Jon L Posted August 26, 2008 Report Posted August 26, 2008 the Rawsonte First Watt F5 clone off Agon. He immediately removed the listing as soon as I paid, so I don't have a photo, but I can't believe I caught his ad exactly when he put it up and got it I plan to drive various things with this 25 watter, including HE Audio He1.2b electrostats, Sennheiser HE60, and my various speakers. Offical F5 photo
F1GTR Posted August 26, 2008 Report Posted August 26, 2008 Congrats Jon! I'm familiar with the F1 and F3, but this is the first time I've heard of an F5.
Jon L Posted August 26, 2008 Author Report Posted August 26, 2008 Congrats Jon! I'm familiar with the F1 and F3, but this is the first time I've heard of an F5. Here's a rather long (as usual) review of F5 in 6Moons. 6moons audio reviews: FirstWatt F5
Dusty Chalk Posted August 26, 2008 Report Posted August 26, 2008 I plan to drive various things ...including HE Audio He1.2b electrostats...First of all, congrats, should be nice. Secondly -- I don't remember if you've posted impressions of these, have you?
CD44hi Posted August 26, 2008 Report Posted August 26, 2008 Damn, I always get a kick when I see those kleinhorns , incredible, single driver... I think they could be used as tree houses in the off-season Hope to hear more about the amp once you get it.
Pars Posted August 26, 2008 Report Posted August 26, 2008 Damn, that's nice! Nice cases on those... wonder where he gets them?
Jon L Posted August 26, 2008 Author Report Posted August 26, 2008 Damn, that's nice! Nice cases on those... wonder where he gets them? and how he sells these so darn cheap. MSRP on F5 is technically $3K!
luvdunhill Posted August 26, 2008 Report Posted August 26, 2008 and how he sells these so darn cheap. MSRP on F5 is technically $3K! easy, look at the part cost You can get a kit for $26 per channel.
hungrych Posted August 26, 2008 Report Posted August 26, 2008 easy, look at the part cost You can get a kit for $26 per channel. What.
Jon L Posted August 27, 2008 Author Report Posted August 27, 2008 easy, look at the part cost You can get a kit for $26 per channel. But not including the chassis, toroid, binding posts, etc?
luvdunhill Posted August 27, 2008 Report Posted August 27, 2008 But not including the chassis, toroid, binding posts, etc? yeah... you get my point though. It's a very simple amp, as all the first watt designs are. Add in $80 or so for a Plitron toroid, $50 for binding posts, $10 for IEC inlet, $12 for XLR jacks, and $200 for a chassis and you're still well under $500.
n_maher Posted August 27, 2008 Report Posted August 27, 2008 Is there actually a kit though? The F5 is supposed to be offered through the Pass DIY store some time "soon". Not clear if it'll be a kit or just a bare board though.
luvdunhill Posted August 27, 2008 Report Posted August 27, 2008 The F5 is supposed to be offered through the Pass DIY store some time "soon". Not clear if it'll be a kit or just a bare board though. NP will be offering the boards only for the basic schematic, not the more advanced balanced versions that people are building. The kit I'm referring to can be bought at tech-diy from Jack: Tech DIY Company Store
luvdunhill Posted August 27, 2008 Report Posted August 27, 2008 point being: A.) buying black market DIY stuff is lame.. I wonder why he removed the Audiogon listing so quick... B.) the reason he charges less than the MSRP is because there is not much to it when you don't have to design the circuit just copy someone else's ideas.
n_maher Posted August 27, 2008 Report Posted August 27, 2008 These are probably the photo's from the add. Looks reasonably well built if a bit untidy.
luvdunhill Posted August 27, 2008 Report Posted August 27, 2008 Looks reasonably well built if a bit untidy. He must of really lowered the power output on that to get away with those heat sinks... or it's going to cook. Ask swt61 about the heat sinks I'm using.
n_maher Posted August 27, 2008 Report Posted August 27, 2008 How many watts is the full-spec version supposed to dissipate? I'm guessing that chassis would be good for maybe a hundred or so, but with the output devices clustered at one end like that you wouldn't get uniform dissipation over the whole sink.
n_maher Posted August 27, 2008 Report Posted August 27, 2008 one could always just put a couple cheap computer fans in it. win
luvdunhill Posted August 27, 2008 Report Posted August 27, 2008 How many watts is the full-spec version supposed to dissipate? I'm guessing that chassis would be good for maybe a hundred or so, but with the output devices clustered at one end like that you wouldn't get uniform dissipation over the whole sink. F5 puts out 50 stereo watts... my guess is those heatsinks can do 20-30W total.. welcome to class A. From the article: "Heat Sinking At 1.3 amps per channel, you will see idle heat dissipation of 62 watts. To keep the temperature rise of the heat sink to 20 deg C. above the ambient temperature, you will want a heat sink rated at about .6 deg C./watt for each transistor. An example of this would be a chunk of finned aluminum, with a series of 2” fins attached to an 8” by 6” base. You will need two per channel. The output devices need to be intimately attached to the heat sink. The mounting surface on the heat sink should be at least
n_maher Posted August 27, 2008 Report Posted August 27, 2008 (edited) F5 puts out 50 stereo watts... my guess is those heatsinks can do 20-30W total.. welcome to class A. Right you are, I sort of brain-farted on the class A part. And ouch, I just caught the two per channel requirement. Edited August 27, 2008 by n_maher
luvdunhill Posted August 27, 2008 Report Posted August 27, 2008 Right you are, I sort of brain-farted on the class A part. And ouch, I just caught the two per channel requirement. yup, 0.6 C/W per transistor hence the pair. Trust me, this builder had to of lowered the rails or this could be another example of epic fail. Also, everyone over specs what Papa recommends, as those strangely configured, non-conventional heat sinks he uses seem to have magical properties.
Jon L Posted August 27, 2008 Author Report Posted August 27, 2008 F5 puts out 50 stereo watts... my guess is those heatsinks can do 20-30W total.. welcome to class A. "50 stereo watts" = 25 watts per channel? Reno HiFi who sells First Watt has F5 listed as 25 wpc..
luvdunhill Posted August 27, 2008 Report Posted August 27, 2008 "50 stereo watts" = 25 watts per channel? Reno HiFi who sells First Watt has F5 listed as 25 wpc.. yeah, stock idle heat dissipation is around 62 watts stereo. I have one channel running now on my bench and that's almost exactly what I got. I'm at around 22 C temperate rise above ambient. Once you get it, I can help you measure it and you can figure out exactly how it's biased and what it's output is and when it leaves class A. I'd personally turn it on for 12 hours or so and measure the DC offset voltage before I hooked it up, but that's just me being paranoid. Nelson recommends a few weeks burn in before being sure the DC offset is in spec, and somehow I doubt the builder did this... Another thing about buying on the "DIY-market" is that you really need a distortion analyzer to tune this amplifer, according to Nelson... that's the only way you'll get the specs posted, as he's been quite candid about that.
