The Monkey Posted May 23, 2008 Report Posted May 23, 2008 So I need to send in my Balanced Desktop for a minor repair. I am very tempted to have them install a stepper while it's in the shop. Yea or Nay? Quote
Knuckledragger Posted May 23, 2008 Report Posted May 23, 2008 Around here, that's a rhetorical question. This is Club "Dew Eet." Quote
n_maher Posted May 23, 2008 Report Posted May 23, 2008 I'm tempted to say nay. Tis a shite load of $$$ and the more time that passes the more variable I want my control, not less. Granted, with the gain switch you'll be all set with the HR amp but I'd be shocked if you got back the type of performance gain that the price might have you expecting. Quote
Pars Posted May 23, 2008 Report Posted May 23, 2008 Have 'em put an RK50 in it Then it meets Nate's criteria... both of them Quote
postjack Posted May 23, 2008 Report Posted May 23, 2008 For me, to SA or not to SA is a question a pure preference. I like the feel of the little clickie things. Whenever I end up buying an HR Desktop (let's face it, its an inevitability), I'll probably opt for the SA. As I'm sure you know the HR SA is very stiff, much stiffer then a DACT. Quote
n_maher Posted May 23, 2008 Report Posted May 23, 2008 I'll probably opt for the SA. As I'm sure you know the HR SA is very stiff, much stiffer then a DACT. I honestly think that this perception is purely a result of the Headroom knob's diameter. If you've ever use a Single Power amp w/ a stepper you'd understand as the feel is pretty similar. You just don't generate much mechanical advantage with the stock knobs in both cases. That's why I like to use big honkin' knobs on all my projects, it greatly helps with attenuator feel, whether it's a pot or SA. Quote
postjack Posted May 23, 2008 Report Posted May 23, 2008 I honestly think that this perception is purely a result of the Headroom knob's diameter. If you've ever use a Single Power amp w/ a stepper you'd understand as the feel is pretty similar. You just don't generate much mechanical advantage with the stock knobs in both cases. That's why I like to use big honkin' knobs on all my projects, it greatly helps with attenuator feel, whether it's a pot or SA. Interesting! Quote
CD44hi Posted May 23, 2008 Report Posted May 23, 2008 The feel of the Shallco attenuators is a bit different from that of the DACT or goldpoint. It is a bit more "stuttery." In other words the indexing is more robust. I don't think this type would be that susceptible from differences in turning torque? (which is the big knob effect). I guess to certain degree this discussion is a mute point to the OP (because HR step ladders are of one type, but I think the gain switch if of great support here [i used to own a MOHR with stepp atnn]), but could be helpful for others considering ladders on their amps. Quote
riceboy Posted May 23, 2008 Report Posted May 23, 2008 I honestly think that this perception is purely a result of the Headroom knob's diameter. If you've ever use a Single Power amp w/ a stepper you'd understand as the feel is pretty similar. You just don't generate much mechanical advantage with the stock knobs in both cases. That's why I like to use big honkin' knobs on all my projects, it greatly helps with attenuator feel, whether it's a pot or SA. I have listened to a HR Max with stepped and it sounded good, but I never heard one without SA side by side. I prefer some of my amps to not have a SA so I may control the volume better to get it just right, but I know the sound quality is not as good without a SA. I like that big knob on n_maher's amp Quote
n_maher Posted May 23, 2008 Report Posted May 23, 2008 In case there was any real doubt that big knob was a joke. Quote
Dominatrice Posted May 23, 2008 Report Posted May 23, 2008 HAHA...why not put 4 of them on there and call it a Monster truck amp? muahaha! From what i understand...the stepped pot is really only a upgrade if you listen to music at lower volumes. I dunno if thats true or not, just what ive heard. Quote
CD44hi Posted May 23, 2008 Report Posted May 23, 2008 In case there was any real doubt that big knob was a joke. Damn, you just came up with that now! I was already half way through developing a Bermoulli's for the flux of torque from index to index change..... Quote
Dusty Chalk Posted May 23, 2008 Report Posted May 23, 2008 Around here, that's a rhetorical question. This is Club "Dew Eet."x2. Quote
boomana Posted May 23, 2008 Report Posted May 23, 2008 x2. X3. I tend to favor excess when possible. Quote
Dominatrice Posted May 23, 2008 Report Posted May 23, 2008 X3. I tend to favor excess when possible. and thats why we love you Boomy...you buy the stuff some can only masterbate too. =) Quote
darkless Posted May 30, 2008 Report Posted May 30, 2008 x4. I know all about excess. For instance, since my future amp has no room left on the back panel, I asked Mikhail to add an additional position to the input switcher that will allow me to use XLR input #2 as a balanced loop-out for XLR input #1 (albeit with the wrong gender, but that is easily fixed with a pair of male/male XLR adapters). Excess? Possibly, but I like the added flexibility. Here's a pic that shows just how stuffed it is. Oh, and before you mention the spot with the white warning text as a possible place to drill another hole, it's already been covered with a metal plate and fitted with a 6-pin STAX jack. Quote
tkam Posted May 30, 2008 Report Posted May 30, 2008 It's his custom SP amp that's what almost 2 years in the making now? Quote
darkless Posted May 30, 2008 Report Posted May 30, 2008 It's been worked on since November 2006 IIRC. Quote
laxx Posted May 30, 2008 Report Posted May 30, 2008 Yea, I know it's an SP amp (whenever I see Made in USA Denver, CO in italics, I think SP). Got any other pics of it? Quote
darkless Posted May 30, 2008 Report Posted May 30, 2008 There are three additional photos in my gallery here on HC. Quote
The Monkey Posted June 16, 2008 Author Report Posted June 16, 2008 An update: I sent in the amp for repair and opted out of the SA. The amp likely will be going up for sale upon its return anyway. Next time around, I will consider the stepper. I'd like 60 steps, though. Quote
n_maher Posted June 16, 2008 Report Posted June 16, 2008 I'd like 60 steps, though. Damn near impossible with a simple, compact, discrete switch. If I were Headroom I'd be taking a cue from what DIY folks like Twisted Pear and others have done and be looking into relay-based solutions that can provide far greater numbers of steps and still be relatively compact or at least flexible. Quote
