Duggeh Posted June 23, 2008 Report Posted June 23, 2008 Can I use this with my jenalabs recabled HFI-780? Really though, niiiiiiiiiiiiiiiiiiiiiiice.
deepak Posted June 23, 2008 Report Posted June 23, 2008 i'd get the Krell Evo 900s I guess I'm a Pass fan as well after owning one of their amps. But yeah any amp where you can go : how many watts is your amp : over a kilowatt : what :
deepak Posted June 23, 2008 Report Posted June 23, 2008 well, the 900s are only 900, into 8 They're still probably amazingly good. only 900 into 8? give me a pair of these The problem would be finding one.
tkam Posted June 23, 2008 Report Posted June 23, 2008 The problem would be finding one. details, details
deepak Posted June 23, 2008 Report Posted June 23, 2008 details, details They were made in a very limited quantity. A statement product.
Dusty Chalk Posted June 23, 2008 Report Posted June 23, 2008 They're still probably amazingly good.Pfff. /me not a Krell fan. If you're talking greater than 3 digits of watts, I'd go Musical Fidelity kW. Or less -- I'm perfectly happy with my A308CR (250 -> 8, 450 -> 4).
luvdunhill Posted June 23, 2008 Report Posted June 23, 2008 only 900 into 8? give me a pair of these same output as a Pass x1000.5...
Voltron Posted June 23, 2008 Report Posted June 23, 2008 Hah! I get to hear that beasty before all of you fools! Maybe I should bring my k1000 with bare-ended equinox. Will it blow up my cans?
swt61 Posted June 23, 2008 Report Posted June 23, 2008 Will it blow up my cans? I'd turn the volume all the way down when hooking them up, and I wouldn't leave them hooked up for some passer by to destroy. Other than that you should be fine. I doubt you'll need much volume to drive them.
Voltron Posted June 23, 2008 Report Posted June 23, 2008 I'd turn the volume all the way down when hooking them up, and I wouldn't leave them hooked up for some passer by to destroy. Other than that you should be fine. I doubt you'll need much volume to drive them. Thanks Steve. That's a lot of watts, but I once had the K1000s hooked up to MBL mono blocks without any trouble.
Dusty Chalk Posted June 24, 2008 Report Posted June 24, 2008 It's more a function of gain than watts.
Iron_Dreamer Posted June 24, 2008 Report Posted June 24, 2008 Mother of holy christbudda! Now I really can't wait for this weekend, if just to see this monolith in person, let alone listen to it!
tom_hankins Posted June 24, 2008 Report Posted June 24, 2008 i'm perfectly happy with 240 into 4 I'm happy with my 1300 into 4. But after hearing the new 600 evos, might have to cut back a few watts to 1200.
naamanf Posted June 25, 2008 Report Posted June 25, 2008 This is definitely on my list of builds. I need to brush up on my Solidworks so I can have a case fitting for such an amp. Hmmm monoblock or single chassis?
swt61 Posted June 25, 2008 Report Posted June 25, 2008 This is definitely on my list of builds. I need to brush up on my Solidworks so I can have a case fitting for such an amp. Hmmm monoblock or single chassis? β24 Monoblocks would be crazy overkill, so of coarse that's what you should build. Two of those bad boys would be incredible!
n_maher Posted June 25, 2008 Author Report Posted June 25, 2008 I think mono blocks would probably be the easier of the two build options. I know that I'd need the extra room for the inevitable layout f-up that could derail an entire single-chassis build.
luvdunhill Posted June 25, 2008 Report Posted June 25, 2008 I think mono blocks would probably be the easier of the two build options. I know that I'd need the extra room for the inevitable layout f-up that could derail an entire single-chassis build. I think mono blocks would be harder. Since you have 2 channels on a single board, so you'll either have to use L brackets on each end and align that to the heat sinks on each side, or some weird single heat sink design. My experience is mounting directly on the heat sink is much easier to do, and less error prone.
amb Posted June 27, 2008 Report Posted June 27, 2008 Here are a few more pics. There are even more at the interim β24 website.
Voltron Posted June 27, 2008 Report Posted June 27, 2008 Tomorrow will be fun. Awesome fit-n-finish Ti.
M3NTAL Posted June 27, 2008 Report Posted June 27, 2008 That thing is sexy as helk. Cooler than my RPA-1 fo-sho
