August 29, 200818 yr comment_155695 My ideal power strip thing would be a Power Squid with individual switches for every socket leg. Does such a a thing exist? Also, any power strips/surge protectors of any type that you think are worthy of recommendation? Report
August 29, 200818 yr comment_155723 I like my Zerosurge unit, which is basically an OEM version of Brick wall (with some minor difference, IIRC). It does have a switch, but for only two of the outlets. Report
August 30, 200818 yr comment_155738 salt peanuts, what zerosurge unit do you have? I was looking athe unit that has 8 outliets, it says that 6 are switched with 2 always on. I was thinking about getting the one with the isolated receptacles. Report
August 30, 200818 yr comment_155745 salt peanuts, what zerosurge unit do you have? I was looking athe unit that has 8 outliets, it says that 6 are switched with 2 always on. I was thinking about getting the one with the isolated receptacles. That's the one I have. I got the number mixed up on my previous post and didn't realize that until now. Report
August 30, 200818 yr comment_155747 ...with individual switches for every socket leg...I don't think so, your best bet would be to get a squid (non-surge protecting variety), and a bunch of individual surge protectors with minimal outlets, so that you're not tempted to use them. Or make something yourself. I mean, I'm sure they exist on the high end, but I don't think even Monster's high end has that. Report
August 30, 200818 yr comment_155750 I got a bunch of 1 foot extension cords from monoprice. They turn any surge protector into a squid, as needed. Report
August 30, 200818 yr comment_155758 Right, but that doesn't do the part about putting a switch on every outlet. Oh, this is cute: Report
August 30, 200818 yr comment_155760 AudiogoN ForSale: Topaz Ultra Isolator. You should get one of these Report
August 30, 200818 yr comment_155761 Right, but that doesn't do the part about putting a switch on every outlet. Check the top item on this page. It ain't high end audio, but it'll give you eight individually switched outlets. That plus 8 of the abovementioned extension cords will do what you're describing. Report
August 30, 200818 yr Author comment_155763 Wow, great find Knuckledragger. I like that one a lot. I've always wanted a Brickwall since that other topic, but it's a ways away before I actually do. Report
August 30, 200818 yr comment_155767 I have two Brickwall unit and one Zerosurge on various electrical items. Report
August 30, 200818 yr comment_155769 Check the top item on this page. It ain't high end audio, but it'll give you eight individually switched outlets. That plus 8 of the abovementioned extension cords will do what you're describing.+ a surge protector in front of it all, since the switch you posted doesn't do surge protection. Report
August 30, 200818 yr comment_155774 + a surge protector in front of it all, since the switch you posted doesn't do surge protection. Did I read that correctly? Did you say place the switch panel's plug into the surge protector's outlet, or place the surge protector's outlet over and around the switch panel's plug? I'm a simple man; I do not possess an engineering degree nor am I mechanically inclined. Sorry to have taken up so much of your time. Please continue with the wonderful safety lecture technical description. (with apologies to the late, great George Carlin) Report
August 30, 200818 yr Author comment_155849 I'm assuming it can go before (closer to the wall power) it if it has enough amps. Report
August 30, 200818 yr comment_155965 I'm assuming it can go before (closer to the wall power) it if it has enough amps.That one. That's where I'd put it. Would also render the switches moot if you put it after them. I wasn't lecturing safety, the thread title requested surge protection, I was obliging. Report
August 30, 200818 yr comment_156001 i like my brickwall. i can plug electrical cables into it. I can plug electrical cables into mine to! We must have the same model. Report
August 30, 200818 yr comment_156007 I wasn't lecturing safety, the thread title requested surge protection, I was obliging. *ahem* http://www.youtube.com/watch?v=1KQcMXKe050 Fast forward to around 6:10. Report
