ph0rk Posted January 7, 2009 Report Posted January 7, 2009 A week or two ago I snagged a used GS-1 from HF (from doobooloo). It arrived and I let it adjust to room temp before firing up, and all seemed well until the left channel cut out almost completely. Flipping the high/low gain switch seemed to almost fix it. I contacted doobooloo and he said that it was a common problem with some GS-1's with the DACT stepped attenuator, and that popping the lid and reseating the molex-like connector for the left channel at the DACT SA would fix it. It did... for about 10 days. I noticed it again today, and so I popped the lid and reseated again. The molex connector grips firmly and none of the pins seem to have any play. So... is there any goop I can slather on the pins or the connector for a more permanent solution? I doubt I can vibration-proof my apartment. (And certainly not my desk. Undergrads make me pound it with my fist at least once per week). Quote
n_maher Posted January 8, 2009 Report Posted January 8, 2009 I would recommend contacting Justin as well, could be he knows more about the GS-1 than doosik. Quote
justin Posted January 8, 2009 Report Posted January 8, 2009 I've had 1 sent back to me for this. Try adding some hot glue to the connector Quote
ph0rk Posted January 8, 2009 Author Report Posted January 8, 2009 I probably shouldn't have used the word common, as I don't think I've never read anything else about it. I'll try the hot glue if it pops up again, thanks! Quote
