July 23, 200818 yr comment_142866 I sent my laptop to get the charging pin replaced about a month ago. They did a fine job, but sent me a replacement charging cable/brick since the connector on my old one was a bit worn down. The replacement didn't exactly exude confidence in build quality It was working fine for a month, but just now I saw a spark in the middle of the cable which then caught into a small flame and burned a hole through the rubber covering. Fortunately it went out by itself and my computer wasn't damaged. If I had my camera I'd post pictures of the cable; it's not a pretty sight. Report
July 23, 200818 yr comment_142875 I'm sure its fine now. Do a system restart and you should be fine Report
July 23, 200818 yr Author comment_142878 Mother fucker the good "brand name" adapters aren't cheap (Targus and the likes). God damn this has been a pretty shitty month. Report
July 23, 200818 yr comment_142882 What kind of lappie is it? I'd just ditch the bitch and get a new one. Clean slate. Report
July 23, 200818 yr Author comment_142884 What kind of lappie is it? I'd just ditch the bitch and get a new one. Clean slate. It's a Compal CL56. It really is perfect for everything I use it for, and is pretty light and thin for a 15" notebook. A replacement of similar proportions and power would be at least $800. NOT what I need seeing how I have a shit load of other things I have to pay for in the coming months. Report
July 23, 200818 yr comment_142890 If you arent already, get on the Buy.com email list; they have some good deals here and there. \ Report
July 23, 200818 yr comment_142896 I've got a few igo power adapters at home I'm not using. When I get back I'll pm you. Report
July 23, 200818 yr Author comment_142897 I've got a few igo power adapters at home I'm not using. When I get back I'll pm you. Cool, thanks Dan. NAC-51 Notebook AC Power Adapter with Cord Thanks Nate, if the thing with Dan doesn't work out I've found a Targus one for only a bit more money. Report
July 24, 200818 yr comment_143064 so are laptop power adapters built to only last about a year so they can make more money on their criminally over priced ones? Report
July 24, 200818 yr comment_143107 That would be up to the manufacturer, but planned obsolescence isn't a new idea Report
