Wmcmanus Posted 23 hours ago Report Posted 23 hours ago While I suspect that their methodology may be a bit suspect, I like the fact that they recommend specific pressings. Just don't know (personally) where to find a list of albums with measured DR rankings, although it seems to me that I've seen that before. If anyone has a good source, please share it. Spoiler Would have never guessed that Neil Young's Harvest would have made this list. Guess maybe because most of my listens were via cassette or 8-track most likely. LOL!! https://www.headphonesty.com/2025/04/audiophile-albums-show-off-systems/?fbclid=IwY2xjawJbiBxleHRuA2FlbQIxMAABHdIaG5CVJ_7HV1XInkWg-Wcl3bi5eLqEwY5TvbZI40UW4lJ_Eqj6sLgZDg_aem_6BZ_zHeMd1xzv_520xfiqQ 1 Quote
Grahame Posted 23 hours ago Report Posted 23 hours ago (edited) The DR database can be found here https://dr.loudness-war.info As described in their FAQ. https://dr.loudness-war.info/faq The links is item in the menu points to some tools if you want to make your own readings. You can use Audacity to look at the waveforms of the track to see if they have been "brickwalled" or still retain a semblance of dynamic range. https://manual.audacityteam.org/man/audacity_waveform.html Edited 22 hours ago by Grahame 1 Quote
