Genetic Posted February 16, 2009 Report Posted February 16, 2009 Yes another USB converter.... I have an easy one for you: do these USB converters are that truly different from each other? I mean are they realy on different levels if you compare the ones you can find used like the affordable RedWine Audio to the crazy expensive Empirical stuff? I like the Canto presentation but at $500 (US) this need to be good. Thanks in advance. Amicalement
Salt Peanuts Posted February 16, 2009 Report Posted February 16, 2009 http://www.head-case.org/forums/audio-accessories/5000-bel-canto-high-rez-usb-playback-last.html
Genetic Posted February 16, 2009 Author Report Posted February 16, 2009 http://www.head-case.org/forums/audio-accessories/5000-bel-canto-high-rez-usb-playback-last.html Thanks......but after reading the linked thread I learned only one interesting fact: Justin is working on a similar device.... Amicalement
Salt Peanuts Posted February 16, 2009 Report Posted February 16, 2009 Thanks......but after reading the linked thread I learned only one interesting fact: Justin is working on a similar device.... Amicalement Yep, and I'm willing to bet it'll come in better looking case.
Genetic Posted February 16, 2009 Author Report Posted February 16, 2009 Yep, and I'm willing to bet it'll come in better looking case. OK you win.... But I'm still wondering if the iMac I will buy next month will benefit from such a costly converter if I want to use it with my Ack Dack 2.0 I like this dac but a $500. converter seems a bit over the top unless there is no real gain from these higher level converters. Just wondering. Amicalement
Genetic Posted February 16, 2009 Author Report Posted February 16, 2009 the iMac has a bit perfect optical output. Yes but I dont think it will work with the Ack Dack. Amicalement
Genetic Posted February 16, 2009 Author Report Posted February 16, 2009 does the Ack Dack only have a coax connector? in that case, a toslink to coax adapter would be a better bet, i would think. I just looked into that option. And indeed this will cost a lot less (around $50). I just hope this will (the adapter) keep the sound at a the same quality level as the one I was looking for with a converter. Thanks for your suggestions. Amicalement
Knuckledragger Posted February 16, 2009 Report Posted February 16, 2009 Rat Shack had digital converts (coaxial to optical or coptical to coaxial) converters on closeout for $10 each about a month ago. I bought one, kind of wish I'd bought them out.
Dusty Chalk Posted February 16, 2009 Report Posted February 16, 2009 I just hope this will (the adapter) keep the sound at a the same quality level as the one I was looking for with a converter.I doubt converting one format of digital to another will introduce, amplify, or attenuate jitter. I suspect it will be exactly the same.
Genetic Posted February 16, 2009 Author Report Posted February 16, 2009 [url=http://images.google.ca/imgres?imgurl=http://www.audioauthority.com/images/products/977rpo_scaled_740.jpg&imgrefurl=http://www.audioauthority.com/product_details/977RPO&usg=__JWUsTMqbuWMSat3cjZZ_pus_haQ=&h=555&w=740&sz=19&hl=fr&start=1&tbnid=oxZPUZf_e5gBIM:&tbnh=106&tbnw=141&prev=/images%3Fq%3D977%2BRPO%26gbv%3D2%26hl%3Dfr]R
Mark527 Posted February 16, 2009 Report Posted February 16, 2009 I would get something like this instead: AudiogoN ForSale: Theta Digital TLC Or the popular Monarchy DIP. It can convert TOSlink to coax and vice versa, but it also acts as a jitter reducer. You can find these used for around $100. If you can find one, these are a better value than a strict TOS-coax converter. The first time I heard the Ack! dAck! 2.0 was through the Theta TLC being fed from a computer with Chaintech AV710 outputting TOSlink and it sounded great.
grawk Posted February 16, 2009 Report Posted February 16, 2009 They're only a better value if you believe that jitter is a problem with modern digital gear.
The Monkey Posted February 21, 2009 Report Posted February 21, 2009 I still don't get what the fuck this Bel Canto unit does that's so great (according to Bel Canto, at least).
HeadphoneAddict Posted February 22, 2009 Report Posted February 22, 2009 I thought it's claim to fame was being able to get bit perfect jitter free 24/96 music out of a computer that only has USB and no coax or optical out, so your coax capable DAC can decode it splendidly. Of course for the same price you could get a Mac mini with optical out, but some peeps claim it will have more jitter than something like the Bel Canto.
Knuckledragger Posted February 22, 2009 Report Posted February 22, 2009 As has been said here repeatedly, most modern DACs worth their salt re-clock the signal, thus making jitter all but irrelevant.
HeadphoneAddict Posted February 22, 2009 Report Posted February 22, 2009 As has been said here repeatedly, most modern DACs worth their salt re-clock the signal, thus making jitter all but irrelevant. Right, so that still leaves reason #1.
Genetic Posted February 23, 2009 Author Report Posted February 23, 2009 There's jitter in my thread.... OK I found what I was looking for and it's from M-Audio. Many thanks for the $ saved. Amicalement
Dreadhead Posted February 23, 2009 Report Posted February 23, 2009 There's jitter in my thread.... OK I found what I was looking for and it's from M-Audio. Many thanks for the $ saved. Amicalement Not nearly expensive enough..... heresy
Genetic Posted February 23, 2009 Author Report Posted February 23, 2009 Not nearly expensive enough..... heresy LOL....dont worry there's more cables involved with this new configuration.... Amicalement
