 2009 Report Posted June 9, 2009 Anyone compare the Carat-Topaz (currently $299) or Emerald against the Compass, Pico, etc.? Kinda dug the size, RCAs, and 1/4" jack. Didn't have any phones available I was familiar with at CJ though. Quote
n3rdling Posted June 9, 2009 Report Posted June 9, 2009 I've been thinking about selling the APL and getting a 30.6 for the last week or so. If you decide to do this, shoot me a PM and I'll give you the phone number of a guy that wanted to sell me his 30.6 DAC/PS Quote
feckn_eejit Posted June 9, 2009 Report Posted June 9, 2009 I've been thinking about selling the APL and getting a 30.6 for the last week or so. don't blame you... what's the going rate? what a beast... Quote
guzziguy Posted June 9, 2009 Report Posted June 9, 2009 don't blame you... what's the going rate? what a beast... I'd guess about a 5 year's supply of fresh bread. Quote
feckn_eejit Posted June 9, 2009 Report Posted June 9, 2009 I'd guess about a 5 year's supply of fresh bread.i was going to guess four and a half years but you are probably right! Quote
spritzer Posted June 9, 2009 Report Posted June 9, 2009 If you decide to do this, shoot me a PM and I'll give you the phone number of a guy that wanted to sell me his 30.6 DAC/PS Will do. I'm a bit hesitant to send out the APL and import something new with the economy in this state. The ISK has gone down some 4% this week and it is only Tuesday... don't blame you... what's the going rate? what a beast... I'd say about 5-6.5k$ for a 30.6 based on condition and/or if it was upgraded or not. ML charged 750$ for a new face plate so not all upgraded units have one. I'd guess about a 5 year's supply of fresh bread. I'd say about 7 year's supply today but it could be up to 8 in the next few days. If I could just pay in bread then it would be awesome... Quote
Icarium Posted June 9, 2009 Report Posted June 9, 2009 What?? You have the change to get a 30.6 and haven't? ;p Do it!! Quote
