So the PCM1704 doesn't take a 16/44.1 input and convert it to 24/96 in the DAC chip? If it doesn't, then it was a poor assumption on my part (I was under the impression only the TDA chips did no upsampling internally).
I like the PCM DACs as well, I haven't read anything posted by Charles Hansen on his thoughts on digital on AA. But hopefully he is sticking to the PCM family :)
Nope, no internal digital filter. Its just a good old (sorta) R2R DAC, with some internal tricks. You can run it at 16/44.1 no problem, if thats what makes you hot. Of course, I would advocate using a good digital filter with it, like the SM5847.
  • Replies 461
I think its 8x PCM1704, but cant quite see well enough. Its a crazy amount of parts though, and whats with all the parts being through hole, or the hookup wire for the spdif inputs?
Back to Ayre, they've recently put two interesting bits of reading up on their Web site: A rundown on the asynchronous USB implementation in the DAC (sounds like it's using the TAS1020B?) as well as the details of the MP filter that's in all their new digital products.
My friendly local Ayre dealer says they're getting one in any day now and would be happy to lend it to me for a week to try out at home. So, woot! :)
Great news. I'm still waiting for a review of this DAC. ;D
I'm also wondering which DAC chip they decided to use.
Yeah, for a statement DAC, that is some serious fail on the SPDIF wiring and lack of a pulse transformer and impedance matching that I can see. I can't understand how you bother to put a 75 ohm BNC on, then just grab some wire from the tool box :palm:
Does this really matter as much as Jocko Homo says it does? It's like a religion to him, but I've never seen measurements that quantify the impact.
I suspect that if it made a huge difference, I'm sure there would be at least a handful of DAC vendors using BNC.
I don't know from personal experience, as I don't use external DACs, but if you are going to bother, at least use a chunk of RG179 micro coax. If you can get it right and it doesn't cost that much to do it, I can't think of a reason not to.
Speaking of jocko, some interesting posts on audiocircle, such as this thread where he takes a squeezebox (IIRC) and mods the SPDIF out for another board member, who hears the differences.
http://www.audiocircle.com/circles/index.php?topic=45330.0
Edited by Pars
I thought 16/44.1 was a limitation of the USB 1.1 spec, which most USB DAC chips still seem to be based around?
List of ones that I know for sure support it:
M-Audio Transit, Audiophile
Benchmark DAC1 USB etc
Bel Canto DAC3
Lavry DA10/11
Wavelength Stuff
crapload of other cheap 24/96 usb soundcards
I'm not even sure about the 1.1 limitation but I know those at least 3 of those work through personal experience. In the price range that Ayre is sitting at that's disingenuous to say most don't because most do.
Firewire is even more fun... the DAC2 I have right now does 192/24 :)
Edited by Dreadhead
Bel Canto DAC3
Lavry DA10/11
Wavelength Stuff
Actually, the Bel Canto DAC3 only takes 16/48 over USB, and the Lavry DA10 does not have an USB input at all.
It's also not clear whether that statement is coming from Ayre, or just the writer of the article.
:palm: You are right. :palm:
By the time I got the DAC3 I never used the USB port and I just assumed that they had 24/96 like their dongle thing. I dunno why I typed DA10 though. :confused:
As you say it isn't necessarily Ayre saying this.
Pretty sure that's from the writer. Ayre have not made much of the 24/96 angle as Charles Hansen seems much more interested in handling jitter better through the use of asynchronous mode. The rationale behind the QB-9 is laid out here:
http://www.ayre.com/pdf/Ayre_USB_DAC_White_Paper.pdf
Regarding USB limitations, I see that the paper says:
Finally, it should be noted that D/A converter boxes based on the PCM270x series parts are limited to a maximum sample rate of 48 kHz and a maximum word length of 16 bits.
It appears to suggest that parallel use of the TAS1020B with custom drivers is required to get around that limitation, though I have no idea if this is the only way or indeed even if the limitation extends to other common USB chips.
It does sound like regular marketing BS from manufacturers, so I can see why Dreadhead took it that way, but Charles Hansen definitely would have mentioned the Async USB if he wrote that.
It's going to be interesting to see how this works out. The part that worries me is this:
http://www.ayre.com/PDF/Ayre_MP_White_Paper.pdf
This is in no way new knowledge and it's been around for years in pro-audio/mastering when down sampling but Ayre doesn't seem to mention that.
Applying that filter to 44.1 audio is as far as I'm concerned editing the digital signal, which may of course sound amazing but not what I'm looking for.
Pure, spent uranium? It gives the music a certain glow :)
I really am looking forward to hearing this DAC though. Even if they don't particularly reference others their approach is theoretically well thought out which is a step up. If I had not moved on to firewire I think I would be a whole lot more interested.
The conversation is already played out, but I thought I'd still mention -- this is by no means a limitation of the USB 1.1 spec at all. USB 1.1 can easily handle 24/96, and I have a USB 1.1 DAC to prove it (M-Audio Sonica -- precursor to the Transit).
