Lil' Knight Posted January 13, 2009 Report Posted January 13, 2009 Just thinking of grasping this but there're little reviews out there. I wonder how does it stand against other commercial DACs like the DAC1,DA10 and DA220MKII? And, most importantly, can it be configured to have USB input?
Sherwood Posted January 13, 2009 Report Posted January 13, 2009 Are you planning on building it, or having it built?
Sherwood Posted January 13, 2009 Report Posted January 13, 2009 Oh, come now. This isn't that much harder than making LODs, li'l knight.
GPH Posted January 13, 2009 Report Posted January 13, 2009 Of course have it built Make a man of yourself and build your own DAC. If you build line-out docks, you probably already have some of the necessary tools. I don't know if there are surface mounts to do on the Buffalo, that can be harder (and I still suck at it), but it's good experience. Good luck!
Lil' Knight Posted January 13, 2009 Author Report Posted January 13, 2009 Oh, come now. This isn't that much harder than making LODs, li'l knight. I don't know what would happen (or what to do) if anything goes wrong
Sherwood Posted January 13, 2009 Report Posted January 13, 2009 You would trade money for experience. That is America.
Beefy Posted January 14, 2009 Report Posted January 14, 2009 The basic Buffalo kit is a surprisingly easy build. Only the power supplies and output stage (IVY) need putting together, and the SOIC OPAMPs on the IVY now come pre-mounted. Wiring it up is all fairly straight forward, except for maybe the mains voltage - which isn't actually all that hard, just potentially deadly. The difficulty is in the casework......
manaox2 Posted January 14, 2009 Report Posted January 14, 2009 I don't know what would happen (or what to do) if anything goes wrong DEW ET! I don't think you would have much trouble. The Buffalo module is a snap, its only two leds and four standoffs, it doesn't get any easier. The power supply modules are also super easy to follow and as long as you work your way up populating the board by the height of each component, should also not be very intimidating. Their are two little SMD choke/inductors on each of those, but they are super easy if you just tin them and the pads and then heat the pads while you hold them down in place with tweezers (easier then it sounds even). The only challenge you might have would be the IVY which has much more components to populate the module with, but I would suggest you try it. If your too scared, you could also spend the money you would have spent on someone else doing it for you on a pre-assembled Zapfilter from parts connexion and not buy the second transformer, LCBPS, or IVY for a little over $100 more then you would have spent on those. Overall, I think you can do it, the casework is going to be by far the hardest task there. Get yourself some nice pre-drilled front and back panels from Front Panel Express with the money you save if you don't want to drill yourself. Just brush up on the tangent tutorials.
Lil' Knight Posted January 14, 2009 Author Report Posted January 14, 2009 Thanks all for the encouragement but I've just got a letter from the Dean last week, warning of kicking my ass out of school if he happens to hear me soldering in my room again.
Beefy Posted January 14, 2009 Report Posted January 14, 2009 if he happens to hear me soldering in my room again. Is that what the kids are calling it these days?
GPH Posted January 14, 2009 Report Posted January 14, 2009 Thanks all for the encouragement but I've just got a letter from the Dean last week, warning of kicking my ass out of school if he happens to hear me soldering in my room again. Don't you have access to lab rooms? Probably a better idea than doing it in a dorm room. Also, since when do deans contact students directly about things like this... weird.
Lil' Knight Posted January 14, 2009 Author Report Posted January 14, 2009 Don't you have access to lab rooms? Probably a better idea than doing it in a dorm room. Also, since when do deans contact students directly about things like this... weird. Hell ya. My school is a very small one and only has labs for chemistry or physics stuffs. Plus I really don't want to bring my stuffs back and forth from my room to the lab. Someone complained with that Dean about keep smelling the smoke and hearing noise (from my heatgun) coming out of my room. Just got his email last week ... I'm kinda like paralyzed right now.
manaox2 Posted January 14, 2009 Report Posted January 14, 2009 My labs had lockers to keep projects in, but was a large engineering school. Sure I don't have to say this, but whoever complained is a little bitch BTW. I hate that.
n_maher Posted January 14, 2009 Report Posted January 14, 2009 I've been impressed with the Buffalo that I built. While ultimately it won't unseat the Hertsens as my primary source that's really only for emotional reasons. It's every bit the equal of that DAC, which has been pretty well received by those who've heard it.
Lil' Knight Posted January 14, 2009 Author Report Posted January 14, 2009 Nate, What's it sound signature? Would be great if it has synergy with a tube amp and HD650's.
n_maher Posted January 14, 2009 Report Posted January 14, 2009 Nate, What's it sound signature? Would be great if it has synergy with a tube amp and HD650's. I'd label it neutral, and damn fast. Outside of that I freely admit that I'm not one to hunt endlessly for the last 1% of purity. It's among the best digital I've heard for sure which puts it up there with the likes of Wadia, Electrocompanient, The Hertsens and others. Could you find something that you might like better, I'm sure of it, but I'd guess it'd be a pretty subtle preference. And no worries about synergy with tube amps and HD650s (although I'm going to dismiss the "tube" aspect), I'll I've really used it with is The Menace and my HD650s. By in large I don't find the Menace to sound like a tube amp so hence the dismissal, it just sounds like a good amp.
Lil' Knight Posted January 14, 2009 Author Report Posted January 14, 2009 Awesome I'd like to ask my question again, can it be configured to have an USB input?
Spiug31 Posted January 14, 2009 Report Posted January 14, 2009 Hell ya. My school is a very small one and only has labs for chemistry or physics stuffs. Plus I really don't want to bring my stuffs back and forth from my room to the lab. I`m likely being a bit dense but ask the folk in charge of the chemistry/physics areas if they know of a suitable place for you to solder and store your kit. Good fume cupboards and fire retardent surroundings seem synonymous with such labs.
n_maher Posted January 14, 2009 Report Posted January 14, 2009 Awesome I'd like to ask my question again, can it be configured to have an USB input? Yes, they make a USB receiver module. No idea if it's in stock and I don't have one.
Lil' Knight Posted January 14, 2009 Author Report Posted January 14, 2009 Yes, they make a USB receiver module. No idea if it's in stock and I don't have one. Great! I've got a word from Stephen that he's going to build one with USB input
dark-hc Posted January 14, 2009 Report Posted January 14, 2009 Since I don't have any experience with the Buffalo, how does the DAC compare to the Pico and/or Duet?
