Salt Peanuts Posted June 8, 2008 Report Posted June 8, 2008 Anyone here know cheap speaker cables with small/skinny spade plugs? My McIntosh 2100 has tiny speaker taps (there's a pic of it around here somewhere) and most spades won't come close to fitting, unfortunately. Quote
luvdunhill Posted June 8, 2008 Report Posted June 8, 2008 try the cheapest spades that Kimber Kable makes, as Vandersteen speakers historically have the same issues and I've found that these fit very nicely into the narrow barrier strips. Quote
Duggeh Posted June 8, 2008 Report Posted June 8, 2008 Replace the binding posts on the amp with ones that aren't rubbish? Quote
Salt Peanuts Posted June 8, 2008 Author Report Posted June 8, 2008 Replace the binding posts on the amp with ones that aren't rubbish? Not really an option as it's a vintage amp. Here's a pic of mulveling's MC2100 - http://www.head-case.org/off-topic/the-perennial-favorite-post-a-pic-of-your-rig/msg102821/#msg102821 Quote
Augsburger Posted June 8, 2008 Report Posted June 8, 2008 If reterminating is not an option you could try anticables, they will terminate their cables with 3/16 inch spades if those will work on your MC 2100. Quote
tkam Posted June 8, 2008 Report Posted June 8, 2008 You could just use cable with bare ends, just bend it around the screw into a hook shape and tighten the screw on it. Quote
Salt Peanuts Posted June 8, 2008 Author Report Posted June 8, 2008 You could just use cable with bare ends, just bend it around the screw into a hook shape and tighten the screw on it. Yeah, I was thinking that probably would be the easiest solution but figured it wouldn't hurt to ask around. Quote
ronnielee54 Posted June 9, 2008 Report Posted June 9, 2008 Try taking some of the material on the sides of the spades off with a Dremel tool or file if you don't have a Dremel. Quote
jp11801 Posted June 10, 2008 Report Posted June 10, 2008 barrier strips and bare wire is a great connection air tight and a solid connection. Maybe just tin the ends of the speaker wire to make it easier to connect and keep stray strands of wire on mutli strand cable from fraying. Quote
Grand Enigma Posted June 10, 2008 Report Posted June 10, 2008 Just go to Radio Shack and pick up the variety pack of crimp on spades. Should cost a few bucks at most and work just fine. Could even crimp them to the current ends of the cables you have now that don't fit. Quote
