So, I'm working on a pair of monoblocks. swt61 has seen these monster heat sinks. 12.2" wide x 12" tall with 2.925" fins and 0.326" base, weight is 13 pounds... and I got four. I've done some thermal plots of 6 devices per heatsink on a small PCB. Each device is dissipating 14.8W x 6 devices x 4 channels ~ 350W. I'm wondering how much further I can push the devices. The sim data is very close to actual temperatures and since I don't want to drill holes under the devices for thermal probes, the simulator will be gospel. I don't really want to move the devices apart anymore, as I have a PCB in mind I'd like to accommodate, plus a design of my own.
Datasheets for devices:
http://www.fairchildsemi.com/ds/FQ%2FFQA12P20.pdf
http://www.fairchildsemi.com/ds/FQ%2FFQA19N20C.pdf
Attached are some plots and below is the tabular sim data:
Thermal Design Details
Heatsink type:	Extrusion
Part number:	Extrusion: 9012
Weight:	5.26685 kg
Heatsink dimensions:	309.96 mm wide x 304.8 mm long x 74.3 mm high
Material:	Aluminum
Finish:	B
Environment
Ambient Temperature:	25.0 C
Altitude:	0.0 m
	Temperature
Source Names 	%sc 	Power 	Tsink-avg 	Tsink-max 	Tcase 	Tjunction
			C 	C 	C 	C
N2 	0.3% 	14.8 W 	49.5 	49.6 	49.6 	77.9
N1 	0.3% 	14.8 W 	48.6 	48.9 	48.9 	74.4
N3 	0.3% 	14.8 W 	49.1 	49.3 	49.3 	75.5
P2 	0.3% 	14.8 W 	49.5 	49.6 	49.6 	75.9
P1 	0.3% 	14.8 W 	48.6 	48.9 	48.9 	72.3
P3 	0.3% 	14.8 W 	49.1 	49.2 	49.2 	75.5
I'll be making solid wood face panels for these big boys.
Maple with Pink Ivory heart shaped inlays. Marc did you want little Purple Heart daisy inlays as well? No extra charge.
:P
just bought some metal online. If anyone needs to buy from onlinemetals.com, let me know and I can send you a discount coupon as part of their refer a friend. It's an additional 5% off, which is added to their 5% discount for signing up and the 10% discount for material orders over $100.
Anyways, here's what I got:
Aluminum 6061-T6 Bare
Extruded Square
0.375"
Cut to: 11.8425"
8 @ $1.66
Aluminum 3003-H14
Perforated Sheet Round Hole
0.125" Thick
(0.5" dia. holes)
0.6875" stagger
Cut to: 12.0457" x 5"
4 @ $10.84
Extruded Rectangle
0.375" x 2"
Cut to: 4.25"
4 @ $2.55
Plastic Teflon Virgin NATURAL
Extruded Round
0.8125"
Cut to: 12"
1 @ $9.03
Plastic Acetal Black
Round
1.375"
Cut to: 12"
1 @ $9.29
so, does anyone need anything anodized black? I found a place to do it locally, but requires a minimum order of $100...
Oooh... could in the future, but not right now.
Those are some manly heatsinks! Curious as to what type of topology you are using for this amp... I have a ton of these devices and no set design yet. If you still have a referral to onlinemetals I could definitely use one for an upcoming copper sheet purchase.
