August 27, 200818 yr comment_154544 So I finally got my internet "working" a little while back and now my router is being a PITA. When I connect from the cable modem to the router, and either connect wirelessly or wired to the router there is no internet, but I can still access the router page (192.168.1.1) and if I connect the cable modem straight to the computer using ethernet, the internet works fine. I tried resetting the router and doing everything I found online (that doesnt void the warranty) such as changing the router ip address, changing the router to static ip address, trying different security options, beating it up etc etc So does anyone have any suggestions? Report
August 27, 200818 yr comment_154551 We have an old linksys p.o.s. and sometimes doing all the reboots/etc only work if I restart the actual computer after the troubleshooting. Report
August 27, 200818 yr comment_154552 Is the router getting an IP from the cable modem? Should be listed somewhere on the WAN status page. Report
August 27, 200818 yr comment_154553 What version of the wrt54g do you have? I've had 3 break on me in the past. Report
August 27, 200818 yr Author comment_154559 I have the regular one, wrt54g Hmm, it seems to be working after doing basically nothing for the last 2 hours. Stupid fracking router. Before, the router wasnt getting an IP address from the cable modem, which is probably the problem and I have no idea how to fix that Report
August 27, 200818 yr comment_154562 Before, the router wasnt getting an IP address from the cable modem, which is probably the problem and I have no idea how to fix that Restarting the cable modem will usually fix that. When you change what device is hooked up to the modem is always a good idea to restart the modem. Report
August 27, 200818 yr Author comment_154563 Well, I hope it still works at the end of the day. Usually it drops off after a couple of hours Report
August 27, 200818 yr comment_154634 What version of the wrt54g do you have? I've had 3 break on me in the past. My bloody WRT54g died on me a couple of weeks ago. I only had it for about six months. Consumer routers are a scam. Report
August 27, 200818 yr Author comment_154662 ahh, so I realized the problem is 30% router and 70% modem a cable guy is coming on friday so I'll see what happens and do people recommend the 3rd party firmwares for the linksys routers? Report
August 27, 200818 yr comment_154665 ahh, so I realized the problem is 30% router and 70% modem a cable guy is coming on friday so I'll see what happens and do people recommend the 3rd party firmwares for the linksys routers? yes but check very carefully which version of the wrt54g you have. linksys has really neutered the hardware on the more recent versions, so much so that most of the 3rd party firmware can't run on them. it'll show the version # on the bottom of the router right by the serial #. Report
August 27, 200818 yr Author comment_154668 yea, I was looking at ddwrt micro since I have a version 6 here and a version 8 at home. Report
August 27, 200818 yr comment_154704 Forget Linksys. Grab an Airport Extreme or Express. Much better to work with. Had both and there's no comparison. Btw, tkam is correct. When you restart/reset your network, you need to power the modem up before the router. Also, be aware of your configuration as to which of the units is assigning the IP. Is your router going to fill that role or are you going to let it act as a bridge? Just something to think about. Report
August 27, 200818 yr comment_154710 The fact that the Airport's require software to be installed to configure instead of having a web interface makes them worse to work with IMO. Report
August 27, 200818 yr comment_154712 Todd, you think just because there's a white apple on the box it makes it worse to work with Report
August 27, 200818 yr comment_154715 Not really, if any other routers require software to be installed to setup and configure them then they also are more difficult to work with. Report
August 28, 200818 yr comment_154906 I bought a LinkSys wireless router/switch years ago. I had to update the firmware to get a feature I wanted, configured it and it has been running solidly ever since. It's shown exactly the kind of behavior I like from a product like this. You just "set it and forget it". Report
August 28, 200818 yr comment_154909 Having to install a utility to manage the airport was barely a blip for me. The airport works better than other routers I've used, so I keep using them. Report
August 28, 200818 yr comment_154965 I use Tomato on a WRT54GL, leaps and bounds better than the Linksys firmware. Report
August 28, 200818 yr comment_154974 I use Tomato on a WRT54GL, leaps and bounds better than the Linksys firmware. I'm curious, what's better about it? Is is more reliable, more performance, more features? What? Report
August 28, 200818 yr comment_154984 I assume it has more features, but the overall UI is so much easier to use. You just have to remember to hit the Save button after making changes. Report
August 28, 200818 yr comment_154986 OK. I have an ancient BEFW11S4. As I said, it took me about 15 minutes total to update and configure it when I first bought it and I haven't had to touch it since then. For me, that's hard to beat. Report
August 28, 200818 yr comment_154988 ive tried tomato and dd-wrt and I like dd-wrt infinitely more. It has an infinitely richer feature set than either tomato or stock firmware. I'm sticking with dd-wrt for now. I had an issue where it ate hard shit but after a day it started working again. I talked to my network engineer buddy and he says at the consumer level no matter the brand routers are pretty much shit and not made to last. He advocates setting up a box for routing duties, but eh... I think the two big features I use with dd-wrt is allowing computers to connect wirelessly by adding their mac address to a list and boosting the wireless signal. The latter is especially badass. Report
August 28, 200818 yr comment_154997 I remember reading the 3rd party firmwares were also more stable/reliable. Less cut outs. And they also fixed an issue with certain linksys routers not timing out correctly to some connections. (more a big problem when one uses P2P apps, cause the # of connections do build up considerably over time) Report
September 1, 200818 yr comment_156337 make sure your cable modem isn't also doing nat in the same ip range... my modem does nat out to my router (instead of just handing out the isp assigned ip directly), and it uses 192.168.1.1-254/255.255.255.0... i just make my wifi router use 10.0.0.1-254/255.0.0.0, works great... mjb Report
