ZDT <- This is very similar to the Nautilus amp that he had prototyped but better (Partial Silver Electraprint transformers last time I heard).
I think it's a steal at this price versus the price of a new Zana Deux.... anyone on board or considering?
Can someone explain the differences and what they entail? I can see that it's got transformers and now has the capability to drive speakers. But what makes it better?
Sorry for my ignorance. :confused:
It's transformer coupled rather than OTL which is a different sound. It's a pretty different topology I believe.
It's not really balanced.. I believe it's balanced with transformers.. and it only offers single ended input -> "balanced" output. It doesn't let you do balanced input.
I dunno the Nautilus sounded pretty different from the Zana.. wider soundstage... more engaging sound.
Guest sacd lover
I wish he had used something besides a 12AX7 for gain. I like the ZDs 6SL7 better. But, with the transformers eating up some of the gain he probably needed too.
I wish that he'd a) remove the locking mechanism from the 4-pin jack, it's 100% unnecessary and detracts form the look of the amp and B) while he's at it rear mount the 4-pin jack, it would clean up and otherwise very aesthetically pleasing design. 2 pretty minor quibbles, hope to hear one some day.
I think the reason the locking mechanism is left in is that XLR jacks don't have the same contact force that RCA jacks do. I know amb has said this a few times, as have a few people on other boards who seem to give a knee-jerk disapproval when they see pics of jacks with the mechanisms removed.
Nah.. this was designed/prototyped in parallel with the BA as the Nautilus. His plan was always to have it assembled alongside the current run of ZDs and BAs. This shouldn't influence delivery time on the BA at all.
He's been working on both concurrently the ZDT has been in the works for months. The BA delays are a function of parts delivery not build time as they all pretty much go to the build house he uses. (not sure if the build house is doing the BA or not)
I am pretty sure the ZDT is being assembled by the build folks he uses.
Yeah the build house is.. not sure if its in that stage. He might still need to take some solid photos of the completed BA before giving his reference to them (I have preliminary photos and it looks pretty sweet, but I think he wants to do some ones with better lighting before posting them on his site). He also might need to do some tweaking with the AD1 tubes (He ended up putting those in his reference because he couldn't find his 307A sockets). After it enters that stage though they should be finished in ~2 weeks... then its probably testing/packing.
Doesn't Neutrik make the jacks (maybe not the 4-pin) with the locks removed?
For one look at the power output into lower impedance. Waaaaay more power output, so the benefits of better drive capability into the low impedance grados and such theoretically should be apparent. Consider you are getting about 3watts of power into 32 ohms and I am sure the tube itself is run very lightly due to the transformer coupling, the sound could be a step up from the zana with the low impedances.
8 watts into 8 ohms is ideal for my speaker tastes - in fact if craig fracking let me know that something like this was on the horizon or if the moth didn't come through, I would get this in a heartbeat due to the versatility.
The transformer coupling in general will allow the tube to run a bit easier (which in my opinion is usually a benefit in operation and sound). The tube itself has a very low plate impedance so the transformer itself can be wound much better, making it more ideal in this application. Cannot beat the higher power output though that stems from all those things mentioned above.
I dunno dudes... I really fucking want one...
Pretty much my end-all, be-all SE solution with a whole lot more power than the Moth. As I was listening to Mike's (Absorbine's) ZD at the IL meet this past weekend, I was thinking to myself "fark, I really wish this amp had speaker posts".
I'll be damned, Craig decided to give me/us just that, with plenty of iron to boot :).
Almost makes me regret selling both my K1000's. Speaker outputs for my speakers, too, though 8 watts into 8 Ohms is about half of other 6C33C-B amps like Almarro A318B...
$2500. How much was the now sold-out Balancing Act again?
