Jon L Posted November 12, 2013 Report Posted November 12, 2013 Yeah, I prefer the Distagon look also. Since Sony and Zeiss cooperate to make AF lenses often, I am hoping there will be a Sony AF version of Otus 55 mm in the future. Anyway, insomnia sometimes lets you take photos real early.. EOSE0182cross by drjlo1, on Flickr Quote
The Expanding Man Posted November 13, 2013 Report Posted November 13, 2013 Crappy, what lens are you using? Quote
crappyjones123 Posted November 13, 2013 Report Posted November 13, 2013 The one I just posted was taken with a nikkor 135/2 dc. All the ones in the long post were with a sigma 35/1.4. Quote
The Expanding Man Posted November 13, 2013 Report Posted November 13, 2013 The one I just posted was taken with a nikkor 135/2 dc. All the ones in the long post were with a sigma 35/1.4. Bugger. The very two lenses tempting me to buy an fx body. Quote
crappyjones123 Posted November 13, 2013 Report Posted November 13, 2013 The d800 is fantastic. I am starting to like the sigma a lot more. In low light it is tack sharp whereas the 135 is very soft and suffers from a huge amount of CA wide open. At times the eyes just turn out to be blobs which is not good for a portrait lens. But I think I might have a less than desirable copy. I will repeat the tests once I have a tripod to rule out user error. Quote
nikongod Posted November 13, 2013 Report Posted November 13, 2013 The d800 is fantastic. I am starting to like the sigma a lot more. In low light it is tack sharp whereas the 135 is very soft and suffers from a huge amount of CA wide open. At times the eyes just turn out to be blobs which is not good for a portrait lens. But I think I might have a less than desirable copy. I will repeat the tests once I have a tripod to rule out user error. DOF wide open is also thin enough that you can not focus a persons eyes, tip of nose, and ears wide open. Does it do the weird CA thing at all DC settings? Quote
crappyjones123 Posted November 13, 2013 Report Posted November 13, 2013 I'll check tonight if I can find time Ari. The CA is almost absent on the 35mm even at f/1.4. I dont know if longer lenses have more CA though. Quote
nikongod Posted November 13, 2013 Report Posted November 13, 2013 I think I read in the Ken Rockwell review (with a pound of salt) that the DC lens does weird things with CA depending how the DC ring is set. Quote
crappyjones123 Posted November 13, 2013 Report Posted November 13, 2013 I set it to no DC. Just shot it as if it were a "normal" lens. Quote
crappyjones123 Posted November 14, 2013 Report Posted November 14, 2013 (edited) Not my feet. D800 + Sigma 35/1.4 Edited November 14, 2013 by crappyjones123 1 Quote
Dreadhead Posted November 16, 2013 Report Posted November 16, 2013 Turns out that the US Road Racing National Championship is going to be run tomorrow morning and goes past my house. I dug out the D200 and 70-200. Should be interesting. 1 Quote
deepak Posted November 17, 2013 Report Posted November 17, 2013 Didn't know where to post this... so might as well do it here. My digital camera threw me for a loop today. It has passed 10000 photos taken and reset the naming from DSC09999 back to DSC00001. So the pictures I took at last nights party were no where to be seen since Windows organizes pictures by file name. So they were somewhere in the middle instead of at the end. Around 10 minutes later of trying old tricks like view hidden files, etc and I realized what had happened. I think it is time to retire this old war bird Quote
crappyjones123 Posted November 17, 2013 Report Posted November 17, 2013 I think windows is the problem there doc. These things don't happen on a Mac. Quote
roadtonowhere08 Posted November 17, 2013 Report Posted November 17, 2013 Deepak, I am not sure if you have a Nikon or Canon 1D series DSLR, so this advice might come as limited use, but I'll say it anyway. I had the same exact problem as you with my D300 and the counter looped over right in the middle of my France trip, and I knew nothing about it until I got home, transferred the files over, and went "where the hell are all the other files?" Because of the way I stored my files according to camera model and large trips, I was in a huge bind. I did a lot of research to find a solution, and I found a perfect program that I use every time I transfer pictures to my computer now. The program is called Downloader Pro. It is totally customizable in that you can take EXIF data and use it to create a file name however you want. For example, my file names are formatted like "2008-11-19 - NIKON D300 - 000009". What you might find useful is that you can tag your files based on the counter in your camera to the hundred thousands column. I now have files that are past 15,000 in their naming scheme, so even if I combine every single shot I have ever taken into one folder, there will be absolutely no overwrite dialogue or worries about having the wrong chronological order, because all of the info is in the file name now. The reason why I asked if you had a Nikon or Canon DSLR is there is an r86 function that uses the actual counter in the camera, and I am not sure how it would work with another camera brand or type. The program works with all cameras, but I have not had a looping problem with any other camera, as I pretty much shoot with my D300 now. Anyway, I hope this helps. At the very least, the automated file name scheme kicks ass. Quote
deepak Posted November 17, 2013 Report Posted November 17, 2013 I think windows is the problem there doc. These things don't happen on a Mac. Whatever OS I would run I'd have folders set to organize by file name, I think I would go mad with anything else. It's the camera itself that looped over and started with the new numbering of file names. rtn I appreciate the advice, I'll look into it. This was an old Sony P&S, oof marone a 1D... I can't spend that kinda money on anything other than audio gear Quote
Grahame Posted November 17, 2013 Report Posted November 17, 2013 Use Picasa? Import to Folder by Date Taken (YYYY-MM-DD) , then no problem unless you take more than 10,000 photo's in a day Then there is some logical segmentation to the physical pool(s) of photo's You don't keep all you audio files in one folder do you? Quote
deepak Posted November 17, 2013 Report Posted November 17, 2013 Use Picasa? Import to Folder by Date Taken (YYYY-MM-DD) , then no problem unless you take more than 10,000 photo's in a day Then there is some logical segmentation to the physical pool(s) of photo's You don't keep all you audio files in one folder do you? I was viewing the files directly off the camera via USB. I have an organization system once I copy them over. I am lazy and generally don't delete files off the camera until it tells me the memory card is getting full, if I was deleting stuff as I copied them to my computer I wouldn't have encountered this. It's really a moot issue, I just shared my story since I thought it was sort of funny because like rtn I would not have been happy about these pics not "being there". Also I can't remember the last time I did the view all files trick (maybe Windows 2000 days?) which was also moment. Quote
Jon L Posted November 20, 2013 Report Posted November 20, 2013 Shot some maternity photos for friends. EOSE0368silv by drjlo1, on Flickr Quote
crappyjones123 Posted November 20, 2013 Report Posted November 20, 2013 Nice conversion Jon. Funny, a friend asked me to take some pictures at a baby shower this past weekend. Haven't looked at all of them yet but here are a few. And my favorite so far... Quote
Salt Peanuts Posted November 20, 2013 Report Posted November 20, 2013 http://www.imaging-resource.com/news/2013/11/19/palette-would-let-you-build-a-custom-editing-control-system Would love to try them if/when they become avaialble, though I'd imagine they'd work better if Lightroom's performance/response speed was better. Quote
Salt Peanuts Posted November 22, 2013 Report Posted November 22, 2013 ^ Kickstarter for it. http://www.kickstarter.com/projects/cchu/palette-a-freeform-interface-that-controls-any-sof Quote
