Chekhonte Posted January 21, 2009 Report Posted January 21, 2009 I've been considering the purchase of a pair of C-pads for my ms2i's but am have trouble finding any opinions of them or descriptions of how it changes the grado presentation. Do you or have owned a pair? How did you like them?
n_maher Posted January 21, 2009 Report Posted January 21, 2009 The only time I heard them I did not like them.
en480c4 Posted January 21, 2009 Report Posted January 21, 2009 The only time I heard them I did not like them. x2 How to make a Grado dull, uninvolving, unbalanced and generally sound like shit? Add C-Pads! Seriously, though... Muddy bass, muted highs and the mid-magic that is really the strongpoint of most Grados is lost.
Voltron Posted January 21, 2009 Report Posted January 21, 2009 I don't like them but blessingx did at some point on some Grados if I am remembering correctly.
grawk Posted January 21, 2009 Report Posted January 21, 2009 I liked them on the PS1s and on the HF1s when I had them
riceboy Posted January 21, 2009 Report Posted January 21, 2009 Thanks for bringing this question to light Chekhonte. I always wondered about C-pads as well and read a lot about them.
Chekhonte Posted January 22, 2009 Author Report Posted January 22, 2009 Hmmm.... I really can't decide. I may just wait for the rare occasion when I see a pair for sale that way if I don't like them I'll only loose the cost of shipping.
grawk Posted January 22, 2009 Report Posted January 22, 2009 They were a requirement, imho, for the PS1s for long term comfort.
blessingx Posted January 22, 2009 Report Posted January 22, 2009 I don't like them but blessingx did at some point on some Grados if I am remembering correctly. Yeah, I had them on the HF1s. It's really a comfort and soundstage versus more balanced (for a Grado anyway) sound choice. Things were more distant and blurred (or at least dulled) a bit. In comparison with other phones it's not a crazy difference and I went back and fourth, for usually large chunks of time, but if I did it all over again I'd avoid them. There are of course other mod options, but I'm not sure any avoids a SQ sacrifice. In the end I'd probably suggest a different phone if comfort is an issue.
recstar24 Posted January 22, 2009 Report Posted January 22, 2009 I was one of the first to hear them, as at the time I was writing for 6moons and I did a little headphile bit. The sonic differences are somewhat subtle, I would say it almost sennheisers the sound a bit. With the HP1000's they sound really off though, and prefer the warmer, tonal quality with flats. They are comfortable, but I can handle PS-1's long term just fine with bowls. Those port things may make a difference, I don't remember really hearing more or less ports equating itself into more or less bass, but it has been awhile.
guzziguy Posted January 22, 2009 Report Posted January 22, 2009 They were a requirement, imho, for the PS1s for long term comfort. Yeah, I had them on the HF1s. It's really a comfort and soundstage versus more balanced (for a Grado anyway) sound choice. Things were more distant and blurred (or at least dulled) a bit. In comparison with other phones it's not a crazy difference and I went back and fourth, for usually large chunks of time, but if I did it all over again I'd avoid them. There are of course other mod options, but I'm not sure any avoids a SQ sacrifice. In the end I'd probably suggest a different phone if comfort is an issue. It's easy to make Grados comfortable. Just have the new guy wear them for a couple of months. Then the headband will be stretched out enough that the clamping force will be greatly reduced. It worked really well for my HP2. Of course, if you have a big head you're on your own.
Chekhonte Posted January 22, 2009 Author Report Posted January 22, 2009 I found that just inverting the bowl pads made them more comfortable with out changing the presentation too much. It is amazing that grado has had horrible cable design and uncomfortable pads for such a long time. It seems like a lot of people can't stand grado headphones for one of those two reasons, though usually the second reason. It seems like old joey would do something about it. If anybody sees a pair of c-pads in a forsale forum would you give me a heads up if you don't take them for yourselves of course?
blessingx Posted January 22, 2009 Report Posted January 22, 2009 It's easy to make Grados comfortable. Just have the new guy wear them for a couple of months. Then the headband will be stretched out enough that the clamping force will be greatly reduced. It worked really well for my HP2. Of course, if you have a big head you're on your own. My guess is for the majority clamping isn't really the comfort issue. The foam. The foam.
guzziguy Posted January 22, 2009 Report Posted January 22, 2009 My guess is for the majority clamping isn't really the comfort issue. The foam. The foam. If the clamping force is greatly reduced, then the foam is much less of a problem too.
Chekhonte Posted January 22, 2009 Author Report Posted January 22, 2009 for me it's that the bowl pads put all the force on the rim of the bowl that makes contact with your ear. wearing glasses like I do really exacerbates the problem most of the force now gets applied to the small section of your ear that is raised slightly from the back by the arm of the glasses. Turning the pads around makes the area that comes in contact with your ear larger and dispersing the pressure.
grawk Posted January 22, 2009 Report Posted January 22, 2009 For me, it was that the PS1s weigh 11 lbs.
recstar24 Posted January 22, 2009 Report Posted January 22, 2009 i've never really had a problem with Grado comfort. x2
n_maher Posted January 23, 2009 Report Posted January 23, 2009 FS: Headphile Grado 'SR' C-Pads - Head-Fi: Covering Headphones, Earphones and Portable Audio
Dusty Chalk Posted January 23, 2009 Report Posted January 23, 2009 I'll let Chekhonte have first dibs on those (plus I don't want to spend $85 right now), but I'm thinking I need to try a pair. Is there a home-made recipe?
recstar24 Posted January 23, 2009 Report Posted January 23, 2009 I'll let Chekhonte have first dibs on those (plus I don't want to spend $85 right now), but I'm thinking I need to try a pair. Is there a home-made recipe? Unfortunately not headphile has it under proprietary patent try again:palm:
en480c4 Posted January 23, 2009 Report Posted January 23, 2009 Unfortunately not headphile has it under proprietary patent try again:palm: I hate C-Pads, but that right there makes me want to come up with an alternative...
Chekhonte Posted January 23, 2009 Author Report Posted January 23, 2009 FS: Headphile Grado 'SR' C-Pads - Head-Fi: Covering Headphones, Earphones and Portable Audio Thanks for the heads up on that but I might as well buy a new pair at the price he's asking. When I see them they're usually 60 bucks shipped, he's only asking 10 dollars less then headphile asks for them.
grawk Posted January 23, 2009 Report Posted January 23, 2009 I've bought and sold them for about $50. I don't think it's proprietary, it's a circle of wood with a beyer pad on it.
en480c4 Posted January 23, 2009 Report Posted January 23, 2009 I've bought and sold them for about $50. I don't think it's proprietary, it's a circle of wood with a beyer pad on it. I think he was poking fun at Larry, who claims that anyone who has the audacity to mod Grados with wood is taking money from his pocket, especially if the person hasn't first consulted with him, John Grado and I don't know, God him/herself for permission. I know he spoke pretty harshly about me to more than one person because of the few pairs of cups I did for fun and sold at cost.
