The Menace
  • Replies 500
  • Views 106k
  • In addition to a regulator for the PS, a CCS plate load for the first stage will decrease distortion, a CCS cathode load for the second stage will also decrease distortion, and using a MOSFET instead
  • mypasswordis
    mypasswordis
    Hey hey, come on now, the main constraint of this exercise was OTL  give the man what he wants, even if it is worse.
Lathe scraps! Clean one up, drill a couple of holes, add small bolt to tighten to extension. Just what you need, right? Another project!
Yeah Nate I have something in mind as well along these lines. >:D
You could go yard saling, and find an old stereo to steal knobs from.
Some ovens and older kitchen appliances also have some nice knobs & dials you can steal. Take a walk down the street on garbage day with a couple screwdrivers and you should be able to find something.
Wiring will commence withing the hour, but first a couple of pictures since fabrication is now complete baring the need for another terminal strip. I haven't quite made up my mind about that just yet.
I couldn't resist mocking it up with tubes >:D
Upskirt
Hmmm, that thing would look even more awesome with a custom spray job. Shame I'll never get to hear it but damn, it's nice to look at.
Looks awesome. Is that all the components you'll be using in the amp, or are there going to be other parts soldered onto socket pins or the like? Either way, huge relief after the massive parts count of some solid state stuff, eh?
I hope that it isn't that ghetto looking to you guys.
No, it looks good.
That's all the hard mounted parts but there are definitely a few more (just resistors and caps) to go that will be wired into the circuit and either attach to the tube sockets, terminal strips or otherwise. I ended up adding a second terminal strip last night to use as a grounding point. I drew up a wiring diagram for the whole amp and I just wasn't happy with how things were being routed and by the number of connections that I was having to tie to a single point. This is mostly because as a starting point the ground of the amp is going to be floated and not tied to the chassis while the amp chassis will be tied to AC ground via the umbilical cord. We'll see what I get for hum, hey at this point I'd be happy with hum, and then figure out if I need to work on an alternate grounding scheme. I'm pretty sure that there was no way this was ever going to be a single chassis amp. ;D
Here's to hoping I can get the wiring finished up tonight and maybe test it tomorrow night. A box of tubes just arrived so I've got my test tubes ready to go.
Nate
Very cool Nate! Shall I send over a case of Jolt Cola?
Well I'm crossing my fingers that when you attack it again tomorrow you'll be able to sort it all out and continue on.
Yeah, me too. I'm pretty sure that I'm ok but when it comes to matter of high voltage I'm going to defer to the expert and see what he says.
Good news arrived in my inbox this morning in the form of a "you didn't screw anything up" message. Woot!
Final wiring to commence at 7pm EST. O0
:prettyprincess: :prettyprincess:
This is Nate, posting to you live from the Top Secret Menace testing facility, errr, my basement. The power supply has just been successfully fired for the first time without issue. Unloaded B+ is right on target with the 5AR4's, now rolling in 5U4G's to see if B+ drops as expected... So far it's all WOOTS! here in NH.
And there won't be any testing of the amp tonight, I'm done with the wiring but want to send pictures to Pete for a quick sanity check before unleashing the hounds for the first time.
